Many of the classic "non-wearoutable" diesels had unbushed big ends....I am thinking of all those old Webras, PAW's etc, of which many are running on their 40'th or 50'th C/L season....
![]() If the bearing support area isn't exceptionally small, I think there is no reason to worry... ![]() PS I feel 20% castor is a tad on the low side....I would go for 25%.... |
I isn't.
![]() The greatest routine malady with diesels is the stuck contra. It's almost impossible to fix without stressing the rod, or disassembling the engine and ruining those beautiful fits. With synthetics it doesn't happen. Just incidentally, I found the most effective/least intrusive method is to pass some soft string into the bore through the exhaust ports. Fill up the cylinder as much as you can, then gently rotate the shaft until you hear that rewarding click!. Still stresses the gudgeon and rod though. |
OS part number 21805000 conrod .15 RX fits the Norvel .15. Andy figured this out some time ago. What material are you using for a new piston for the Norvel .15? BTW, Andy's biodiesel test showed it wasn't really burning much, if any, of the biodiesel.
Schlosser over the Valentine any day. I own neither, but will never buy a Valentine. after seeing the Schlosser and running it, it's on my list. I have an AE0.1 that has issues I have to fix. Overall the AE is a disappointment. Greg |
Latest blog entry: A tiny diesel engine AE 0.1CC
Ancaster, Ontario, Canada
Joined Oct 2005
Thanks for the info on the above two “comparisons”. I’ll take your advice with thanks. The owner wants $350 Cdn for this specimen. Seems very steep. That’s more than the new OT!
Warren, I don’t think you are alone, “maybe it's time to admit I have a problem?” As Bill said, this place needs a serious clean out. Chas, what was the term you used earlier….”I can only think of Crankologist, a name with a nice ironmongery ring about it and just about the right shade of meaning." Engine addicts, crank, not crack, addicts. I picked up a Merco .29 (5cc) in what would probably be called good condition. I’ve soaked it with penetrating oil and used a fair amount of heat, but I cannot get the last head bolt to loosen up. I could leave well enough alone and not polish the inside of the cylinder (to clean the varnish and crud out), or I could risk snapping the bolt. Would I damage the metal if I tried to shock it with freezing (liquid nitrogen). Freezing the engine, then quickly warming the outside might loose the bolt threads, or I just might damage all. |
Hi John,
$350 is rather steep for a 0.25 Schlosser, but expect to pay around $200-$250. The trouble is finding one at any price. My method for contra pistons is to remove the comp screw and push the contra down with a suitable pin punch through the screw hole in a drill press. Once the "seal" has been broken, and with a bit of fuel squirted in on top, the piston has a much easier time pushing it back up. If the engine can be disassembled, pushing the contra up and down in the bore a few times, again using a pin punch in the drill press, will ussally free it up. This also works quite well on engines which are not completely stuck, but where the contra is bordering too tight anyway. Using the drill press as a press is also the best way to press off prop drivers etc. Iv'e had to deal with a few impossible Merco head screws (I have too many of those too!), only way I've had success is to drill off the screw head, then once the cylinder head is removed, remove the screw stump with vice grips. I've tried easy-outs but the screw diameter is too small and the extractor is easily broken off in the screw -doubling the problem! |
John, Years ago faced with the same problem I took the motor to a machinist who set it up in a vertical mill then end milled the head of the screw off ,he pulled the head off leaving the threaded remains wich was a lot easier to remove, that worked for him, but I would not be positive that it would work in all instances.
Latest blog entry: For motor builders
you got that right ,the only problem on some of those other uses the chuck arbor can come loose
| Thread Tools | |
| Diesel Engines | Aeromister | Engines | 8 | Sep 01, 2009 07:17 AM |
| Discussion Need help with two diesel engines ! | cosmin | Engines | 3 | Feb 17, 2005 05:27 PM |
| WTB-Model Diesel Fuel | slogo | Aircraft - Fuel - Airplanes (FS/W) | 3 | Nov 13, 2004 09:42 PM |
| scale model of engines | dw1122 | Life, The Universe, and Politics | 2 | Apr 23, 2004 05:43 AM |
| diesel engines | wyflyer_55 | Fuel Plane Talk | 7 | Apr 22, 2002 02:45 AM |
