Old Mar 19, 2012, 03:26 AM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
Junsi.
To simplify my request. I would like to be able to see how many mAh my flight has drawn after landing.
/Håkan
Originally Posted by hakank View Post
I have a Powerlog 6S and a question. Is there a way to have the mAh NOT to reset when I throttle down to 0A? As it's now it will reset itself when 0A flow after about 5 sec.
Thanks in advance.
hakank is offline Find More Posts by hakank
Old Mar 19, 2012, 11:02 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Sorry for digging up an old question, but cant seem to find the answer let alone the question....
When connecting my 6S lipo at full charge, my reading a cell 4 is always way out. At 80% discharge or storage voltage it seems to be ok.
Can someone please tell me what is the fix for this problem?
I have a powerlog 6
evltoy is offline Find More Posts by evltoy
Old Mar 24, 2012, 08:35 AM
driveday is offline
Find More Posts by driveday
Joined Aug 2011
Junsi.
/Håkan
I think you are talking about the function of capacity, in the page8 of the manual.
driveday is offline Find More Posts by driveday
Old Mar 24, 2012, 01:52 PM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Indeed.
Problem is the value is reset to zero again with no flow of current after about 4 seconds..
/Håkan
Old Mar 26, 2012, 10:14 AM
driveday is offline
Joined Aug 2011
"When there is no current flowing through T-Plug, if the displayed current is not zero, please press <▲>+<▼>+< > for 3 seconds" that is the original design from Junsi.
Old Mar 27, 2012, 02:00 PM
ErichH is offline
Find More Posts by ErichH
Joined Mar 2012
Hi
After the update i got the error: "ERR: Flash Memory" and it does not save any logging data. All other functions seem to work fine.
Any solution?
ErichH is offline Find More Posts by ErichH
Old Apr 08, 2012, 07:52 AM
UPz is offline
UPz
Find More Posts by UPz
UPz
Joined Apr 2012
Hi all!
I'm new here and I have a newby question:
I'm not into RC and I don't have very deep knowledge on electronics.
I'm considering buying a PowerLog 6S from hobbyking, to make my work easier.
I'm into flashlights world, and I review flashlight for several sites. I've been using a home made system (webcam+multimeter+timer) to grab the runtime on the diferent modes and record the current draw at every minute.
With the Powerlog I will be able to record Amp draws, cell volts and temperatures... which is very valuable information, but I'm not sure if it will work with single battery flashlights, NiHM or Li-Ion.
Will the powerlog 6s log data from a 1.2V NiMH powered flashlight?
I don't know if it can work with less than 4.5V, as stated on the manual.
Aslo, I don't know if it needs a external power supply (USB or battery).
Thanks in advance for your help!
UPz is offline Find More Posts by UPz
Old Apr 08, 2012, 11:32 AM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Thanks. I think it did the trick!
/Håkan
Old Apr 09, 2012, 09:37 PM
LizardMan is offline
Find More Posts by LizardMan
Joined Sep 2010
Originally Posted by UPz View Post
Hi all!
If the battery connected to the main power port doesn't supply enough voltage for the PowerLog6S, supply it power via the servo or temp probe ports. An RX pack purchased at your local hobby store should work fine. I'd purchase a five cell NiMH pack built using 2000 mAh or larger cells. A four cell pack (very common) is cutting it a bit close, a five cell is a better choice.
LizardMan is offline Find More Posts by LizardMan
Old Apr 09, 2012, 10:03 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Also, if you are logging to a PC, the USB connection will supply the necessary power. No extra battery required in that case.
You could use the USB connection plugged into a USB car charger/wall wart as another option.
jj604 is online now Find More Posts by jj604
Old May 01, 2012, 01:40 AM
red1one is offline
Find More Posts by red1one
red1one's Avatar
United States, MI, Ann Arbor
Joined Mar 2012
In addition to the manual for the Powerlog 6s, are there any youtube or other videos available to show basic use?
red1one is offline Find More Posts by red1one
Old May 11, 2012, 11:28 AM
barns_from_oz is offline
Find More Posts by barns_from_oz
Joined May 2012
Hi
Ive just bought a CellLog 8S, and cannot use LogView (stuck on a mac)... Im guessing my choices are a mac version of the fabulous-looking LogView - or of AJH's simpler display tool from 2009 - neither of which seems likely! - OR info on the serial settings for terminal software?
Can anyone provide the serial settings? I can download/send the logfile, but get lots of junk, as I dont have the serial speed, parity etc right. I guessed it might be 115k speed, but expect 8N1 parity and CTS flow control, but it is apparently not.
Then I'll have to work out what format the data is in (specs for Open Format, anyone?) but this comes first. Im hoping Excel does a pretty good job these days? All I need to do is locate a few dicky batteries!
Any suggestions please?
barns from oz
PS Im using a mac laptop with CoolTerm for Mac; I have 6 harnesses set up to monitor 150V worth of 45 LiPo ThunderSkys. Battery management error light comes on as soon as I put my foot down, but pack still charges to full (~154V) each cycle... now looking for a dicky battery or three
barns_from_oz is offline Find More Posts by barns_from_oz
Last edited by barns_from_oz; May 11, 2012 at 11:33 AM. Reason: added more questions...
Old May 11, 2012, 01:05 PM
AJH is online now
AJH
Find More Posts by AJH
AJH
AJH
UK
Joined Jul 2004
"Can anyone provide the serial settings?"
128000-N-8-1, no flow control.
The repeated data fields will be of the form:
$1;1;;3945;3933;3938;3939;3930;3937;0;0;23622;20
$1;1;;3945;3933;3938;3941;3930;3937;0;0;23624;29
Decoding is left as an exercise for the reader. Clue: The above was a 6 cell LiPo.
AJH
AJH is online now Find More Posts by AJH
Old May 12, 2012, 11:34 AM
Joined May 2012
Thanks, AJH for the serial and data formats...
Many thanks for the quick reply; nevertheless, so far Im snookered, as you will see below....
But first, is it true you are the person who wrote the 'simpler' display tool? As you can see I have no idea if this is a reasonable question, but is a mac version possible?
I ask because the serial specs you mention dont exist when I look at 2 bits of mac serial term software. They only know about speeds NEAR 128,000... specifically 115,200 and 230,400 bps. What a challenge! Should I keep looking? Ask the developers? Can the CellLog be persuaded to output at any other speed? A secret menu, perhaps?
Seems there are multiple standards for serial speed. That's what I like about standards, so many to choose from... :-))
Cheers, barns
AJH
Old May 12, 2012, 01:52 PM
AJH is online now
AJH
AJH
AJH
UK
Joined Jul 2004
"is it true you are the person who wrote the 'simpler' display tool?"
Guilty as charged.
"is a mac version possible?"
Not from me - I can't even spell Macin??, but I'm reliably informed that other programs of mine that use the same serial comms and graphing routines run on Windows emulators on Macs.
"A secret menu, perhaps?"
I have no information from the device manufacturer, I simply reverse engineered the data stream. I would think it unlikely, as the achievable Baud rates will be fixed by the processor clock speed.
Out of curiosity , I downloaded the Windows version of CoolTerm. Near the end of the help file there is a section entitled:
"Adding extra baudrates to the selection in Connection Options"
I did as instructed and got it to listen to my CellLog at 128000, successfully reading data shown in my previous post. I would expect the Mac version to be similarly capable.
AJH
