Espritmodel.com Heli Air
Old Jun 13, 2009, 09:21 PM
Does it fly?
Gussy's Avatar
Melbourne, Australia
Joined May 2007
Without wanting to wish you any bad luck... I hope you find some more defects soon!!
Gussy is offline Find More Posts by Gussy
Old Jun 15, 2009, 07:55 AM
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Okay folks, if you haven't guessed the fault yet, it's closing in 1 HOUR, (midnight here in Australia, AEST).
Paul.
PLD is offline Find More Posts by PLD
Old Jun 15, 2009, 09:12 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Competition is now CLOSED.
The fault was that the middle track wasn't quite drilled out enough, so there was a very fine trace of copper still causing conduction and preventing the system from shutting down.
Old Jun 15, 2009, 05:39 PM
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
Ahhh - that was my next guess
glydr is offline Find More Posts by glydr
Old Jun 23, 2009, 04:43 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
##CLOSED## - Defect 4, June 23, 2009
Okay, I overshot the usual 1 week repeat for the defect but here's the next one (to be fair, I did have another one submitted to me by a good person but I'm still working on that ).
The prize for this week is a mystery, even to me - yes I'm serious, I don't know what I'm going to offer up yet, so consider it a big of a lucky-draw.
So here we go, straight out of the reflow oven.... (these are PLD-BAC-ESJ base units)
Paul
Status
Glory points: Neilmy, Dusk, Gussy, DonQ, gman326, mudman1959, glydr, sparkysko, Charles Beener, littlewing78
Prize claims: Kentucky
Defect: A resistor on the back of the 3rd board from the left has gone vertical (tombstoned).
Old Jun 23, 2009, 04:57 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Okay, got two successful responses so far
Old Jun 23, 2009, 05:12 AM
Does it fly?
Gussy's Avatar
Joined May 2007
Dead easy
(I thought it was a fitting response... heh)
Old Jun 26, 2009, 11:41 PM
I meant to do that
littlewing78's Avatar
Eagle Mountain, Utah
Joined Jul 2004
PM sent
littlewing78 is offline Find More Posts by littlewing78
Old Jun 27, 2009, 12:02 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Okay, comp is now closed... until next week
The fault was, as many people correctly spotted, the resistor on the 3rd board has "tombstoned". This happens sometimes if there if the part hasn't made proper contact with the solder paste on one side, when the reflow phase occurs the surface tension of the other side is more than sufficient to yank the part up into the air.
Paul.
Old Jul 11, 2009, 10:45 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
CLOSED - Defect 5, July 12, 2009
update - prize is claimed, now it's all for the glory!
Wow, can you believe it's been a MONTH since I posted the last defect, or so it seems.
Here's the next one, symptoms are simply that it doesn't start the discharge process for the lipo cell #3, the other two cells discharge fine.
Hint #1 - There's no solder bridges. Anything you think is a bridge is not, it'll be likely flux slag reflecting the halogen lights
The prize... is a lipo Normaliser, only one of these to give away so BE QUICK
Also, an adjustment on the glory-points schedule, we'll work it like this from now on;
1st correct = 3 points
2nd = 2 points
Everyone else gets 1 point after that, that way it means that we can get shuffling of the leaderboard based on their response times
Paul.
Stats
Prize: RCHMC (USA)
Glory: DonQ (+3), mudman1959(+2), glydr(+1)
Defect: The small inductor (grey block, looks a bit like a capacitor) on the right hand side is missing solder on the pad closest to the camera.
Old Jul 12, 2009, 01:42 AM
TacoChuck's Avatar
United States, MI, Ann Arbor
Joined Feb 2008
Switched to PM - Sorry about that pldaniels, I wasn't thinking or reading apparently.
TacoChuck is offline Find More Posts by TacoChuck
Old Jul 12, 2009, 01:47 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Hey there Taco,
PM the guesses Don't want everyone knowing
Paul.
Old Jul 12, 2009, 03:58 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Old Jul 30, 2009, 03:44 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Defect #6 - Starting July 30, 2009
Here we go again
The sheeded paper fibers aren't the fault and the TACO chip is meant to look a bit grubby.
PM me with the fault INCLUDING if you want the prize or points towards the 3 month price.
For glory points - 3 points to the first correct, 2 to the second, 1 point for all the rest.
The prize for the first correct prize claimer... a low voltage alarm / readout ( http://nqrc.com/?vp=PLD-LVA-MINI-NI ).
The prize for the second correct prize claimer... one each of the new PLD Voltage protectors ( PLD-VP220, VP470 and VP1000 - http://nqrc.com/?vp=PLD-VP1000 ).
PRIZES
Main prize: glydr
Secondary prize: Dusk
SCORES
neilmy: +3 pts.
kentucky: +2 pts.
gman326: +1 pts.
DEFECT: The 470 resistor on the front-left didn't have its pad soldered during the reflow, instead it's resting above the actual PCB pad.
Old Aug 05, 2009, 10:38 PM
glydr's Avatar
Joined Feb 2004
Main prize arrived thanks - so tiny!
This one will go on my new small slopey - a Wasp. Am thinking of attaching such that it is visible through a little window.
Nice.
Poll Should the AMA accept the less than $1000 per year for a spot on it's website? J_R AMA (Academy of Model Aeronautics) 23 Apr 22, 2006 01:58 PM
