Old Mar 24, 2012, 09:34 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think the threaded cylinder and head results in a more lightweight engine overall. So it works to the engine's advantage by keeping the weight down. if you have to allow room for screws to bolt things together with, then you have to allow for more metal to let you drill/thread/tap the holes, etc. I doubt there is any cost savings to either method, screw on or bolt on, due to the machining steps involved. At the time this engine was designed it was thought that the rear intake would impart a performance advantage over a front intake engine. But one can get more performance with a front intake and save even more weight in the process too. Which is what one sees with the modern 3.5cc diesel engines (or glow engines for that matter).
earlwb is online now Find More Posts by earlwb
Old Mar 25, 2012, 09:34 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The threaded parts are cheaper to make if clocking of components is not important. It's all a compromise in design and manufacture. Nobody uses screw-in cylinders in modern designs for good reason. Threaded backplates and heads still make a lot of sense, but can require special tooling to install and remove. There's a lot to think about in engine design and manufacture.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 25, 2012, 03:23 PM
G WILLIE is offline
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
ID help needed
Can anyone tell me the maker, country of origin, year of mfg, and cost of this twin? I first thought it was a Taplin or a Taplin copy, but too many things are wrong.
The front and rear covers are fastened with 3 bolts, not 4.
The mounting lugs and screw bosses don't run the full length of the case.
There are individual brazed on exhaust stacks, not an exhaust manifold.
The heads are finned and held by 4 bolts, not smooth with 6 screws.
There are no lock on the Tommy bars (I love "Tommy bar". I wish I had an excuse to use "gudgeon pin", too!)
The carb is fascinating, but doesn't look like a Taplin.
The socket head capscews look to be of a modern manufacture.
Approximate dimensions are:
2 3/16" cylinder center to center
2 3/8" beam mount length
1 7/16" wide case under mounts
1 3/8" head diameter
3 3/8" bottom of case to top of cylinder
4 7/8" back of rear cover to front of drive washer
It weighs 26 oz
I'm guessing Chinese
G WILLIE is offline Find More Posts by G WILLIE
Old Mar 25, 2012, 05:10 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
The crank case looks similar to the CS copy of the OT twin .15.
Looks good, it's always nice to have something a little different.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Mar 25, 2012, 05:26 PM
Warren B is offline
Find More Posts by Warren B
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
The twin is a 10cc Krines.
I think it's an 80's/90's product from Germany or maybe Eastern European.
Pretty sure it's not Chinese.
Warren B is offline Find More Posts by Warren B
Old Mar 25, 2012, 07:03 PM
G WILLIE is offline
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
Many Thank's
Old Mar 26, 2012, 02:22 AM
brokenenglish is online now
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Bill, there never is a lock on a Tommy bar. The Tommy bar is the "transversal" lever that you use to turn the screw... The lock is on the threaded compression screw...
I'm waiting for your ECJ series to get to the Combat Specials and Rat-Race .40s, and the disassembling thereof... Then you'll be able to use gudgeon pin!
Brian
brokenenglish is online now Find More Posts by brokenenglish
Old Mar 26, 2012, 03:06 AM
hastf1b is offline
Find More Posts by hastf1b
F1B is ok.
Monheim am Rhein Germany
Joined Jul 2008
@ Taplin-Twin
http://modelenginenews.org/drj/taplin_mk3.html
http://www.google.de/search?q=taplin...w=1254&bih=605
Heinz
hastf1b is offline Find More Posts by hastf1b
Old Mar 26, 2012, 06:59 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Hi Warren is that a sliding piston throttle on that carb ?
olmod is offline Find More Posts by olmod
Old Mar 26, 2012, 07:01 AM
G WILLIE is offline
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
Brian
I stand corrected Brian. That's the danger of we Americans using a foreign language (English).
You don't have to wait for the Combat series. In part III of the Stunt 35 series, I will get to use gudgeon pin.
Old Mar 26, 2012, 07:06 AM
G WILLIE is offline
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
Yes it is a sliding trottle barrel.
On MECA's region 16 website, www.meca-region16.de there is a picture of a Krines made from Herr Krines drawings. It was started in 1963, but no idea when it was finished. The notes say it is a 20cc engine.
I'm still rying to find out when and where the newer version was made.
Old Mar 28, 2012, 07:53 PM
JohnAV8R is offline
Joined Oct 2005
AMZ diesel
Is any one familiar with this diesel? It's a long stroke, so probably not a high rpm engine.The thrust washer looks almost like the early ETA .15, even the same colour.
John
Old Mar 28, 2012, 08:06 PM
Warren B is offline
Warren B's Avatar
Joined Dec 2008
Looks like an Oliver Tiger MkIII based design to me, obvioulsy with some modern features like the muffler mounting jacket etc.
Old Mar 28, 2012, 08:20 PM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
John
The AMZ engines were made by a Dr. Walter Sturm, Im Strasser Feld, Herzogenrath (or Roetgen ?) Germany. He placed small adverts for this interesting 2.5 Diesel in 1980's era AeroModeller magazines. BOB
Twin-Stack is offline Find More Posts by Twin-Stack
Old Mar 30, 2012, 06:29 PM
JohnAV8R is offline
Joined Oct 2005
Thanks Bob. Do you have any more information on EU Engines. The box cover shows an English address. Since this is the first time I have seen a picture of the AMZ, I'm guessing that either it wasn't very popular, or not too many were made.
John
Diesel Engines Aeromister Engines 15 Aug 23, 2016 09:57 AM
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
