Bombardier CL-415
I kept flying the models I have whenever weather and spare time allowed, but haven’t built anything since 2007. Got into this new hobby:
Suddenly I got the building bug and decided to do the CL-415. Before starting the guitar thing I was thinking of learning Rhino and use it to build models. Now I can tell it’s not going to happen. Constantly dedicating at least one hour per day to guitar practice can only allow for quick, cheap and dirty builds. Well, the 415 deserves better, so it won’t be that cheap, but I won’t care much about details and scale. Since I will use some techniques that go well with any model, I will post it here in the Scratchbuilt section because there is more traffic Thanks, S55 |
The 3-view drawing I used is available here, if you click on the Specifications and Performance tab.
http://www.bombardier.com/en/aerospa...1260d80008fff# I enlarged it at Kinko’s to 40 inch wingspan and followed these steps. Two template pairs were made of formica: one for top/bottom and one for left/right. Sanded the edges very carefully so the hot wire would slide nicely on them. Then I cut a plywood piece following the keel line and glued/sandwiched it between two foam blocks. Then I used the top/bottom templates and hot wired the sides. After that I placed the left/right side templates and hot wired the hull bottom. The plywood keel was helpful during this step as the hot wire was resting on it and on the side template. |
Hi S55, Looking good so far.
Here is a free set of plans for the CL-415 with a w/s of 67in. Maybe it can help you with some idea on your build. http://www.aerosquare.com/content/ca...24/42/lang,en/ |
| Thread Tools | |
| Canadair CL-415 Progress | Slope Nut | Scale Electric Planes | 83 | Jan 31, 2009 01:06 AM |
| Discussion Bombardier CL 415 Waterbomber | kcar | Electric Plane Talk | 8 | Mar 22, 2006 12:19 AM |
| Beldone Models CL-415 | Mark Turner | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 03, 2003 02:38 PM |
| Canadair CL-415 inflight photos | Slope Nut | Scale Electric Planes | 5 | Jan 27, 2003 10:50 AM |
| Fowler flaps for Aeronaut CL-415 | Immelmann | Scale Electric Planes | 0 | Dec 14, 2002 01:22 PM |
