Old May 28, 2009, 06:19 PM
rich95 is offline
Find More Posts by rich95
Heli Whore
Toronto, Canada
Joined Nov 2007
Question
Confused - Thunder Power balance tabs?
Hi there;
I've recently acquired a new 4S lipo that comes with a Thunder Power balance tab. I intend to convert this to a standard JST XH.
However, a 4S JST balance plug has 5 cables and this 4S Thunder Power has 6. Now I'm confused. Why 6 cables for a 4S balance tab? And if I do this conversion to the JST XH 4S tab that uses 5 cables, which one do I drop?
Or should I go with a TP -> JST XH converter? Any ideas where to get this?
-Rich
rich95 is offline Find More Posts by rich95
Old May 28, 2009, 07:13 PM
cgbole is offline
Find More Posts by cgbole
cgbole's Avatar
Tulsa Int, Oklahoma, United States
Joined Aug 2002
It has 6 leads because it is the same one they use for a 5s pack. They just don't connect all the leads.. for instance my 6s packs have one 4 wire balance plug and one 6 wire plug. The 4 wire plug has to be connected to the balancer after the 6 wire plug because it has the wire that is connected to the neg lead of the pack. I'll look around on here but there was quite a few posts with diagrams of TP ballance connectors. Showing how they are wired...
chuck
cgbole is offline Find More Posts by cgbole
Old May 28, 2009, 07:20 PM
rich95 is offline
Heli Whore
Toronto, Canada
Joined Nov 2007
Thanks, Chuck. What is the correct way to electrically test each lead and find out which one is not connecter to the cells?
-Rich
Old May 28, 2009, 07:56 PM
cgbole is offline
cgbole's Avatar
Joined Aug 2002
Yes but i don't mean to talk down to you but i'd hate to be responcible for
for messing it up or starting a fire.. So if you don't know what you're doing..
If the balancer connector is color coded, (Typical TP balance lead) the black wire should go to the neg. lead. The next one should go the the first positive tab on the first cell. And then the next wire should go to the next positive side of the next cell.. You can tell by the voltage reading from a volt meter.. place the neg test lead on the neg lead, and then touch the positive test lead to the second lead in line on the connector. the second wire will be .. 3.6V the next (3rd wire) should read 7.2V the next 10.8 ect... depending on charge level.. DO NOT short the leads...
chuck
Old May 29, 2009, 02:38 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
If you scroll down to the bottom of this page http://www.flighttech.co.uk/index.as...eries/EON.html you'll find a wiring diagram for FlightPower balancers which, in my experience, are identical to TP ones. It shows, among other things, how the 6-pin plug is wired for a 4-cell LiPo.
abenn is offline Find More Posts by abenn
Discussion source for thunder power balance tap 4mla1fn Batteries and Chargers 5 Nov 08, 2008 12:12 PM
Help! 2S Hyperion to Thunder Power balance adaptor Stephen Bennett Batteries and Chargers 1 Oct 22, 2007 11:54 AM
Help! Thunder Power Balance Plugs to Astro Blinky Adapter for 6s Lipo graupman Power Systems 0 Mar 09, 2007 10:05 AM
Discussion Thunder power balance adapter johnnychimpo Batteries and Chargers 3 Mar 01, 2007 01:19 PM
Discussion Thunder Power balance tap wires keep falling off.. Safety Hawk Batteries and Chargers 7 Jul 05, 2006 10:33 PM
