Old Dec 22, 2012, 01:27 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Scaledown, sorry to hear that the FOK is not co-operating. No popping, no suction. For fuel suction try: thumb over the venture, get an air bubble in the fuel line, flip the prop. Does the air bubble move? If not, then possibly an air leak at the seal on the rear cover (which was ok before you removed it?), or the piston/cylinder taper is too loose at the bottom as you have suggested.
To get a “pop”, prime the engine with fuel, then add a drop of 30W oil into the exhaust area. The oil will help with the seal for one or two pops before it is burnt out.
Page 237 post #3701 has a review for the FOK25.
The Taifun Hurrikan is a very nice diesel. I’ve always liked them since I first saw one in my LHS (early 1960s). Post #3730 shows what appears to be a home made twin.
An R/C carb for the 1.5, the Parra Wasp uses an Enya carb, post # 3836.
Shown also in post #3836 is the Cox .09 for comparison. There was also an RC version that used an air bleed carb.
JohnAV8R is offline Find More Posts by JohnAV8R
Old Dec 26, 2012, 06:44 PM
G WILLIE is offline
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
WOHM Diesel
Reggie, Did you ever take your WOHM apart? My wife got me one for Christmas. I'm curious to see inside.
G WILLIE is offline Find More Posts by G WILLIE
Old Dec 28, 2012, 05:47 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
No way. That engine was run-in by the maker and with diesels it is better not to unscrew things when the engine is set up properly. The only thing I did replace are the lockable set screws that you can obtain from that same maker, forgot his name right now......
Reginald is offline Find More Posts by Reginald
Old Dec 28, 2012, 08:48 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I haven't looked inside of my WOHM engine either. I would only do it if I had to because of a problem of some sort.
earlwb is online now Find More Posts by earlwb
Old Dec 28, 2012, 09:11 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
A side comment, the TD 09 is a 50 year old design, and still a standard for comparison for high power 1.5cc engines. I wonder, 50 years from now, what engine new today will be the standard for comparison? Maybe we will still use the TD 09.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Dec 30, 2012, 04:01 PM
pch is offline
pch
Find More Posts by pch
pch
Joined Aug 2010
Fok 15
Scaledown, I have samples of the FOK 10, FOK 15 & FOK 25. They came to me as a box of spares & faulty returns from when Ripmax, the UK importers, stopped supporting them.
I only managed to get one FOK 10 complete & running, but this is a delightful sport engine easy to start and runs very reliably. It was regularly used in a reduced size F/F Rambler, trimmed properly for a near vertical climb then that slow circling glide.
I made up a couple of FOK 15s, these are lightly made engines that like to rev, probably not much down on power to my PAW 1.49s and usually power my C/L Jasco Tracer, but they are a little fragile.
There were lots of FOK 25 bits in the box, so I assume they had more returns of this size. I spent quite a lot of time selecting the cleanest ones and then lapping the piston/liner till I could get them running. IIRC much of the lapping was done with toothpaste. The 25 was not my favourite engine, a bit of a slogger, so most were sold on.
..................Paul Harrison
pch is offline Find More Posts by pch
Old Dec 30, 2012, 04:50 PM
Gluehand is offline
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
This FOK 15 (1.5 cc) was manufactured for Engel Modellbau in Germany, who sold it as "Engel Rebell", designation cast into the crankcase.
My example is pretty much used, but still in good condition, with a nice "bouncy" feel when flipping the prop.
This is a late version with a single R/H exhaust port (in order to simplify manufacure of an exhaust collector/silencer).
I have yet to find some use for it though...I've been thinking of putting it in a power pod for a glider eventually...it's too good to sit in a drawer....
Gluehand is offline Find More Posts by Gluehand
Old Dec 30, 2012, 11:30 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I could see that standard moving to some other 1.5cc engine. But it is hard to choose something else. Cox simply made so many of the things. Cox very likely made more .09 engines than all the other engine companies did combined. So it is hard to beat those production numbers. it just makes that engine one of the most common ones to see and use.
I would probably choose the Parra 1.5cc engine as a new bench standard to compare to. But some other ones would be good candidates too.
Old Dec 31, 2012, 02:55 AM
greggles47 is offline
Find More Posts by greggles47
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
You Americans will continue to love the TD's but in terms of sheer performance the Oliver Cub would be a far better motor. But again it's not comparing like with like. The Cub was a TBR diesel and could swing a very wide range of props. In 1/2A Team Racing it was unbeatable for many years.
Regards
Greg
greggles47 is offline Find More Posts by greggles47
Old Dec 31, 2012, 03:59 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Exact production numbers were published in MAN or Flying Magazine years ago, I seem to remember a total production of over 32 million engines ! Imagine shoveling that amount into your basement.
Old Dec 31, 2012, 05:59 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
I've got an Engel Rebell 1cc which starts well and produces plenty of power. I had expected my 1.5 to be good also.
Did FOK produce Engel or did Engel produce FOK?
Scaledown is offline Find More Posts by Scaledown
Old Dec 31, 2012, 06:49 AM
hastf1b is offline
Find More Posts by hastf1b
F1B is ok.
Monheim am Rhein Germany
Joined Jul 2008
Alexander Engel was/is only a dealer. (Brochure of 1958.)
Heinz
hastf1b is offline Find More Posts by hastf1b
Old Dec 31, 2012, 08:56 AM
Gluehand is offline
Gluehand's Avatar
Joined Sep 2008
Aah...the tiny 0.25 cc VT-11 is a real beauty....and very rare....
The Hungarian ALAG, VT, FOK etc, belong to a huge engine family, connected to the AKKÜ Company, the Vella Brothers a.s.o...
An interesting history lesson by Adrian Duncan is to be found HERE
Also, HERE is a site, showing several members of the actual family tree, mixed with other fascinating, rarely seen engines.....
Old Dec 31, 2012, 09:01 AM
JohnAV8R is offline
Joined Oct 2005
Hastf1b, what is/was a DM in exchange for $ 1 US?
About 1959 a Cox Olympic .15 was $12.95
to-day's Foreign Exchange Rates
Our rates as of: Mon Dec 31 09:50:00 EST 2012
Client Buys
(Pays
Canadian)
Client Sells
(Receives
Canadian)
Non-Cash Transactions
US DOLLARS 1.0218 0.969
CANADIAN DOLLARS 1 1
US BORDERLESS PLAN 1.0112 0.9796
POUND STERLING 1.6633 1.5703
AUSTRALIA DOLLAR 1.0631 1.0033
BARBADOS DOLLAR 0.5303 N/A
CZECH KORUNA 0.0552 N/A
DANISH KRONER 0.1849 0.1679
E CARIBBEAN DOLL 0.3954 N/A
EURO 1.3566 1.2756
HONG KONG DOLLAR 0.1327 0.1241
INDIAN RUPEE 0.0188 N/A
JAPANESE YEN 0.011902 0.011154
MEXICAN PESO 0.0819 N/A
NEW ZEALAND 0.8419 0.7959
NORWEGIAN KRONE 0.1863 0.1718
PAKISTAN RUPEE 0.0113 N/A
PHILIPPINES PESO 0.0249 N/A
SAUDI RIYAL 0.2814 0.2494
SINGAPORE DOLLAR 0.8436 0.7866
S. AFRICAN RAND 0.1266 N/A
SWEDISH KRONA 0.158 0.1484
SWISS FRANC 1.1213 1.0593
U.A.E DIRHAM 0.2845 N/A
POLISH ZLOTY 0.3437 N/A
HUNGARIAN FORINT 0.004848 N/A
Old Dec 31, 2012, 09:03 AM
JohnAV8R is offline
Joined Oct 2005
Gluehand, nice collection.
The "Red Head" glow in the back almost looks like the McCoy RV racing engines.
John
Diesel Engines Aeromister Engines 15 Aug 23, 2016 09:57 AM
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
