What a terrible thing to do...
![]() ![]() ![]() ...please don't...!As I'm in the middle of gasket making right now - using THIS PRIMITIVE METHOD - it would be a pleasure to make a few for you, of various thickness to try out.... Please PM your address + required inner and outer dia, and I'll send you a couple of cylinder base gaskets......costs nothing...!
Another suggestion if the parts are super clean make thin washer that is a tight fit over the shaft from a plastic bag push into place using the washer and prop collar then remove, this will stop any adhesive getting into the shaft bearing, use some loctite 480 black max wich is a high strength high temp adhesive to glue the prop collar on .clean up any excess straight away with a cotton bud and acetone, leave overnight then pull out the plastic bag washer. If ever you need to remove it you can use a butane torch . over the years I have done many repairs using this product good to have on hand
. but not literally .
Latest blog entry: For motor builders
Getting back to my Snipe problem - she's all fixed.
Everybody was correct. I had leaks around the needle valve, the cylinder seat and the backplate. It leaked like a sieve in fact. Gluehand's gasket fixed the cylinder seat, rubber washers around the needle valve and a home make gasket for the backplate fixed the rest. It really hammers now. I got 300 more rpm than my PAW 1.5 on the same prop.
Ancaster, Ontario, Canada
Joined Oct 2005
For those interested in model diesel engines, the following are listed as nib.
DA David Anderson Drabant .25 Diesel RC model airplane hobby engine in box Rare http://cgi.ebay.ca/ws/eBayISAPI.dll?...E:B:SS:CA:1123 seller also lists Taifun Hobby .098 ccm Diesel Model Airplane Engine made in Germany Vintage Taipan Australian Model Aircraft Engine RC 2.5 cc Diesel with box. Taifun Zyklon Multispeed 2.5 ccm Diesel Vintage RC model engine with box |
| Thread Tools | |
| Diesel Engines | Aeromister | Engines | 8 | Sep 01, 2009 07:17 AM |
| Discussion Need help with two diesel engines ! | cosmin | Engines | 3 | Feb 17, 2005 05:27 PM |
| WTB-Model Diesel Fuel | slogo | Aircraft - Fuel - Airplanes (FS/W) | 3 | Nov 13, 2004 09:42 PM |
| scale model of engines | dw1122 | Life, The Universe, and Politics | 2 | Apr 23, 2004 05:43 AM |
| diesel engines | wyflyer_55 | Fuel Plane Talk | 7 | Apr 22, 2002 02:45 AM |
