Old Sep 07, 2011, 03:24 AM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
Originally Posted by earlwb View Post
That engine looks like they were using the crankcase for the fuel tank too. So it may not be really all that heavy.
I wonder how well that worked. I would think the fuel would heat up causing the ether to evaporate faster. But maybe for short free flight runs, it would not be a problem.
Like this Earl -
Twin-Stack is offline Find More Posts by Twin-Stack
Old Sep 07, 2011, 10:22 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
yeah like that too, that Huscika looks like they did it more like the Antares engine did.
earlwb is offline Find More Posts by earlwb
Old Sep 10, 2011, 01:17 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
T-b
Now here is a pretty rare one, the Thorning-Bensen, made in Denmark in 1945,
ser.nmbr. 2059 Came without the fueltank so I am making one, I do have the original drawing, when finished the tank will be "matted" of course.
Reginald is online now Find More Posts by Reginald
Old Sep 10, 2011, 01:28 AM
Reginald's Avatar
Belgium
Joined Aug 2004
Thorning-Bensen
Thorning-Bensen
Old Sep 10, 2011, 08:27 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have what appears to be a original Mills 1.3cc MK-I engine. But someone appears to have made a different intake MK-II style venturi tube for it. the Intake has the needle assembly horizontally mounted instead of vertical. The engine appears to be new and not even run. Maybe mounted on a display stand or something. There is a 63 stamped on one mounting lug and a 127 stamped on the other lug.
Old Sep 10, 2011, 08:30 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That Thorning-Bensen is looking really nice. I would think that you would put a inside lip or shoulder on the fuel tank to help keep it from moving around some.
Old Sep 10, 2011, 06:13 PM
gossie is offline
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
That Mk1 Mills should run okay like that Earl, but if you could pick up the proper carb. and tank would be nice.
gossie is offline Find More Posts by gossie
Old Sep 10, 2011, 09:01 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yeah I have thought about machining up a new intake tube and make it vertical and maybe machining up a fuel tank for it too. Sort of what the MP-Jet replicas have.
But I will keep a lookout for a original intake and fuel tank though.
Old Sep 12, 2011, 04:25 AM
Closed Account
Joined Nov 2009
Anybody got one of these ?
http://ameblo.jp/in-the-groove/image...560939217.html
Old Sep 12, 2011, 05:52 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
No, but I like it! sparks
sparks59 is offline Find More Posts by sparks59
Old Sep 12, 2011, 06:33 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
They needed a hex nut on the bearing tube ? oh yes its a glow motor .
olmod is offline Find More Posts by olmod
Old Sep 12, 2011, 06:45 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Originally Posted by Twin-Stack View Post
I don't have that one, but I have one of these. the Parra 2.5cc RC AAC model diesel engine.
I don't think he makes those old style combat engines shown above anymore, it isn't listed on this website and it has the old exhaust pipe style on it.
The contra piston design Parra uses is a low profile setup so it tends to look like a glow engine with the glow plug tip broken off.
Test run using a MA 8x4 prop a DDD fuel.
Parra 2.5cc RC model diesel engine test run (3 min 0 sec)
Old Sep 13, 2011, 03:06 PM
nitroairplane is offline
Find More Posts by nitroairplane
Tiny diesels.... I love 'em
United Kingdom, England, London
Joined Aug 2011
Clan 0.24cc (0.015 cu in) diesel model engine tiny (5 min 54 sec)
nitroairplane is offline Find More Posts by nitroairplane
Old Sep 13, 2011, 03:07 PM
Joined Aug 2011
Frog 100 [1cc or 0.06cu]vintage diesel model aircraft engine (0 min 43 sec)
Joined Aug 2011
cox .020 pee wee diesel running nicely (1 min 55 sec)
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
