Old May 29, 2009, 10:23 PM
mxcop is offline
Find More Posts by mxcop
TEAM EXTREME / HORIZON HOBBY
mxcop's Avatar
United States, NJ, Tuckerton
Joined Oct 2006
Extreme Flight RC 48" Extra 300 EXP Build
Ok guys, I decided to start a new thread for the build to help guys just getting the planes now so they don't have to dig into other threads for info. Please jump in here and post any questions and info you have as well as pictures and videos. I can tell you Chris is very excited about this new release as it is the best flying electric in this size plane that he's released yet. Between the two of us at SEFF we each flew about 20 flights a day there all week. We hammered these planes and they took it with ease. We had no mixing at all in our radios, they flew perfect right out of the box. Here are the specs from the website, just set yours up as recommended and you're in for a big treat.
Introducing the Extreme Flight
Extra 300-EXP Arf
Extreme Flight RC is pleased to announce the release of the new 48 inch wingspan Extra 300EXP ARF.
Incorporating many forward thinking design elements, the EXP is the result of several months of R&D, flight testing and refinement.
Loosely based on the mid wing Extra 300, the EXP has been manipulated to offer the most aggressive flight envelope imaginable.
Following is a brief rundown of some of the unique design features that contribute to the amazing flight capabilities of the Extra 300EXP.
-Forward canopy placement places the tallest portion of the fuselage over the CG, which is optimum for best knife edge performance.
-Huge airfoiled control surfaces utilizing geodetic construction provide the ultimate in yaw, pitch and roll authority.
-Carbon fiber longerons and motor box supports add enormous strength and rigidity to the airframe, while G10/lite ply composite laminates make for a robust landing gear mount.
-One piece airfoiled molded carbon fiber landing gear and tailwheel bracket provide solid ground handling and contribute to the awesome appearance of the EXP.
-Long tail moment contributes to rock solid precision flight performance and tracking.
-Spring loaded hatch latch provides instant access to battery tray and interior of aircraft while providing a solid attachment point for the canopy.
-2 piece wing mounts on a carbon fiber wing tube and is easily removed for transport.
-G10 elevator horn bolts on to stock servo arm to allow for insane elevator travel.
-Rudder and elevator servo mount in the rear of the aircraft and utilize a short direct drive carbon fiber pushrod with ball link for slop free control surface actuation.
-Removable Side Force Generators add tremendously to the effective side area of the EXP increasing rudder authority and improving knife edge and high alpha stability.
-2 gorgeous genuine Ultracote color schemes available with expertly painted fiberglass cowl and wheel pants.
-Complete hardware package and decal sheet included.
-High level of pre-fabrication allows you to get the EXP in the air in as little as 3 hours!
Designed around the Torque 2818T/900 and 2814T/820 (spacers included to accommodate both motors) and Airboss Elite 45 Amp ESC utilizing a 4S 2100-2600 mah LiPo battery
(we highly recommend the new FlightPower EON Lite 2550 packs!!!), the EXP achieves ballistic performance from either motor.
We offer money saving combos with either motor/esc package.
We also highly recommend the Hitec HS-65MG or new HS-5065MG digital servo for control surface actuation.
The Extra 300EXP is by far the most advanced and best performing small electric aircraft that Extreme Flight has released to date. Give us a call or place your order in our on-line store and experience for yourself the incredible flight envelope of the Extra 300EXP.
* Spinner Not Included
Specifications:
Wingspan: 48 inches
Length: 48 inches
Wing Area: 500 sq. in.
Weight: 42-46 oz.
Power: Torque 2818/900 or 2814/820 Outrunner with Airboss 45A Esc w/ 4S 2100 - 2500mAh LiPo battery
Radio: 5 channel w/ 4 sub-micro servos and ESC
Lee
mxcop is offline Find More Posts by mxcop
Old May 29, 2009, 10:37 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
Ok there really isn't much to building this plane so it's not going to get very detailed, I actually got both of mine built and ready to fly in about 4 hours. When they showed up they were boxed very well but as usual UPS managed to crush one of the boxes pretty good, luckily nothing was damaged inside the box.
Here's the equipment I'm using in my planes:
Both are powered by Torque 2814/820 with Airboos 45 Elite speed controls
APC 12/6E props with 52mm Extreme Flight spinners
Thunder Power 4 cell 2600mah V2's (crazy power)
Spektrum AR 6200 rx's
Hitec Digital HS-5065 MG's
2 24" extensions for the rear mounted elevator and rudder servos
2 6" extensions for the aileron servos
Guided by JR/DSM 12X radio
The boxes are so good looking I don't want to throw them out, lol. Everything is packed very well as you can see, and the first thing I noticed when I open them up was the quality of the covering job on these planes. No wrinkles anywhere, the paint on the canopy and cowl match the covering great as well.
Old May 29, 2009, 10:51 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
The first thing I did was pull out the iron and go over all the seams to make sure eveything was sealed. I went over the high stress areas with ca and organized all the hardware to make things go fast and easy. I took a couple pictures of the airfoiled tail surfarces with some backlight so you can see the geodetic construction which helps in preventing warping in the surfaces, yet makes for a very strong lightweight structure. The airfoiled surfaces really help this plane excell in flight performance. Also, as you can see it doesn't take any soecial attention to hinging the elevator to acheive the close to 90 degree throw, just push the surface on the hinges and push them just about flush, then deflect the surface all the way and you'll see what I mean. Another nice bonus you'll see is there is no need to cut or trim any covering other than the cooling exit hole in the bottom of the fuse, everything else is done at the factory. This plane has an extremely high level of pre-fabrication to make the build process and fast and painless as can be for the customer.
Old May 29, 2009, 11:09 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
Step #1 in the instruction manual is carbon pushrod construction. I used 5 minute epoxy for this step. First thing you do is lightly sand one end of each rod, make sure you clean them off well after sanding. I found the ball links to be very tight and was afraid I was going to damage them by forcing the rods in so I drilled them out slightly. I used a 3/32 drill bit and did this by hand. once I felt good about the fit I mixed up the epoxy and installed the links, make sure you twist them when putting them on to spread the glue evenly inside the link. I cleaned of the excess glue but left a small fillet as the instructions say. Once finished with this just set them aside to dry making sure to set them vertically ball link down to dry.
Old May 29, 2009, 11:18 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
Time for hinging the wings, locate the G10 control horns. You'll see they're all the same size however one is trimmed shorter on the bottom for the elevator. Get the wings and locate the pre-cut slots on the ailerons. Lightly scuff the contact surface on the horns and wipe them clean. Test fit them in place to make sure everything fits properly. Use medium ca for this step, I recommend using a fine tip to prevent making an mess on the ailerons. Wick some ca into the holes and apply a thin bead on the horn, slide it into the slot and quickly wipe any excess from around the horn. Wait a few minutes, then give them a tug and make sure everything's secure.
Old May 29, 2009, 11:24 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
It's time to hinge the ailerons on. I recommend pulling all the ca hinges out and folding them in half to help in making sure you have them centered when glueing. Once done doing that, slide them into the wing, then slide the ailerons on making sure everthing is lined up properly and there's no binding anywhere. Make sure you have the ailerons flush with the wings tip, otherwise they will rub the SFG's and cause problems. Go ahead and deflect the surface and apply a few drops of thin ca to the hinges with a fine tip to keep everything clean. I usually flip the wings over and apply a few drops to the other side of the hinges as well. I didn't take any pictures of this process but you will see a few photos in the instruction manual.
Old May 29, 2009, 11:32 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
[QUOTE=mxcop]Step #1 in the instruction manual is carbon pushrod construction. I used 5 minute epoxy for this step. First thing you do is lightly sand one end of each rod, make sure you clean them off well after sanding. I found the ball links to be very tight and was afraid I was going to damage them by forcing the rods in so I drilled them out slightly. I used a 3/32 drill bit and did this by hand. once I felt good about the fit I mixed up the epoxy and installed the links, make sure you twist them when putting them on to spread the glue evenly inside the link. I cleaned of the excess glue but left a small fillet as the instructions say. Once finished with this just set them aside to dry making sure to set them vertically ball link down to dry.[/QUOT
They are very tight!
bighead93 is offline Find More Posts by bighead93
Old May 29, 2009, 11:42 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
Ok, time to install the aileron servos. I'm using the Hitec HS-5065 MG's (digital version of the HS-65MG). Attatch your 6" extension and feed it into the pre-cut servo hole output shaft towards the rear of the plane. You only need to install 1 screw in the center hole on each side of the servo, this will be more than enough to hold them in. Locate the largest sinlge sided arm included with the servo and drill the outer hole out with a 5/64 drill bit to allow the included ez connectors to fit. You'll see there are two washers on the shaft, make sure you install the washers on each side of the arm to allow for easy movement. You can apply a drop of oil on the shaft (not threaded area) to allow easy free movement. Go ahead and tighten down the nut on the shaft until snug, then back it off slightly until the connector rotates freely. Place a drop of ca on the threaded portion of the shaft where it meets the nut to prevent it from backing off. Next locate the two carbon rods that are the same length. Go ahead and attatch the ball links to the G10 horns with the provided 2mm bolts, washers, and nuts making sure to mount the ball link on the root side of the horn. Use blue loctite to prevent the nut from backing off. At this point you can electronically center the arm on your servo with your radio, then slide the carbon rod thru the hole on the ez connectors. Once you have the surface centered go ahead and tighten done the set screw, once it gets snug turn it about one more turn to ensure it's retaining the rod properly. Repeat this on the other wing and your done with the wings for now. Once again I haven't included any pictures of this because Chris has several detailed photos in the manual, plus it's very straight forward with the ez connectors.
Old May 29, 2009, 11:43 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
[QUOTE=bighead93]
Yes, sand them down and drill the links out and they should slide right on
Old May 29, 2009, 11:53 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
[QUOTE=mxcop]
I just sanded them down a bit more...I used 30min epoxy! Those are set and drying...just installed the aileron horns.
Old May 29, 2009, 11:57 PM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
Next is the landing gear. The carbon gear is very nice and really adds a nice finished touch to the plane. Locate the two 3mm machine screws and washers. Use blue loctite on the screws and go ahead and mount the gear making sure you have the flat side of the gear facing forward. Locate the axles, wheels, locknuts, collars and wheel pants. An optional item here is a tube of silicone, I used silicone for repairing fish tanks that can be purchased at home depot. Go ahead and mount the wheels on the axles with the collars, then slide the axles into the gear and screw the locknuts onto the axles a couple turns. This is where the silcone comes into play, you can place a small drop of silicone on the gear or wheels pants were they meet the gear, this prevents them from moving easily, yet will allow them to move if they are bumped to prevent them from cracking. Slide the pants over the axles so they're between the axle stop and gear. Go ahead and tighten down the locknuts snug, then adjust the pants to the angle you prefer and allow the silicone to dry.
Old May 30, 2009, 12:04 AM
mxcop is offline
mxcop's Avatar
Joined Oct 2006
[QUOTE=bighead93]
Cool, good luck with your build, I'm done for tonight and will finish this tomorrow. Please post any info and pictures you want on here, you're going to love this plane. Since I'm not going to get to it tonight I'll give you a heads up on the stab/elevator installation. Just make sure you push the stab all that way forward and test fit the elevator and rudder in place to make sure the elevator half connector doesn't touch the bevel on the rudder when deflecting it. You shouldn't have any problems here, just make sure you double check this when glueing the elevator hinges. You'll see what I'm talking about when you get to this step.
Lee
Old May 30, 2009, 08:10 AM
appleflyer is offline
Find More Posts by appleflyer
Fly DW foamies!
appleflyer's Avatar
longmont, CO
Joined May 2006
you lucky dog!! you get to build and fly 2!
appleflyer is offline Find More Posts by appleflyer
Old May 30, 2009, 02:31 PM
tuck is offline
Find More Posts by tuck
tuck's Avatar
United States, CA, Citrus Heights
Joined Feb 2009
silicone is brilliant, amazing were common sense will take you.Ive been either putting a drop of ca or nothing on my pants and either way have their own draw backs.DUHHH Thank you for the trick.
tuck is offline Find More Posts by tuck
Old May 30, 2009, 06:43 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Quick questions...getting ready to mount the motor and I will be using the 2 ply spacers...what is the super thin fiberglass piece for? It is the same size as the ply pieces but paper thin. By the way...Easiest build so far!
Article Extreme Flight 58" Extra 300-E Review Bill K. 3D Flying 123 Dec 14, 2015 11:09 PM
Discussion New Extreme Flight RC 48" Extra EXP mxcop 3D Flying 3 May 20, 2009 12:49 PM
Off Site Extreme Flight 58" Extra 300 sdstick Aircraft - Fuel - Airplanes (FS/W) 3 Jun 05, 2008 04:13 PM
Discussion Extreme Flight 58" Extra 300 with Hacker C50 13S+6.7:1 Ed Lyerly Sport Planes 32 Jan 09, 2008 11:18 AM
New Product Extreme Flight 45 inch Extra 300-E Distributed by Atlantahobby.com atlav8r Product Announcements 1 Jan 29, 2006 06:35 PM
