Old Oct 12, 2012, 09:41 AM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
While the fit piston to sleeve might be very small , production tolerances are not this tight, for the sake of keeping cost in line. The designer chooses a suitable tolerance on both parts and when you have a loose sleeve, you pick a piston on the high tolerance to mate.
My OTM 0.8 is not in good shape either. It has a tremendous amount of sub piston induction, especially at the rear of the piston where it's trimmed to clear the backplate? The centering of the machined features in the casting looks good. However. There is a crack in the bottom rear of the crankcase from an impact that is no visible in the screwed in backplate. It appears to have happened after machining. I can see light under the front of the cylinder where it should be sitting on the crankcase! The backplate itself looks like it is of much better quality in finish. Honestly, it looks like it was produced on a CNC, it looks like it might be from a Norvel. I just checked and it is. Looks like I was had on this buy. I'm sure it came from Ebay and I usually keep a record, but I'm sure I didn't pay much for it. I didn't inspect it like I usually do when I get an engine. Oh well. Maybe one day I'll see if it runs.
Greg
gkamysz is offline Find More Posts by gkamysz
Latest blog entry: A tiny diesel engine AE 0.1CC
Old Oct 14, 2012, 04:31 PM
Ancaster, Ontario, Canada
Joined Oct 2005
Oliver Tiger Mk V and Mk IV
I've been waiting 2 years for the Mk V, finally got it. The Mk IV, I got in the 1970's (?).
This Mk V diesel feels just as smooth as the older one.
See above recent post, #4182, for link to Tom.
JohnAV8R is offline Find More Posts by JohnAV8R
Old Oct 14, 2012, 06:22 PM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
It looks great John...congrats...!...
Personally I like that, although doubtless beeing a "modern" diesel, the stylish tradition of a "real" T-bar comp.lever is retained..., contrary to many of the newer ones entering the market....
(...am I a conservative old f**t...?)
Gluehand is offline Find More Posts by Gluehand
Old Oct 18, 2012, 05:37 AM
Gluehand's Avatar
Joined Sep 2008
The "gasket-o-matic" :-)
After my recent "engine-cleaning-mania" (which was a healthy thing to do), several engines still live in plastic bags, unassembled, as some odd gaskets are missing here and there..
Particularily older diesels, with screw-on backplates and cylinders, use various circular gaskets and fibre washers....none of them beeing standard dimension...
Pushed by the obvious need, I rigged this device, based on an old bench grinder with a chuck fitted, that I already had. (this machine has been very handy for various purposes.)
As shown on the pics, the "add-on" is a primitive gizmo, and it was easy to make.
It works great..!
Thanks Al, for the "spray-mount-glue" hint...!...making this concept work excellent....
Old Oct 18, 2012, 08:01 AM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
I have used a bench drill in a similar way except the cutter and a centre point are mounted on the bedplate and I use sliding adjustment between the blade and the centre point adjusted with vernier,the centre point has a impression in the cork backing that's glued to the wooden mandrel that's chuck mounted, I made it origonally for making instrument glasses from clear ABS. If I still had it I would have included a pix but it was one of the things I let go.
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Oct 22, 2012, 08:42 PM
Hervey Bay, Queensland, Australia
Joined Mar 2008
What is it?
Let's see who can guess what this is.
fiery is offline Find More Posts by fiery
Old Oct 22, 2012, 09:38 PM
Joined Aug 2004
Webra
Reginald is offline Find More Posts by Reginald
Old Oct 22, 2012, 10:47 PM
Joined Aug 2004
glow or diesel ?
Not sure if this was OS or Saito made ? Dates from the 80'ies. Any help isappeciated
Old Oct 22, 2012, 11:02 PM
I've used O rings from the local hardware store on screw in backplates. Seems to work fine.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Oct 23, 2012, 01:53 AM
Gluehand's Avatar
Joined Sep 2008
No, not Webra....too rough...
Lots of paint + a Taplin-Twin-like comp.lever....er....Indian....?
Old Oct 23, 2012, 03:28 AM
Closed Account
Joined Nov 2009
"You are bidding on a nice little repro of the very,very rare Healy 0.99 c.c. vintage model aircraft diesel engine. This engine is in excellent condition. It has very good compression and very smooth bearings. The mounting lugs are in excellent shape with no washer marks. It is clearly based on an original Amco 87 crankcase, but the rest has been expertly created by a skilled engineer whose identity is not known to me. The original Healy was of course developed into the lovely little Amco 0.87 (See Clanfords book). The engine carries the serial number 2307. It started easily and ran very well when tested."
http://www.ebay.co.uk/itm/Healy-0-99...item3f1dffb5b7
Twin-Stack is offline Find More Posts by Twin-Stack
Old Oct 23, 2012, 03:33 AM
Joined Mar 2007
Those prop nuts are like the ones I made for my mate ... but mine are nicer, 'cos I polished them to a mirror finish and drilled a hole for a tommy-bar.
Not braggin' ...
bogbeagle is offline Find More Posts by bogbeagle
Old Oct 23, 2012, 04:10 AM
Closed Account
Joined Nov 2009
Presenting the "Teapot" Taifun Hobby II.......
Old Oct 23, 2012, 04:36 AM
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Shame the engine doesn't look much like a Healey, especially with the Amco case and the Mills propnut, but I wouldn't mind betting it's a super runner. Be great to fly.
brokenenglish is offline Find More Posts by brokenenglish
Old Oct 23, 2012, 04:47 AM
Joined Nov 2011
Looks like a Russian replica Taipan. Gordon can't have made one that rough...
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
Discussion Need help with two diesel engines ! cosmin Engines 3 Feb 17, 2005 05:27 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
scale model of engines dw1122 Life, The Universe, and Politics 2 Apr 23, 2004 05:43 AM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
