| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
Smelly cantankerous things, old druids used to mount them on stands and run them at the field just to prove that they could. I had a couple of McCoys that used to vaporize the teflon contra piston o-rings. That burrrrp,burrrrp sound was kind of reminiscent of rotary engines though. You really need three hands to start them. Just kidding!!!
#47 | |
Go here for a discussion on this problem: http://www.rcuniverse.com/forum/m_35...tm.htm#3555861 Last edited by JMP_blackfoot; May 29, 2009 at 02:22 AM. |
#48 |
Quality, Czech style
MP Jets are (were, they are not made any more, alas) really high quality engines, and they perform as well as they look.
The Ball bearing 1cc was given to me with a broken crankshaft. I was lucky to find a spare at Carlson Engines (I think he may still have the glow version in stock). Too bad I can't seem to find a spare R/C carburettor or two for these engines... The 0,6cc Letmo reproduction is also a nice engine, although this one, which is true to the original, is not so easy to mount in a model. The "classic" version with side lugs is much easier in that respect. Runs and behaves very well, though. These MP Jets are a real pleasure to handle, to look at and to actually run and use. Last edited by JMP_blackfoot; May 29, 2009 at 02:06 AM. |
#49 |
Quality, Japanese style
This Enya 25 Diesel may be the best quality engine in my collection. It is destined to a very special model I hope to find time to build one day. It absolutely oozes quality and perfection in manufacturing. I haven't dared run it yet.
Find a report here : http://www.modelflight.com.au/manual..._SS_Diesel.pdf Last edited by JMP_blackfoot; May 29, 2009 at 01:51 AM. |
#50 |
Barry Try a piece of tube to make an addapter coller to match each dont damage either part
......... at a push silicon joiner pipe might work??? In stock form the little blighter just picks up its skirts and howls in a most sporting FSR fashion for its size, and will tick over just got to get the interface right Clive if you come up with the right combo/part Id love to see it in action. Last edited by Airboatflyingshp; May 29, 2009 at 07:33 AM. |
#51 |
Blackfoot my mate tells me that enya now produce a 4stroke deisel anyone had their mitts on one?
Pics should have gone on prev post oops
#52 |
I have an Enya .41 four stroke diesel. What looks like a glow plug is just a dummy plug with no element. Also an Enya .25 two stroke diesel. I have added a tommy bar and locking lever for compression adjustment to the .25 engine. Both well made engines. Just wish the four stroke had a compression adjustment. Jack
#53 |
Barry,
I used a CS 061 R/C carby on my Mk17, they can be gotton from B&L Hobbies. And some of my other diesels, The PB .33 R/C is a true example of a craftsman at work an excellent engine with first class fits and finish no compromises,next is an MPJet 061 R/C ballraced , MPJet .040ci Classic. Bottom row is 1.3cc Indian Mills R/C , McCoy 049 , JENNA 1cc twin ballraced with front side port induction . |
#54 |
Jack just a wild card idea but could adjustment not be achieved via cap screw in the place of the dummy Plug? My davies diesel head uses that set up instead of a Tommy bay ................... or are you too attached to your fingers? You would need to make up a special angle Allen key and contra piston that would allow for the sliding contact push pull......... easier to start with a new head probably.
#55 | |
I have removed the spring starters, as I think they disturb the true look of the engines...and I have no use for them. I did save the parts though. The Merlin is so far my favourite. A very sweet running engine, and its size and weight is perfect for all those small "Vic Smeedish" models, originally designed for the Mills 75. This example was used in a "Mini-Eros" for a while. Eventually I gave it away, luckily keeping the engine... I regret I only purchased one Merlin, as there were several available from a Swedish importer in the early 80's.... Note that the Spitfire outweighs the Sabre by 2 grams, due to the thicker liner....a less practical 1 cc - if you don't need the nose weight... On the air intake of the Rapier, above the spraybar, is an "extra" hole...."provision for an extra spraybar"...hmm...for what...? A nice and colourful group of engines, reminding of past golden years...making me recall those full-page ads in the magazines, late 50's - early 60's, etched into my mind... ...I hope to use them all, sooner and later, seeing that beautiful anodising fade in a gentle and natural way...
#56 |
50 years old and still brand new
Gluehand,
Nice pictures of great little engines. They all look brand new! The info on the instructions also shows the early prices...I guess we all should have saved up more as kids. But then that was still a lot of money back then."On the air intake of the Rapier, above the spraybar, is an "extra" hole...."provision for an extra spraybar"...hmm...for what...?" I had a K&B .15 with 2 needles, spray bars, one above the other. It gave a 2 speed engine, the second spray bar giving more fuel and a rich run. Not very good, but a high and lower speed setting. Had too pinch the second fuel line for "high". Perhaps the start of an early throttle, could be the same on yours. |
#57 |
On the subject of colourful little jews of motors am I correct to mention the name Taifun.........if Ive got the spelling correct?
http://www.model-aero-engines.com/st...s,Motor,Motors) http://www.ronald-valentine-engines.com/ Caught my interest seaching to check my memory
#58 | |
Great Ideal that I should have already considered. I was not going to butcher the rear engine plate by modification for fit anyways. The russian vendors selling parts engines would have sold me a spare plate for this approach. They seem to have no current activity on the ebay diesel listings unfortunatly. As everyone should be aware prices have escallated nicely in the last year on ebay for model diesels. There must be thousands of these engines new in boxes still in Russia. I had heard reasonable things about the mk 17 over time as well. They were 20.00 new on ebay for quite awhile. I should have grabbed a few more. That hind sight thing again. It is reputed the earlier ones in the larger plastic boxes are superior to the later production versions in the smaller boxes. My earlier version came with a green prop, venturi size change sleeve and a few other things. It is also a decent looking engine and not too poorly finished. Especially compared to many soviet diesels. If it had an exhaust collector it would have been mounted on a plane by now. I guess I could make one of them as well come to think of it. My thanks by the way. You have reinforced my belief it might carb well. I will just have to retire from my constantly ever busier retirement to get some of these projects done I guess. |
#59 |
Ahh Clive, thanks for bringing up Taifun, my first ever engine was a Taifun Hurrikan, a Christmes present from my parents (beat the hell out of a pair of sox!).
Built Ron Moultons C/L Rascal for it and learnt to fly C/L on it at the local park. Happy days. Have recently built another Rascal for a PAW 149 but am yet to maiden it. |
#60 |
Light and floaty does it
I still have a DC Sabre. It was the nicest starting, easiest handling, most docile and controllable model engine I ever had. a complete joy. I haven't run it for 33 years.
| Thread Tools | |
| Diesel Engines | Aeromister | Engines | 8 | Sep 01, 2009 08:17 AM |
| News Need help with two diesel engines ! | cosmin | Engines | 3 | Feb 17, 2005 06:27 PM |
| WTB-Model Diesel Fuel | slogo | Aircraft - Fuel - Airplanes (FS/W) | 3 | Nov 13, 2004 10:42 PM |
| scale model of engines | dw1122 | Life, The Universe, and Politics | 2 | Apr 23, 2004 06:43 AM |
| diesel engines | wyflyer_55 | Fuel Plane Talk | 7 | Apr 22, 2002 03:45 AM |
