Old Oct 23, 2012, 05:33 AM
mchandrayan is offline
Find More Posts by mchandrayan
Chennai, Tamil Nadu, India
Joined Sep 2003
Even my take was that the all painted engine looks like some one dipped an Indian made (K) engine in a paint tin and made some parts
mchandrayan is offline Find More Posts by mchandrayan
Old Oct 23, 2012, 06:05 AM
gossie is offline
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
My first reaction was it's a German Jaguar when I saw the black head, but no it's not that elsewhere.
gossie is offline Find More Posts by gossie
Old Oct 23, 2012, 07:14 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Wohm
Use of the 3-cylinder Wohm on a German made biplane.
Reginald is offline Find More Posts by Reginald
Old Oct 23, 2012, 07:15 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Yes get your point but there were no rc carbs on the jaguar 's far as I know.
Old Oct 23, 2012, 07:32 AM
Gluehand is online now
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Any safe bodge on this...?
Hi,
Two of my recently cleaned diesels have slightly, just slightly tight fitting contra pistons. In 'working' order ok, but just a little 'too much' to feel comfortable...
In both cases I noticed this initially, when de-pressing the cp's (under heat), and even when dead clean, with a lot of oil applied, these 2 engines still 'stand out' a little in this matter....
Is there a known safe fix for this...?...reasonably lo-tech, if possible...
The cp's just need to be a tad - or a fraction of a tad - looser, to feel nice.
As I'm aware of how easy it would be to overdo things, I'm presently thinking of a careful polish of the cp under rotation...Autosol...?
I thought I'd put the question out here before I go on...
Gluehand is online now Find More Posts by Gluehand
Old Oct 23, 2012, 07:59 AM
brokenenglish is offline
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Bosse,
Everything has to be low tech for me.
I remove the cylinder and tap the c/p down the bore, from the top, using a hammer and fairly thick dowel (say 1/4"), then turn the cylinder upside down, and tap the c/p right up to the top again, until it's flush with the top of the cylinder (the c/p is probably only tight at the top of the bore anyway).
Just keep repeating this process, usually around 10 or a dozen times, until the c/p fit becomes the way you want.
As you say, I suppose you could use mild abrasive (metal cleaner), but I only use 3in1 and it works OK.
This simple method has always worked for me.
Brian
brokenenglish is offline Find More Posts by brokenenglish
Old Oct 23, 2012, 11:59 AM
Gluehand's Avatar
Joined Sep 2008
Thanks Brian. for those strengthening words...
Yes, I'll first try your recommended "reciprocate" method, then if needed, use some very fine abrasive....
Old Oct 23, 2012, 03:48 PM
fiery is offline
Find More Posts by fiery
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
Gents
M Chandrayan gets the cigar.
The mystery engine is a K-700 ( 7 ccm) by Aurora. A lot of Webra influence in the design. It pre-dates the more recent K-600 and K-650 engines, which have a separate head and exhaust collector ring fitted.
The external finish is rough, but it has smooth bearings and great c/p and p/l fits.
fiery is offline Find More Posts by fiery
Old Oct 23, 2012, 04:00 PM
korup is offline
Find More Posts by korup
Denmark, Nordjylland, Kongerslev
Joined Nov 2005
Hi all
Thanks for an interesting thread !
I wondered if anybody can help me identify this one :
Description:
Description:
Description:
There is nothing written/stamped on it ...
Hope you can help.
Cheers
Allan
korup is offline Find More Posts by korup
Old Oct 23, 2012, 06:20 PM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
"This is a vintage French Dynamic diesel airplane engine marked 2334. It comes in the original box which says Atelier Models with manual for the engine. It also has what looks like a large screw and needle in the box"
(More information required here - Brian, anyone ? )
http://www.ebay.com/itm/Vintage-Dyna...item3ccba414d2
Twin-Stack is offline Find More Posts by Twin-Stack
Old Oct 23, 2012, 09:23 PM
Closed Account
Joined Nov 2009
"This is a very rare Pionyr diesel engine, SN 60115. It has very good compression and turns free. It is a Schnuerle ported diesel, very robust and has very good workmanship. It has never been mounted. There is no muffler or box. This engine was almost unheard of outside of Russia. I received it in the mid 70's from a friend."
Old Oct 23, 2012, 11:53 PM
Joined Nov 2011
Bob, There isn't much more information to give. The ad. text is correct. This is the Dynamic, 1.5cc (blue head). Made in Paris, mid-fifties, by a gentleman called Jacques Cornet. There is a similar engine with a red head called "Le Jet" which is 1cc. The one in the photo just has the fuel needle removed, and what the seller is calling a "large screw" looks to me like it may be a spare spraybar.
I considered bidding, but it's another of these "not outside the US" deals, so I didn't bother. Shame... I don't know what the final selling price was, but the guy would probably have made much more by selling in Europe.
Old Oct 23, 2012, 11:58 PM
Joined Sep 2003
Well! At least I can claim to know my onions as far as Indian made engines are concerned :-)
But not having a bolt on back plate on that one was slightly confusing as most of the K diesels sport the bolt and nut method. Only on the K Mills they came with screw on back plate. But then I have never seen the K 700
Old Oct 24, 2012, 04:56 AM
Closed Account
Joined Nov 2009
Originally Posted by korup View Post
Hi all
Allan
Czechoslovakian ?
Old Oct 24, 2012, 06:03 AM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
This was my third engine, in 1957 or 1958. I had bought the plastic Ready-to-Fly control-line model offered by the firm, complete with Dynamic 1,5 engine, through "La Source des Inventions" in Paris and flew it until worn out from too many crashes. Then the engine went into a Berkeley Helioplane which I also flew control-line. The engine worked alright and gave many flights, but also rapped my fingers more than any other engine I ever had. It was not an easy starter, unlike the Jaguar 2,5 cm3 and the ED Baby 0,46 cm3 I had before it. I did not keep it, but found another one some years ago, complete with the original spinner meant to wrap a string around as a starting help, but missing the piston and conrod, which will be a winter project for the EMCO Unimat lathe when it is set up this winter.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
