Just in case anyone else is struggling to get the 'magic juice' I found this link which may be worth a look.
http://www.rcuniverse.com/forum/m_63...tm.htm#8142505 sparks |
Help needed!
A question from the "Control Line" forum about an unknown diesel from Russia:
http://www.rcgroups.com/forums/showthread.php?t=1308195 Look relatively "modern" but might be from the 80's. |
The russian diesel is beyond me!
Report of successful decanting of the easy start. Needed or not, I had left the can of easy start in the freezer for a day. Got home this evening, opened a window and upturned the can to spray off the propellant gas. It took a minute or two. left it upturned for a few more seconds, squirted the last bit of residual pressure then put it back in the freezer for a while. Took it out an hour later and tried the pressure with the can upturned. I got a neat, single jet of fluid Squirted the fluid into a screw top bottle until there was no more. To check, I carefully pierced the bottom of the can with the opener very slight hiss, barely perceptable cut off the bottom and there was only half a teaspoon of liquid left in the can, hardly worth the effort really. It smells like ether should smell!! :-) Fuel mix later. sparks |
![]() ![]() Sparks, I think the neat, single jet was your stuff! No need for the second cooling or spray-off, when it stops spraying inverted the first time, you're ready to puncture (one each side, pour off and enjoy). |
Hey Chas,
the second cooling was done, just to be sure that I had got all the propellant gas out, as you say, there was no need, the neat juice flowed freely. Now to the next problem...it is sooooooo long since I started, or ran a diesel! Got the DC Merlin all hooked up, mixed the fuel, around 40/40 + 20 of castor first problem was air in the line, sucked that through by choking the venturi but apart from a few minor snaps, no run a squirt in the venturi and two or three flicks later we have a buzz or two. Kept trying this, up and down the compression, in and out the needle, but nothing more than few seconds bursts, but never quite picking up in time for me to ease the compression, lean the mix etc. It was still great to hear that diesel sounds, even if only briefly. I'm suspecting that fuel isn't being pulled in, any suggestions on spray bar orientation? I can't recall that it mattered so much ....? Or maybe I need a bit more Ether in the mix? Any suggestions guys? sparks |
![]() Seriously tho, if you invert the can and make a hole in the bottom (now the top) the propellent will hiss out..... So then you turn the can the right way up again over your jam jar and the heat from your sticky mitts will let the Ether squirt out into said jar. But as we are "down under" up and down might be the other way for yoos up there..... ![]() Mark |
No....your present 40% ether content is already touching the ceiling....you would be just fine with 30%, maybe less...no rocket science here...
![]() Those "few seconds" bursts indicate that your fuel should be ok, and the fault is to look for elsewhere....i.e. a leaking backplate seal, incorrect tank position, leaky fuel line, etc.... Another possibilty: (quoting info from the excellent 'Modelenginenews' site) Quote:
Interesting note thanks Glue'.
I also think the fault is elsewhere. I had the fuel tank about level with the crankshaft, though the line is a little bigger diameter than i'd like, and the tank is a clunk type. They are all I can get here. After I blew the bubbles through it seemed to stay reasonably clear. I guess what I should do it get out the tin plate, brass tube and big soldering iron and knock one up. I'll have a look at the rear seal. The red deck seal is there, and I think it looked ok when I whipped the head off to take a look at the internal conditions. Maybe I need to check that the cylinder landed properly, but I was careful sliding it back in. If it's too thin, how will I know? any thoughts about the orientation of the spray tube? cheers sparks |
![]() Quote:
I run my DC Merlin with the spraybar hole out of sight, ie. facing "downstream" - works fine. So long as the red washer is there, thickness shouldn't be too critical, as the alteration to timing would be almost too small to measure. Don't lose that propnut! The bugger is 3BA, and you won't find those in B&Q!
QLD, Australia
Joined Sep 2003
Chas,
The initial advice of refrigerateing the JD start cans has shown a secondary problem , that of disolved butain being trapped in the ether , which later causes gas bubbles in fuel lines and giveing inconsistant runs. Its now recomended(I have done this) to just invert the can and spray off the gas, then open up the base of the can- I use a rotary style can opener n cut the whole base off, makes pouring out the ether both quick n easy. Only a small amount of ether is lost this way and all the gas gets to escape. Stewart |
| Thread Tools | |
| Diesel Engines | Aeromister | Engines | 8 | Sep 01, 2009 07:17 AM |
| Discussion Need help with two diesel engines ! | cosmin | Engines | 3 | Feb 17, 2005 05:27 PM |
| WTB-Model Diesel Fuel | slogo | Aircraft - Fuel - Airplanes (FS/W) | 3 | Nov 13, 2004 09:42 PM |
| scale model of engines | dw1122 | Life, The Universe, and Politics | 2 | Apr 23, 2004 05:43 AM |
| diesel engines | wyflyer_55 | Fuel Plane Talk | 7 | Apr 22, 2002 02:45 AM |
