Old Dec 04, 2009, 07:32 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Originally Posted by Gluehand View Post
1. The diesel incident:
When bench running a Super Tigre G15RV diesel, I tried a home made silencer, which was badly designed, in the way that it allowed the accumulated burnt goo to run back into the engine, after it had stopped.
This is actually a well known problem with muffled diesels. The corrosion is caused by ignition improvers in the fuel. The nitrates produce acids that if aren't removed will cause damage. A muffler tends to collect oil and you experienced the result first hand.
http://www.eifflaender.com/instruct.htm
Look at #15. They recommend this to allow the engine to ventilate.
I've never seen an engine damaged by castor. In fact the best ones to buy off ebay are the ones covered in castor. I picked up an atrocious looking FS-40S that was said to have low time. It went cheap. After washing the castor out it was essentially new.
Are there and MPJet .061 users out there? I have a couple but haven't used them. We ran up a friend's engine last week and man did that howl. it's the loudest diesel I've ever experienced. of course it was propabaly turning 18-19kRPM with a small prop on it.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Dec 04, 2009, 08:09 AM
Gluehand is offline
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
That's a fair suggestion Greg, BUT I didn't use any ignition improver at all ...so as I see it, the spotlight is still on that kerosene...()
I'll sign on that ! I bought (unseen & very cheap) an OS FS60 open rocker, and received it as a brown lump in a plastic bag....after some treatment it was like new...and additionally, it turned out to be the early version with alloy rockers + machined head & carb...
Gluehand is offline Find More Posts by Gluehand
Old Dec 04, 2009, 03:31 PM
Warren B is offline
Find More Posts by Warren B
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
Hi Greg,
I have one of the MP Jet 061 BB's , just starting to build a 70's aerobatic design for it (I chickened out on a flat-out racer). Bench running is very impressive on a 7x4, I expect it will be ballistic on something smaller. I am not too horrified by the noise, the muffler seems to work OK (maybe it was because I had just been playing with a Russian KMD - boy is that loud!).
Warren B is offline Find More Posts by Warren B
Old Dec 04, 2009, 08:22 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Cleaning up the old burned on oil residue can be done by soaking the engine in a container of diesel truck engine oil high in detergents. As Chas mentioned, a heat gun can help.
If you are in no rush, leave the engine to soak for a few months.
I use car engine oil (DG, MM, designations) as “after run oil”. It’s cheap and keeps everything free.
JohnAV8R is offline Find More Posts by JohnAV8R
Old Dec 04, 2009, 08:30 PM
JohnAV8R is offline
Joined Oct 2005
Parra 2.5 diesel
PARRA 2.5 diesel
The specs on this engine are better than the ETA.
Just maybe, it might be best to leave the muffler off it. All the above notes point to Corrosion .
See what fuel is used.
http://www.clubtamaran.com/INSTRUCCI...20D%20ingl.pdf
* Displacement 2,49 cc *Power 0,45 hp/ 18.000 rpm *Weight 160 gr
The new PARRA 2.5 diesel engine was designed for all aeromodellers who love diesel engines.
RUNNING IN
The engine is accurately fitted and adjusted at the factory, so it requires a relatively short running-in period of about 3 to 5 runs of 5 minutes each, allowing it to cool down between runs.
The recommended mix is: 20% Castor Oil, 33% Diethyl Ether, 45.2% Kerosene and 1.8% Ethyl Nitrate or DII.
FIRST FLIGHTS
It is very important to not overwork or force the engine during initial flights. Set compression to avoid darkened exhaust oil colour. Never black! Darkened exhaust oil indicates overcompressed condition, which generates excess heat and load on the parts.
Old Dec 05, 2009, 09:50 AM
JohnAV8R is offline
Joined Oct 2005
“Has anyone here ordered one of those Indian Mills that was mentioned a few weeks back? If so, what is it like? “
Tag1260, that was on another thread.
Check out post #442 for sale, and
#472, Chas seems happy. Ask him.
Lastly, post #475. Here's the replica, and under a $100 US. My email contact was great. The service was excellent. Contact Gao Guo Jun at
csmodels@citiz.net
This little replica is no “slag” engine. It appears to be well made.
Replica engines are just that.
See post # 530 from Chas. The Mills used a special process to treat the metal resulting in a 400 hour life expectancy, kind of like a little Rolls.
I guess it all comes down to what you want or need. For a collection to look at, for a collection to say, “I have an original”, or just to have!
If you want to fly with the engine, and you want it to run well, be easy to start, and give good service, only you can make the choice.
Look at “JETT” engines. There’s quality there; too bad they don’t offer a diesel.
Old Dec 05, 2009, 10:34 AM
JackHiner is online now
Find More Posts by JackHiner
JackHiner's Avatar
Joined Jan 2005
I have had problems with Mills 1.3 cc needle valves holding a setting. So I modified some other brand carbs that hold needle valve settings great. Someone suggested I taper the Mills needle valve and that might improve the stock needle valve performance. Jack
JackHiner is online now Find More Posts by JackHiner
Old Dec 05, 2009, 08:45 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Originally Posted by JohnAV8R View Post
PARRA 2.5 diesel
I'm waiting for the AAC RC version to be released. I just might have to buy one. I'll run a muffler. I ran a muffled MVVS 2.5 when I first started RC and never had trouble.
Greg
Old Dec 05, 2009, 08:52 PM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
This isn't my engine, but this picture from eBay is as good as I would take. It was giving to me and is really nothing more than a curiosity. Particularly with respect to its provenance.
The labeling is conflicting and I can't tell if it was made in East Germany or West Germany
RyanNX211 is offline Find More Posts by RyanNX211
Old Dec 06, 2009, 05:02 AM
Dieter Doerr is offline
Find More Posts by Dieter Doerr
Stuttgart, Germany
Joined May 2001
I have one of these WEBRA Record 1,5 diesel engine.
At your picture, because of the shape of the cylinder head, I think it is more like a WEBRA-Winner 2,5 ccm from approximate 1956 or later.
(But the displacement must shown on the chrankcase as 1.5 or 2.5 !)
My one, shown on my pictures is a WEBRA-Record 1,5 ccm also from approx. 1956.
The cylinder head is more round and red anodized.
Manufacturer and distributor was:
WEBRA-Fein-Modelltechnik, Berlin
Made in Germany
(which means West Germany)
The name WEBRA comes from the two company`s founder
Walter WEichler and Martin BRAgenitz (WE-BRA) back on 1949.
Dieter Doerr is offline Find More Posts by Dieter Doerr
Old Dec 06, 2009, 05:23 AM
Stuttgart, Germany
Joined May 2001
Very comparable to your picture is my ED-1,5 diesel.
He is, let me say a "WEBRA clone"
Old Dec 06, 2009, 07:01 AM
Thermals, Tom
RyanNX211's Avatar
Joined Dec 2007
Made in Germany
Interesting, I had always thought that stuff made in the Federal Republic was stamped: W.Germany whereas things manufactured in the DDR was stamped: Germany.
Is this address in West Berlin?
Old Dec 06, 2009, 07:21 AM
Gluehand is offline
Gluehand's Avatar
Joined Sep 2008
A rough Webra Record history
Hello,
Basically, there were 3 versions of the popular Webra Record.
Ryan's photo shows the later of them.
Dieter's engine is the "59-64" version.
Old Dec 06, 2009, 07:39 AM
John Moore is offline
Find More Posts by John Moore
John Moore's Avatar
Southern Spain
Joined Nov 2003
Dremo 0.5cc diesel
Another small diesel from Germany
John Moore is offline Find More Posts by John Moore
Old Dec 06, 2009, 07:57 AM
Gluehand is offline
Gluehand's Avatar
Joined Sep 2008
Dieter, this engine is the German made "ED HAWK".
Quote from "The Ed Story":
"The thing that will surprise most modelers familiar with previous ED products is the legend "Made in W. Germany" cast into the crankcase. The Hawk is, in fact, made in Germany to E.D.'s specifications and those modelers familiar with the products of Messrs. Fein und Modell Technik of West Berlin, will not be long in recognizing the obvious relationship with Webra engines".
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
