Old Jul 30, 2011, 02:05 PM
Chas is offline
Find More Posts by Chas
Voices through wires? Ha!
Chas's Avatar
Joined Feb 2003
Mr. Wiz,
Things are a little different elsewhere...but it's a diesel !
How Close to a Train Track Can You Setup a Vegetable Market (0 min 44 sec)
Only in India (2 min 43 sec)
Chas is offline Find More Posts by Chas
Old Jul 30, 2011, 02:40 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Chaz.... That's unbelievable!
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jul 30, 2011, 05:17 PM
gossie is offline
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
Every inch of space counts.
gossie is offline Find More Posts by gossie
Old Jul 31, 2011, 10:44 AM
Gluehand is online now
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Mysterious parts
Hi,
I just came across a 'bag of bits', containing this complete NVA + a separate needle (in fact 2 of them...)
Could anyone here identify these parts.........as I haven't even a clue...
(mind, posting here doesn't necessarily mean that the parts come from diesels...)
Gluehand is online now Find More Posts by Gluehand
Old Jul 31, 2011, 12:29 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Top one looks a little familiar....but I just can't remember where.
These are small NVA ( 1/2A, or 0.5cc) ?
Some one will have an engine with these units mounted on them, so maybe they can send us a picture???
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Jul 31, 2011, 01:34 PM
Gluehand's Avatar
Joined Sep 2008
The top needle with its 'cross-knurled' part, reminds slightly of AM....although a direct comparison shows that it isn't...
The fuel line fitting at the end of the spraybar with its turned 'multi-knurl' should be quite easily recognised...for the one who has seen one, that is....
As manufacturers often used uniform sized spraybars for wide ranges of engines, it is hard to judge the size of engine...I would say anything .049 up to .15....
Old Jul 31, 2011, 06:02 PM
WhyNot is offline
Find More Posts by WhyNot
Irvine, CA
Joined Jan 2005
This is similar enough to suggest that your 2nd NV might come from a Cameron engine. The attached is from my Cameron .09 "Rodzy" tether car. On my example the knurled thumb knob was placed on the end to facilitate turning it from outside the car body, but for other applications Cameron may have supplied the a NV in your example.
Charlie
WhyNot is offline Find More Posts by WhyNot
Old Jul 31, 2011, 06:47 PM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
Gluehand, the bottom needle is from an OS Pet II. It is identical to mine. BOB
Twin-Stack is offline Find More Posts by Twin-Stack
Old Jul 31, 2011, 09:31 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
As long as we're talking needles. I got this with an engine it didn't fit. Over all length is almost 56mm.
gkamysz is offline Find More Posts by gkamysz
Old Jul 31, 2011, 11:13 PM
Closed Account
Joined Nov 2009
Looks a bit like one from an OS Max 6. BOB
Old Aug 01, 2011, 03:18 AM
Gluehand's Avatar
Joined Sep 2008
Thanks Bob...!...and a quick googling shows that there's no doubt....
The top one has yet to be identified though....that distinctive 'multi-knurle' fuel line fitting must be quite unique, but I cannot recall having seen one before.....
Old Aug 02, 2011, 09:10 PM
JohnAV8R is offline
Joined Oct 2005
the Russian-made "Marz" 2.5D.
Here's a tale of dark deeds and derring-do from the cloak-and-dagger side of the model engine trade—the saga of the Russian-made "Marz" 2.5D.
Old Aug 02, 2011, 09:25 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I was helping a fellow modeller with his diesel engines over the weekend.
here is his Marz 2.5cc example being test run at my home. His engine was running amazingly well and was amazingly smooth too.
Here is a short video clip of when we were running the engine. i think it was its second tank of fuel at the time. First I ran my Davis Diesel fuel, and the second tank was from his old can of Aerodyne fuel. The old Aerodyne fuel needed a little more compression than the DDD fuel did, so I assume some of the ether had evaporated over time.
So we weren't trying to run it hard. I forget what the prop size was at the time.
Click on the pic to run the video.
earlwb is online now Find More Posts by earlwb
Old Aug 03, 2011, 09:43 AM
barry wilson is offline
Find More Posts by barry wilson
amherst,nova scotia,canada
Joined Nov 2003
The factory muffler is reputed to drop the power substantially on this engine. Of course I have not proven it myself. There has also been some discussion of crankshaft integrety as well.
Using fuel that requires a lower compression setting probably is good for all diesels. My feeling on glow engine conversions especially it is prudent.
I have heard that adding a little more ignitor to the fuel might enable this. Perhaps three percent rather than two percent considered the normally recommended amount. Anyone know?
barry wilson is offline Find More Posts by barry wilson
Old Aug 03, 2011, 12:05 PM
Chas is offline
Chas's Avatar
Joined Feb 2003
Ignitor (amyl etc) really promotes smoothness...to run lower compression ratios you need more ether.
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
