Old May 25, 2009, 08:17 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Electric flyers: How much current does your radio/ESC draw with switch off?
I have an older Futaba single-stick 8ch radio in a sailplane with a 40A ESC w/BEC. The ESC has a switch to be mounted on the plane, which turns the system on and off... I thought.
But I just measured the current draw from the battery (11.1V 2100 mAh 20C LiPo) with the switch off... 35 mA!
Quite a surprise. I expected maybe an order of magnitude less than that, like 3 mA or less. I mean, it's just sitting there doing nothing, receiving nothing. I thought turning a switch off, was supposed to mean OFF. Were's all that current going? I measured it two different ways, got the same answer both times.
With switch on and transmitter on, the currrent draw of the receiver, servos, and ESC while idling jumped to 75 mA, which was a little more what I expected (though still high?)
Do these numbers jive wih what you fellows are seeing in your systems?
Little-Acorn is offline Find More Posts by Little-Acorn
Old May 25, 2009, 08:58 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It's not an on-off switch at all. It's simply a disarming switch to prevent the motor from running accidentally. The battery MUST be unplugged to turn the system off. Leaving the ESC plugged in will drain the battery in a few hours or days, very likely destroying a LiPo.
Daedalus66 is offline Find More Posts by Daedalus66
Old May 25, 2009, 09:15 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Turn the ESC's switch off and leave the TX on.. move the sticks. Often the RX is still powered and the servos will respond.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old May 26, 2009, 12:26 AM
San Diego, CA
Joined Dec 2006
It would be nice to have a switch that simply cuts off the battery, the way older (non-electric power) systems did. Of course, those systems didn't draw 40-plus amps at full power, they way present ones (including the one in my sailplane) do. If you open a set of switch contacts while that kind of current is flowing through it, your switch had better be built to handle it. And the switch may weigh more than the plane.
But this makes me wonder. Will I switch off that battery-cutoff switch, when the motor is running at full power? If I switch off the existing switch on the ESC, doesn't that GUARANTEE me that the motor will not be running at full power afterward? Maybe a less-hefty switch can be used, as a battery cutoff, as long as the ESC switch is always turned off first?
Of course, that battery cutoff switch had better be able to handle that 40 amps flowing through it, which obviously it WILL get during max-performance climbs, racing, etc. But a good switch should have nearly-zero ohms resistance, so a moderate-sized one, correctly designed, may be able to handle such a current. As long as it will NEVER be asked to interrupt that current itself.
Do such switches exist? Anyone know?
It would be nice to simply flip off a switch (or two) after flying, without having to pop the hatch, remove the battery (not easy in my plane) and unplug a pretty stiff connector. Am I dreaming?
Old May 26, 2009, 10:58 AM
Joined Mar 2005
for the switch to cut off all power drain out of the battery, it has to be in a wire between the battery and ESC.
I have added such switches to some models that have awkward access to the battery.
Old May 26, 2009, 11:35 AM
San Diego, CA
Joined Dec 2006
Egg-zactly. I wonder if there is such a switch, that can conduct 40A through its contacts, as long as it is assured that it will NEVER be switched off while that much current is flowing?
Old May 26, 2009, 11:43 AM
Joined Mar 2005
What a lot of people do is take a female deans plug.. wire it into the + lead. Take a make and jumper between poles. Remove the plug and the battery is disconnected.
Thats rated for appx 60 amps.
I found a large automotive toggle switch rated to turn on-off a 60 amp load.
Discussion How much current does the tail motor of an elec heli use jhdgkss Electric Heli Talk 2 Jun 03, 2006 11:11 PM
Question How much current does my charger need? SaMx Batteries and Chargers 14 Jul 22, 2005 08:24 AM
How much power does your radio gear really draw? Beta testers needed. Comatose Power Systems 121 Jul 01, 2005 04:23 PM
How much current does it take to fly a hornet cp on the stock ms motor? Auger Micro Helis 1 Nov 25, 2002 02:34 AM
How much current does your elmn draw yjin Electric Heli Talk 3 May 08, 2001 11:35 PM
