Espritmodel.com Heli Air
Old Feb 14, 2012, 06:12 PM
Ancaster, Ontario, Canada
Joined Oct 2005
Sundancer, nice pictures, great memories. You were very lucky to have had a sister that shared your interests.
How did the Eureka with the ETA 15 Mk I compare to the one with the Cox .15?
If the Dixielander and Eureka are the same size, assuming all similar weight, how would you compare or place the AM 3.5, ETA 2.5 and Cox .15 ?
JohnAV8R is offline Find More Posts by JohnAV8R
Old Feb 14, 2012, 07:49 PM
Chennai, Tamil Nadu, India
Joined Sep 2003
Very nice pictures Sundancer. They look so evocative. Thanks for posting them here
mchandrayan is offline Find More Posts by mchandrayan
Old Feb 15, 2012, 01:54 AM
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
The original, as per Norman Marcus's plan, Eureka was OK with the ETA15, but had the unfortunate habit of stalling off the top of the climb and never pulling out sometimes. My modified verion, with sheeted leading edge and some other changes, subsequently published in Aeromodeller, cured this problem and was a decent model with the ETA or AM35. Fitting a Cox 15 introduced a new set of problems in coping with the extra power and further mods proceeded until resulting in the last model, the Long Eureka IIIA (lengthened tail moment, different flat bottom wing section, stiffer structure) shown and this was a superb model. The Dixielander did not really suit the heavier ETA, with the AM35 it was a wonderfully consistent performer, capable of maybe 3.1/2 to 4 minutes from 10 second runs without lift. But directly substituting a Cox 15 running on high nitro turned it into an animal! We found out that to cope with the extra power and speed you needed to reduce the wing wash in from 3/8" to 1/4", reduce the wing tip washout from 3/8" to 3/16" and trim for a single wide turn in 10 seconds. Widening out the glide turn also improved the performance and you finished up with a model which would deliver close to 5 minutes from a 10 second run, but required care in launching it at exactly the right angle etc. - in other words it became a lot less forgiving of mistakes than the AM35 Dixielander.
How would I rank the three engines for use in open power models? The ETA was heaviest, smoothest running and a lovely handling engine, well suited to the Eureka in it's original form, less so to the Dixielander. The AM35 was light, powerful when swinging the right prop, vibrated a bit more than the ETA and didn't handle as easily but was a perfect match for the kit Dixielander built exactly as per plan producing an easy to trim and very consistent contest model. The Cox TD15 (and later Special 15) were light and incredibly powerful on small props and high nitro fuel, too much for the original Eureka layout and the Dixielander as trimmed for an AM35. In the right airframe (the lengthened Eureka or readjusted Dixielander) however, there was no contest - the Cox had it every time.
Sundancer is offline Find More Posts by Sundancer
Old Feb 15, 2012, 03:35 AM
Closed Account
Joined Nov 2009
With the benefit now of around 30 years of hindsight, can I pose these three question to all Diesel lovers........
1) Was there any real advantage in having a Schnuerle ported Diesel ?
2) Was there any real advantage in having a Diesel with ABC metalurgy ?
3) Was there any real advantage employing both of the above technologies together in a model Diesel engine ?
Twin-Stack is offline Find More Posts by Twin-Stack
Old Feb 15, 2012, 10:26 AM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Not considering myself an 'expert' in any way, my comments are based on a blurry mix of experience and 'feel', accumulated over a fairly long period of time....
1) I think, generally, yes..! The 'hotter' ported diesels (Schnuerle or Schnuerl-ish) I've had the pleasure to try, have all showed very good running properties, i.e. in my lower revving world beeing easy handling, and not least, improved throttling... Torque-wise (ability to pull even larger props) though, I cannot say I've noticed any major improvement....
Experiments with 'hotter' portings on diesels, were/are probably mainly meant as 'rev-boosters' with small props, but IMHO these mods make the engines much nicer to handle even at more low-revving ('sports') applications.
2 & 3) Other than lower friction / higher revving on small props, I cannot see the ABC technology beeing any contribution to the diesel development....and do we have an oil issue here...?...(this is beyond my practical experience)
Gluehand is offline Find More Posts by Gluehand
Old Feb 15, 2012, 02:09 PM
Hervey Bay, Queensland, Australia
Joined Mar 2008
My Irvine. 20D (all three of Bob's attributes) runs a little more powerfully than my Oliver Tiger Major ... but not as far above it as I would have thought.
fiery is offline Find More Posts by fiery
Old Feb 15, 2012, 04:28 PM
Closed Account
Joined Nov 2009
I don't know if any scientific proof or data exists on this, but one of the unofficial laws of 2 stroke technology (that I was taught anyway) is that a Diesel design does not work all that well when converted to glow ignition. This appears to be because the gas passages, which are entirely adequate in a Diesel, are undersized when transposed to a glow. Thus, we had the PAW glows which weren't very powerful or successful, and several other British designs over the last 50 years. From this, I deduce that a Diesel doesn't need to have as much fuel mix going through it, to produce the same (or better) performance than an equivalent glow. It would seem then, that Schnuerle porting in a Diesel is entirely superfluous..........?
Old Feb 15, 2012, 05:36 PM
Joined Oct 2005
items 2&3
The last MVVS 2.5 came with either diesel or glow.
The new Parra 2.5 diesel can also be had with the glow head.
The Parra "steel" has much less porting than the AAC version.
Both engines started out as diesels, but may put out more power on glow, especially if you let them reach high revs.
My guess would be they are similar on 8x4 to 8x6 props.
For comparison, my Cox Conquest would turn an 8x4, 15%, on the ground, an easy 18,500 rpm. My K&B .21 RE puts out more power and burns more fuel than an old OS .50 in a Fun Fly model, but the OS 50 is much more enjoyable.
John
Old Feb 15, 2012, 05:54 PM
Closed Account
Joined Nov 2009
Another Schnuerle related enquiry I have is this - how thick must the cylinder liner in a Schnuerly be, before the ports can be considered "directional" ie. influence the angle of gas flow ? If you can imagine two identical cylinders - one is half a millimeter thick, the other 5 mm thick and both with the same ports, cut through at the same angles, there is no way the thin liner ports could be called "directional", but just merely "holes" surely.
Old Feb 15, 2012, 07:12 PM
Joined Mar 2008
My Taipan Mk 5 "goldhead" schnuerle TBR converted to diesel.
Easy 18,500 RPM on a master 8x3 prop.
Old Feb 15, 2012, 07:51 PM
Joined Jun 2011
Bob, even if the liner was only a few thou thick, if the bypasses in the case are angled to get the gas flowing in the right direction, and the liner ports match up, that should be all that is needed.
Charlie
2gun is offline Find More Posts by 2gun
Old Feb 15, 2012, 07:54 PM
I had a K&B 4011 glow I flew CL stunt with. It turned an APC 9,700 about the way I would set it to fly. I used some Eric Clutton Old English fuel. After leaving the glow plug lit for maybe 20 sec after starting, it ran nice with the needle (ST NVA) turned in 1 1/2 turns, 9, 700
First model Drone diesel, same fuel, a hair overcompressed, 6,900 on MAS 11 x 9, Put on Drone glow head, 10% nitro fuel, very smooth, turned the needle in a little, 6,900.
I understand a 2-cycle engine as basically an air pump. How fast it runs depends on how fast air can go through (with proper fuel mixture, of course). So I am not surprised that an engine runs similar power both diesel and glow. I did not try larger props. Perhaps the diesel would out perform the glow on a bigger prop.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Feb 15, 2012, 08:22 PM
Closed Account
Joined Nov 2009
Charlie
Charlie, the assumption then is, that the bypass channels in the case are of primary importance - the liner ports secondary ?
Old Feb 15, 2012, 09:02 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
1) Maybe, it depends on the porting. But many model diesels appear to have something quite similar if not the same as Schnuerle porting in them already. So one may or may not see an improvement. But the modern model diesels seem to be Schnuerle ported.
2.) yes I think there is, granted a good tapered steel cylinder with a good lapped iron piston works a lot like a ABC setup, the piston in the ABC engine is more light weight and they can get it to turn even higher RPMs than a lapped iron piston engine.
3.) Yeah I can see it as being better. My Para engine runs really superb as a diesel and it has all these things in it. Of course they offer the engine with a steel sleeve, ABC and AAC. Now then AAC seems to offer a advantage in more limited situations than ABC does. I remember seeing some other engines like that but I forget their names at the moment.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Feb 15, 2012, 09:04 PM
Joined Jun 2011
I am considering a typical Schneurle ported engine here. I think that it is a combination of the two. If the liner was only a few thou thick, but the ports matched the bypasses then the bypass would be the only important thing to set the flow direction. However if the liner is say 1/16th thick, but the ports in the liner are not cut at the correct angle to match the bypass angle (perhaps just milled in radially), then you will probably get all sorts of turbulence at the port causing disruption to the required loop flow of the gas. Another thing ( off topic and unrelated to port angles) is the internal finish of the gas passages. In my opinion, although smoothness and flow direction is important, polishing is not. I think that the best surface is about like fine bead blasting. Mind you there is no guarantee that I am right.
Charlie
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
Discussion Need help with two diesel engines ! cosmin Engines 3 Feb 17, 2005 05:27 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
scale model of engines dw1122 Life, The Universe, and Politics 2 Apr 23, 2004 05:43 AM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
