Old Oct 26, 2012, 03:19 PM
Frog 50 is offline
Find More Posts by Frog 50
United Kingdom, London
Joined Apr 2012
Ivan Prior of I.P. Engineering made about 10 to 12 Majesco Mites in the late 1980s.
The original Majesco Mites were pressure/gravity die-cast-so you can see the tooling seams.
The I.P.Eng. engines were sand cast(very,very well done) so, no tooling seams.
Hope this helps.
Frog 50 is offline Find More Posts by Frog 50
Old Oct 26, 2012, 03:27 PM
brokenenglish is offline
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Originally Posted by Gluehand View Post
On auction now.....not named.
To me it looks like a Micron 5 cc.... (?)
http://www.tradera.com/gammal-diesel...2065_167138730
Yes Bosse, that looks like a Micron 5. It's one of the last ones of the main production run, i.e. not counting the short collectors' run in the mid-seventies.
This engine looks original and the main run engines can all be very roughly dated by their heads (3 different types).
The last head type used was this one, it's a cast head anodised red. You don't see many like this, but I think Reggie has one.
After this, the collectors' run engine has the same cast head, but not anodised.
brokenenglish is offline Find More Posts by brokenenglish
Old Oct 26, 2012, 03:47 PM
Gluehand is offline
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Thanks Brian..! These engines rarely turn up in Sweden.
I won't bid though, as I collect engines in a 'mild' way nowadays......trying to focus on 'existing projects'.....
Here is another one on auction...this was totally unknown to me.....
http://www.tradera.com/1-49cc-racer-...2065_167139946
Gluehand is offline Find More Posts by Gluehand
Old Oct 26, 2012, 04:14 PM
Gluehand is offline
Gluehand's Avatar
Joined Sep 2008
More from the same seller.....two Taipan Tyros....
http://www.tradera.com/diesel-motor-...2065_167139597
...both unusual over here....
Old Oct 26, 2012, 06:06 PM
G WILLIE is online now
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
How could I bid on this from USA?
G WILLIE is online now Find More Posts by G WILLIE
Old Oct 26, 2012, 07:51 PM
locktite401 is offline
Find More Posts by locktite401
Joined Nov 2008
Duplicate ...
locktite401 is offline Find More Posts by locktite401
Old Oct 26, 2012, 07:56 PM
Joined Nov 2008
Interesting problem, it seems that the seller will deal with overseas clients and Google Translate works well on the Auction site.
The Google Chrome browser can do an automatic translate as well as you browse. This should make the sign up simple.
http://translate.google.com/translat...139946&act=url
It seems to be a Swedish licensed version of Ebay and you just need a verified Paypal a/c to become an international member..
Ray
Old Oct 27, 2012, 12:28 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
You do mean this one ? The smaller one is made by Michel Moliniť from Paris.
Reginald is offline Find More Posts by Reginald
Old Oct 27, 2012, 01:12 AM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
FROG 50D Mks. 1 and 2
Way back, starting on page 222 (post # 3323 by Gluehand) we started discussing the various marks of FROG 50's. I contended that mine was a 50D Mk. II, whilst Brian thought it to be a Mk. III. Was browsing through Mike Clanford's engine book (known to contain quite a few errors) and I think I know now where the confusion all started. Clanford shows a Mk. I, a Mk. II and a Mk. III FROG 50 Diesel. It would seem Brian, that Gluehand was entirely correct in stating that he had 2 Mk. I's, an early one and a late one. Clanford has made the mistake of listing these two variants of the Mk. I as a Mk. I and a Mk. II, thus he had to list the real Mk. II as a Mk. III, which I don't think ever existed. This is borne out by reading Chinn's Engine Test which is posted back there as well. Over to you Brian !
Twin-Stack is offline Find More Posts by Twin-Stack
Old Oct 27, 2012, 02:52 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
links not working .
olmod is offline Find More Posts by olmod
Old Oct 27, 2012, 02:57 AM
Joined Nov 2011
Bill, I ran my mouse over the Micron ad (same seller), and I got a window saying that the seller would only sell in Sweden... Although that could well be just a "default option"
Old Oct 27, 2012, 03:18 AM
Closed Account
Joined Nov 2009
And from the same Swedish site, the rare 1955 Aquila Baby gear-reduction marine (with a slight mix-up with an Enya 19 Model 4002).......
Old Oct 27, 2012, 03:34 AM
Joined Nov 2011
Yeah Bob, Following our early discussions, there's obvious quite a lot of doubt concerning Frog 50 Marks.We really need Richard Dalby, who must know more about Frog engines than anyone else.
However, after thinking a lot about it, I came to the conclusion that Mike Clanford's book is simply dead right.
The external difference between the Mk I and the Mk II is the head.
The Mk I head is smaller and has fins "right down to the bottom", whereas the larger Mk II head has a plain unfinned section at the bottom (which was continued on the Mk III).
Then, the Mk III has the different crankcase (needle sweepback and strap).
So, to keep it simple, only the Mk I has fins right down to the bottom of the head. Then, the Mk II has a slightly bigger head with the plain unfinned ring at the bottom and, finally, the Mk III retains the Mk II head but with the strap under the case and swept-back needle.
I'm reproducing GH's photo, which shows a Mk I head on the left (ignore the ED Baby comp screw!), and a Mk II head on the right.
Bob, your engine is a Mk III (one of the great things about living down under is that it prevents any possibility of thinking that the world is flat!)
Phew!
Old Oct 27, 2012, 04:10 AM
Closed Account
Joined Nov 2009
Phew!
Brian, please read Chinn's Engine Test closely - the FROG 50 Mk. III never existed !
Old Oct 27, 2012, 04:31 AM
Closed Account
Joined Nov 2009
Brian, please also read this closely -
http://modelenginenews.org/ad/frog_unter.html
(Quote) "This relatively minor variant has sometimes been referred to as the Frog 50 Mk II, with the following model referred to as the Mk III. However, neither the factory nor contemporary reviewers ever applied such designations—both the first and second variants of the Frog 50 were designated as Mk I's."
Diesel Engines Aeromister Engines 15 Aug 23, 2016 09:57 AM
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
