Old Sep 11, 2012, 09:18 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Originally Posted by Dumle View Post
Exactly same problem here. Any help Junsi, please?
You can solve this problem via upgrading to the latest version CellLog(8S)_V208. Any other questions, please feel free to contact us.
Junsi
junsi is offline Find More Posts by junsi
Old Oct 02, 2012, 04:03 AM
__Tango is offline
Find More Posts by __Tango
Joined Oct 2012
Originally Posted by barns_from_oz View Post
Hi
Can anyone provide the serial settings? I can download/send the logfile, but get lots of junk, as I dont have the serial speed, parity etc right. I guessed it might be 115k speed, but expect 8N1 parity and CTS flow control, but it is apparently not.
What did you use as a USB driver for the Mac? I can't even see the cellog from my mac as it's not coming up.
Thanks!
__Tango is offline Find More Posts by __Tango
Old Oct 04, 2012, 11:07 AM
__Tango is offline
Joined Oct 2012
Got it. The USB UART is a Silicon Labs CP210x variant. The Product ID (as shown in the "About this Mac -> More Info -> System Report -> USB") is 0xea60. I found a driver for this here: http://www.silabs.com/products/mcu/P...CPDrivers.aspx. The 3.0 driver works fine for me in Mountain Lion (10.8.2).
Old Nov 09, 2012, 01:38 PM
vic_bull is offline
Find More Posts by vic_bull
Russia,Moscow
Joined Jan 2007
Dear Junsi I found my Powerlog flat dead today. After some confusion I remembered that I was trying accidentally to check the voltage of the small AC power supply with it a week ago. Is there anything could be made before trashing it? Thanks.
vic_bull is offline Find More Posts by vic_bull
Old Nov 13, 2012, 07:00 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Hi all,
Long thread so I apologize if this has been covered already.
I would like to know if the PowerLog provides individual cell voltages in the LogView software as the CellLog does.
Thanks.
David
davehour is offline Find More Posts by davehour
Old Nov 13, 2012, 08:57 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
@vic-bull
Please check the PM we have sent to you. Thanks.
@davehour,
Yes, the PowerLog does, please refer to the detailed specification on the first post of this thread.
Junsi
Old Dec 26, 2012, 10:27 AM
alewank is offline
Find More Posts by alewank
Joined Dec 2012
Setup config Not Saved Powerlog 6S
Hi Junsi, I have a problem... when I try change interval log time, file # or other setup things, the Powerlog 6S did not save the new config... I have upgrade the firmware OK, but still in same condition, changes at setup not saved...
Any ideas?
Alex
alewank is offline Find More Posts by alewank
Old Dec 26, 2012, 07:43 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Any ideas?
Alex
Hello Alex,
Sorry to cause you this trouble, could you please try to upgrade to the lastest firmware again? If it still fails, please let us know, thanks.
Junsi
Old Dec 27, 2012, 12:06 PM
alewank is offline
Joined Dec 2012
Originally Posted by junsi View Post
Hello Alex,
Junsi
Hi Junsi, It still in problem... I have upgrade to PowerLog6s_V110.bin.
For example, when I select LogFile2 and push MENU to exit and save (more to 2 seconds), the display return to LOG FILE menu and LogFile1 is selected.
Other, when I enter in System/Record Interval, and select other value than 0.25 Sec, it record 0.25 Sec without change...
In START SETTING when I select LOG Screen and or Inf. Screen, the changes are not saved.
Please, tell me how can I repair this problem.
Regards.
Alex
Old Dec 27, 2012, 07:30 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Regards.
Alex
Please check the PM we have sent to you, thanks.
Junsi
Old Jan 20, 2013, 01:24 PM
freddy85 is offline
Find More Posts by freddy85
Joined Jul 2009
How long can PowerLog continuous sustain the 130amp rating?
thanks
freddy85 is offline Find More Posts by freddy85
Old Jan 20, 2013, 04:44 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
freddy, I too would like a recommendation from Junsi on this.
Given that the current sensor is a very robust 0.0002 Ohm metal resistor, that cannot be the limiting component at these currents. 130Amps is less than 4 Watts dissipation.
Likely the limit of 40A continuous was made because of measured temperature rise inside the unventilated case from heat conducted to the PC board. Most of this heat will be generated by the resistance in the Deans Connectors not the resistor itself.
Just for info, I will be experimenting shortly with a Powerlog suitably modified to see if it will run continuously and accurately at 130Amps. Happy to post the results back here when finished.
UPDATE: I did test the temp rise way back when the Powerlog was first released and suggested the connectors were the main thing to look at then. Had forgotten about that!
http://www.rcgroups.com/forums/showp...&postcount=345
John
jj604 is online now Find More Posts by jj604
Old Jan 30, 2013, 10:41 AM
NAHANNIV is offline
Find More Posts by NAHANNIV
Joined Jan 2013
Current monitoring affects Cell 1voltage ?
I am having a problem with the PowerLog 6s.
I have it connected as per the diagram in the manual, to a 4cell battery pack and to a load/charger.
I am monitoring individual cell voltage at the same time as current.
The problem is that the Cell1 voltage seems to be affected by the current. The change to cell1 voltage is proportional to the current (magnitude and direction).
I first thought Cell1 had a High internal resistance, but running the same test with the two current connectors unplugged from the PowerLog and connected together resolved the issue.
The direction of the current also seems confusing: -Amps for charging and +Amps for discharge.
What am I doing wrong.
John.
NAHANNIV is offline Find More Posts by NAHANNIV
Old Jan 31, 2013, 12:09 AM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
John,
You need make sure there is no large current through the ground of balance port on the charger, if has current, it will cause effect.
Junsi
Old Jan 31, 2013, 12:33 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
IMO it makes sense, since power goes out through the port labelled "Input" when charging.
flarssen is online now Find More Posts by flarssen
