Old Feb 03, 2013, 06:01 AM
Geoff Potter is offline
Find More Posts by Geoff Potter
Joined Sep 2011
Must be a million model engineer guys in the USA that would make one for you if you have one to copy surely . Geoff.
Geoff Potter is offline Find More Posts by Geoff Potter
Old Feb 03, 2013, 01:29 PM
kakariki is online now
Find More Posts by kakariki
Newbee
Mornington Vic
Joined Mar 2010
What's This Please?
Hi All
Can anyone please confirm what this engine is on E-Bay.
Thanks BB
http://www.ebay.com/itm/148A-Taplin-...item257a7ee33a
kakariki is online now Find More Posts by kakariki
Old Feb 03, 2013, 02:55 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Thanks for posting.
marine diesel looks interesting with the large fly wheel and water jacket.
JohnAV8R is offline Find More Posts by JohnAV8R
Old Feb 03, 2013, 02:58 PM
brokenenglish is online now
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Originally Posted by kakariki View Post
Hi All
Thanks BB
Yes, without any doubt, it's a watercooled ED Comp Special, 2 cc.
brokenenglish is online now Find More Posts by brokenenglish
Old Feb 04, 2013, 03:32 AM
Newbee
Mornington Vic
Joined Mar 2010
re Taplin
Thanks for that info.
BB
Old Feb 05, 2013, 10:32 PM
JohnAV8R is offline
Joined Oct 2005
PAW "80", a 0.8 cc diesel
The PAW .8 cc, is a small diesel, especially when compared to a 10 cc diesel. Again thanks to Bill. I haven't had a chance to run this one, but it appears to be well made, "tough", and has lots of compression.
Best of all, they are still available.
John
Old Feb 06, 2013, 02:57 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
Originally Posted by JackHiner View Post
I have an Enya .41 four stroke diesel. Just wish the four stroke had a compression adjustment. Jack
Aside from using a sleeve valve like a full scale Bristol Hercules, how are you going to vary combustion chamber volume?
GeoffinIN is offline Find More Posts by GeoffinIN
Old Feb 06, 2013, 03:21 PM
Joined Nov 2011
Geoff and Jack, we've been through all this before. The Enya has a dummy plug (screwed into the glowplug hole) that allows slight compression adjustment (by adding or removing washers I suppose), but not while running of course.
Apparently this is sufficient and they are said to run well. In fact, they run as a "fixed compression diesel", but ultra-rugged construction allows very high compression, so that "normal" (variable compression) fuels can be used, and running is less affected by ambient air temperature (than in the case of a fixed compression diesel).
A thing called a "diesel gadget" was also marketed some time ago, to allow other glow engines to run using the same principle (a dummy plug that can slightly vary compression).
Geoff, the Laser .75 fourstroke diesel does actually have a small contra-piston. The two valves leave sufficient surface area in the combustion chamber to accomodate an orifice in which a small contra piston can be operated by a normal compression screw.
Geoff, a little more than 50 years ago, I spent a year or two being dragged around the world by a couple of Bristol Hercules, and later even by four Centaurus.
Brian
Old Feb 08, 2013, 08:25 AM
JohnAV8R is offline
Joined Oct 2005
Avro triplane and Cox 049 diesel
This posting from Steve (mlbco) is worth a look: it uses a small Cox 049 diesel, and it provides a video of a scale model being flown with it. The sound of the little diesel really matches well with this triplane.
http://www.rcgroups.com/forums/showthread.php?t=1583373
RN Models Avro Triplane Mk IV
Thanks Steve.
Old Feb 08, 2013, 08:34 AM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Looks very much like it's cousin.....beautiful looking engines, one diesel, one on gas.
Bill
williame3590 is offline Find More Posts by williame3590
Old Feb 08, 2013, 11:37 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Brian
Pictures of the engine the last one shows the dummy plug.
Reginald is online now Find More Posts by Reginald
Old Feb 08, 2013, 07:39 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Sorry to have dragged up old stuff. Where is the rocker cover on the Enya? My only Enya 4 stroke is a glow .53, and it has a cover. Does the diesel have too much blow-by to allow a cover to be used?
Re the Cox in the Avro triplane: I note that it uses the double slit exhaust ports. No wonder it has no power!
Old Feb 08, 2013, 09:28 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
For some reason Enya leaves the rocker cover off. It is supposed to be in the box though. I don't remember reading anything in the instructions about why they didn't put the cover on either.
Now in place of the glow plug there is just enough room for a Lenova Energy Cell to be put in. But you may have to stop the engine to adjust it though, as it will be close to the prop.
Cox had to come out with the narrow double slit exhaust ports to arrest sparks so the engines don't set off fires. There were some government regulations about it in the later years.
earlwb is offline Find More Posts by earlwb
Old Feb 09, 2013, 12:18 AM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
If its marked mkIII, it would be an E.D. MkIII. 2.49cc rather than a comp. special. but the intake is at the rear like a comp. special, go figure..
kkphantom is offline Find More Posts by kkphantom
Old Feb 09, 2013, 03:09 AM
Joined Nov 2011
OK, one day I'll go through all the Mk IIs, Comp Specials and Mk IIIs on this thread.
First of all, many Comp Specials exist with the front housing marked "Mk II", there are also many with the housing marked "Mk III", and there are also a lot where the "Mk III" in the casting has been crudely modified to "Mk II", i.e. they filed off the last "I"!
Concerning the Mk III 2.49 side-port, the real problem is that it was never really a "production" engine. The few that were made have significant differences (particularly concerning the carb/tank/fuel cutout), and there just aren't enough of them around to be able to establish what should be "normal".
We can discuss this further if anyone is interested...
Now, concerning the engine on eBay, the definite giveaway is the serial number "WM 1978 C". The "C" indicates that it's a Comp Special. The "W" means that it actually left the factory as a boat engine (so it's probably entirely original - good!) and, as is well-known, "M 1978" means that it's the 197th engine made in December 48.
Finally, "just for a smile" and concerning the 2.49 side-port... Those of you who possess Mike Clanford's book could have a look at the 2.49 side-port... and have a look at the (visible) serial number. The S/N ends with a "C"! Thus, IMHO, the engine has a "genuine" top end, that's been assembled on a Comp Special crankcase...
As the French say... "Ce n'est pas une science exacte..."
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
