Go Back   RC Groups > Aircraft - Exotic and Special Interest > Vintage & Old-Timer Designs
Old May 26, 2009, 01:50 PM   #16
A very powerful but unforgiving engine.I believe this is the Appleton version.
  • Name: amco 3.50001.jpg
Snorks is offline Find More Posts by Snorks   Reply With Quote
Old May 26, 2009, 01:52 PM   #17
Ian Easton's Avatar
Snorks, Yours is a Super Merlin as it has the red anodized head and now the correct spinner. I bought a new one about 1974ish. It's a great engine and still runs well. I did send it back once to DC where it was given a rebore and nrew piston.
Ian Easton is offline Find More Posts by Ian Easton   Reply With Quote
Old May 26, 2009, 01:52 PM   #18
Elfin plain bearing. I love this one like a brother... easy handling, powerful, but a little thirsty for a 1.5.
  • Name: elfin1.50001.jpg
Old May 26, 2009, 01:53 PM   #19
My Silver Swallow was bought in 1989. I fitted a PAW silencer & throttle then used it to power an enlarge Frankenstien & later in a Veron Robot. It starts easily enough & the power was OK for the Robot but too much for Frankie. Throttle was from a Thunder Tigre 25 (guttless OS clone version) & worked very well. The silencer was sealed with heat proof epoxy between it's bottom edge & the crankcase.
Tachoed it at 10000 rpm with both an 8x6 & 9x4 Graupner grey, 7200 rpm with a 10x6. IMO a decent moderate power, lightweight sport 2.5cc engine.
  • Name: PICT0226.jpg
Description: With PAW silencer & small venturi. With PAW silencer & small venturi. 56.9 KB · Views: 104
patmcc is offline Find More Posts by patmcc   Reply With Quote
Old May 26, 2009, 02:02 PM   #20
I love this engine. was given to me by a boss. Docile & a good sports engine. taipan 2.5 plain bng.
  • Name: taipan 2.50001.jpg
Old May 26, 2009, 02:22 PM   #21
Small size DC collection plus a throttled ME Heron.
DC Wildcat & Eta 29.
  • Name: Small group.jpg
Description: 2 Darts, 3 Super Merlins, a Spitfire, a Sabre & ME Heron. 2 Darts, 3 Super Merlins, a Spitfire, a Sabre & ME Heron. 96.3 KB · Views: 152
  • Name: Wilcat_Eta.jpg
Description: Same capacity different power, bulk & weight !!! Same capacity different power, bulk & weight !!! 95.0 KB · Views: 103
Old May 26, 2009, 07:12 PM   #22
Airboatflyingshp's Avatar
Ive one of these a Russian made MK17... fantastic little howler of a motor easy to start and reputedly runs well on a carb. Also 2 PAW 2.49s and 2 head conversions for 40 size OS fp/FSR motors.
  • Name: mk17n2-2.jpg
  • Name: mk17n2-4.jpg
Airboatflyingshp is offline Find More Posts by Airboatflyingshp   Reply With Quote
Old May 26, 2009, 07:42 PM   #23
Yet I found it to be very powerful but docile and easy to handle.
Of course, if you don't like it .... and it's unloved ....
Applehoney is offline Find More Posts by Applehoney   Reply With Quote
Old May 26, 2009, 08:09 PM   #24
Cox 0.09 (1.5 cc) Diesel
This is one of my favourite little engines.
The Cox .09 glow had a conversion head made by Davis Diesel Development Inc. The glow version,on mild fuel (10%) , using a glow plug adapter and swinging a 7x4 prop was happy at 16,000 rpm. On diesel, 8x4, 9,000 rpm.
Take your pick, speed or torque.
  • Name: Cox2.jpg
  • Name: Cox3.jpg
  • Name: Cox4.jpg
  • Name: Cox 5.jpg
JohnAV8R is offline Find More Posts by JohnAV8R   Reply With Quote
Old May 26, 2009, 08:20 PM   #25
Cox 0.09 glow vs Cox 0.09 Diesel
Cox 0.09 with Cox 0.01 TD for size coparison.
Cox 0.09 Diesel with new version of Cox 0.09 TD glow with stock carb and muffler. Above TD on glow had an after market Taro carb, otherwise identical engines.
Power???? The Cox 0.09 will pull a Wild Thing, 350 square inch wing area, and all up weight 30 oz, almost straight up. In the same airplane it is faster than an Enya .15 powered competitor.
Are they made well? I think so. Hundreds of runs and still going strong. No loss in compression, just reset the rod in the piston now and again.
  • Name: Cox 09 vs 01TD.jpg
  • Name: Cox 09.jpg
  • Name: Cox 09D vs TD.jpg
  • Name: Cox 09TD vs 09D.jpg
Old May 27, 2009, 09:31 AM   #26
The little TD is a jewel, my OS 40 conversions are a Davies uses an allen key and the other is anodised blue nicely made, but more traditional in that it has a tommy bar adjuster for the contra piston and locking arm it came from the States.
Old May 27, 2009, 11:04 AM   #27
My all time favourite small diesel has to be the Barbini B38 1cc of which I have 2 examples 1 NIB and 1 in use, it turns a 7X5" wood zinger around 13,000rpm. But as can be seen in the instruction leaflet max power is 18,000rpm - puts it in the 1cc MPJET class not bad for a mid 50's design.
Stewart
  • Name: B38-1ccBarbini-2.jpg
  • Name: BarbiniS.jpg
clipclop is offline Find More Posts by clipclop   Reply With Quote
Old May 27, 2009, 12:44 PM   #28
F1B is ok.
Webra-Piccolo
The smallest "Webra" Diesel-Engine "Piccolo" 0,8 ccm
Heinz
  • Name: picco 1.jpg
  • Name: picco 2.jpg
hastf1b is offline Find More Posts by hastf1b   Reply With Quote
Old May 27, 2009, 01:04 PM   #29
What model is that Heinz? & whats going on with the T piece on the fuel line?
cheers
Simon
Old May 27, 2009, 01:50 PM   #30
Gluehand's Avatar
cheers
Simon
A wild guess: The T-piece connects to an airbleed cut-off (timer) ....
This is the nicest version of Piccolo....later on they became more chunky....
Gluehand is offline Find More Posts by Gluehand   Reply With Quote
Diesel Engines Aeromister Engines 8 Sep 01, 2009 08:17 AM
News Need help with two diesel engines ! cosmin Engines 3 Feb 17, 2005 06:27 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 10:42 PM
scale model of engines dw1122 Life, The Universe, and Politics 2 Apr 23, 2004 06:43 AM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 03:45 AM
Bored? Want to fight?
Join the RCGroups clan!
