Ancaster, Ontario, Canada
Joined Oct 2005
Note: EB seller has 3 auctions going for similar cans!
A cautionary note…“old” ethyl ether if previously exposed to air may have oxidized to form ether peroxides which could be ignited by the friction in opening the twist off metal cap on the can. Thanks Al for the mention; I’ve sent an email to Aerodyne http://www.freeflightmodels.com/index.html asking if they would ship model diesel fuel to Canada. They also carry dope and diesel engines! Back to RC-throttles- on diesels. Years ago I mounted a Perry carb on my Frog 3.5. I used a small hose section and just forced it over the venture throat on the Frog and pressed the carb onto the other hose end. I looked very rough and strange, but it did work. |
Joined Aug 2004
Mission Impossible...
In the 'meantime', just to keep us alert
, let's wrinkle our brains, trying to find a way to finish this engine... (I know, it has been posted before... )Read HERE what 'modelenginenews' wrote... Some engines you purchase for use.... Some engines you purchase to admire.... Some engines you purchase 'cause they puzzle you to death....and so does this one, in several ways... ![]()
USA, MS, Byhalia
Joined Nov 2010
Hi ya Gluehand..
Does that engine use an off set main journal bush to tweek the compression? I had to study for the sim event last night but I snuck out to the shop early this morning and found a small piece of 6061 bar and started Jenas spinner.. Couldn't work long but it's a start.. Wish I could help you guys on the fuel but we get no discount on hazmat shipments. Al |
USA, MS, Byhalia
Joined Nov 2010
John, neat post about using the rubber tube for the carb.. I'm going to try putting an OS Max .10 carby I have on my Russian Mk17. Wonderful little engines and dirt cheap, I just got another. Think I'll make a new back plate so's not to ruin the factory set up, I love the little tiny banjo fitting !! Last year when I was running it in I was screwing around with the eraser end of a pencil as a crude choke and it was amazing, an incredibly good idle with just that..
We'll see Al |
Joined Aug 2004
That equals, say, up to a 180° turn on a 'normal' sized comp.screw, which indicates that it is just meant for fine adjustments - not continously 'fiddling'... There's a lock screw for the bush at the bottom of the front c/case. To adjust, you rotate the 'shiny' part just rear of the prop driver, then tighten the lock screw.... I prefer to see it as a fixed compression diesel, where some tweaking is allowed for...
I have been going through boxes of old photographs and negatives and came across this rather poor quality one that I thought might be of interest.
As you can see it started life as an ED Bee which was modified to take a drive from the rear of the crankshaft and through a couple of 90degree gears to run a second prop drive. The twin drive unit was built by a brilliant engineer and modeller Tony Young of the West London, Brentford and Chiswick MFC. He built the unit to power a 60 inch free flight Douglas DC3 shown in the second photo. |
USA, MS, Byhalia
Joined Nov 2010
Look here for Gluehands pics of the Jena and Webra nva. I think he said a Webra 1.5 nva was about the same. http://www.rcgroups.com/forums/showt...54975&page=266 You can email off list here: arobins1@comcast.net but I don't want to be a bother, only if it's convienent and no freebies.. I insist to pay or at least trade something you need or that's fun. Off to see the wizard.. one more day in the "stimulator" ... what fun. CYYZ to KEWR (Pearson to Newark) Fire, flames, engine and flight control failures, what fun. ![]() More in a bit Al |
USA, MS, Byhalia
Joined Nov 2010
Hi Ya Gluehand,
I kinda figured that's what the lock screw was for.. So small compression ratio tweeks with the crank bush, I assume changing the load with different dia. and pitch prop would help to.. So who built it, any idea? Pic below is Cekoadon and my daughter Katie. About 3 sec. later, right after this pic, it broke the con rod up by the little end on the PAW.. Go figure.. It was running undercompressed and fat, (like always) so I have no idea why and I have never damaged a diesel.. Out of the 3 PAW 55 BR RC's we got at about the same time, this one was the runt of the littler. Hard starting, excessive end play in the crank and about 6-800 rpm lower top end.. Ed Carlson is sending me a conrod but I think it might should go back to PAW for a look see. if I can't find something obvious. Al Quote:
Perfect for free flight, both props turn at the same revs no matter what, and counter rotating to boot. That would have been weird flicking the prop over and seeing the other one bouncing around in unison, but backwards. |
Brian |
Joined Aug 2004
| Thread Tools | |
| Diesel Engines | Aeromister | Engines | 8 | Sep 01, 2009 07:17 AM |
| Discussion Need help with two diesel engines ! | cosmin | Engines | 3 | Feb 17, 2005 05:27 PM |
| WTB-Model Diesel Fuel | slogo | Aircraft - Fuel - Airplanes (FS/W) | 3 | Nov 13, 2004 09:42 PM |
| scale model of engines | dw1122 | Life, The Universe, and Politics | 2 | Apr 23, 2004 05:43 AM |
| diesel engines | wyflyer_55 | Fuel Plane Talk | 7 | Apr 22, 2002 02:45 AM |
