Old Jul 14, 2011, 11:12 PM
gossie is offline
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
That's nice Charlie, and a great effort to boot.
So what do you build for it? CL?
gossie is offline Find More Posts by gossie
Old Jul 14, 2011, 11:26 PM
2gun is offline
Find More Posts by 2gun
Joined Jun 2011
Thank Gossie, Something C/L is the plan, but I don't know just what yet. I will have to start with a major cleanup in the workshop first.
Charlie
2gun is offline Find More Posts by 2gun
Old Jul 15, 2011, 01:06 AM
Chas is offline
Find More Posts by Chas
Voices through wires? Ha!
Chas's Avatar
Joined Feb 2003
Gorgeous! The Tommybar is pure Oliver....but why am I thinking Futurama??...
Chas is offline Find More Posts by Chas
Old Jul 15, 2011, 01:20 AM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Hi
Good engine for a Mercury Toreador
NX-687 is offline Find More Posts by NX-687
Old Jul 15, 2011, 01:43 AM
mchandrayan is online now
Find More Posts by mchandrayan
Chennai, Tamil Nadu, India
Joined Sep 2003
That's a gorgeous little diesel you have made Charlie. Any more in stock?
mchandrayan is online now Find More Posts by mchandrayan
Old Jul 15, 2011, 02:01 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Originally Posted by 2gun View Post
Perhaps this might interest someone. It is an MAN .19 diesel that I have built from a design published in Model Airplane News in 1956. It started life as a lump of aluminium 2 1/2 inches diameter. It runs well and starts easily although making it was a bit more involved than I expected.
Charlie
Very nice work but what is the witness line up the front of the crankcase
olmod is offline Find More Posts by olmod
Old Jul 15, 2011, 03:14 AM
2gun is offline
Joined Jun 2011
The bit of the crankcase between the top of the engine bearers and the lowest fins was shaped by spark eroding (EDM) and the witness line that you see on the front of the case is where I didn't do a perfect job of aligning the electrode when I turned the case over to cut the second side. I will attach a photo of the electrode that I used. (I made 2, but only needed 1)
Old Jul 15, 2011, 04:56 AM
Twin-Stack is offline
Find More Posts by Twin-Stack
Closed Account
Joined Nov 2009
Charlie, may I add my congratulations on a beautiful job well done ! The engine looks like a surgical instrument that has been hewn from a solid block of stainless steel by a laser. Its the class of artifact that should be in a museum somewhere ! BOB ALLAN
Twin-Stack is offline Find More Posts by Twin-Stack
Old Jul 15, 2011, 05:01 AM
2gun is offline
Joined Jun 2011
Thanks Bob, coming from a student of engines such as yourself that is a real compliment.
Charlie
Old Jul 15, 2011, 06:15 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Charlie
Hey Charlie, that thing is beautiful. You should be very proud of that effort.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jul 15, 2011, 06:46 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
2gun, I loved how that engine came out. That was a great job you did on making the engine. The EDM method you did, made it look like a cast crankcase too.
earlwb is offline Find More Posts by earlwb
Old Jul 15, 2011, 08:38 AM
2gun is offline
Joined Jun 2011
The bit between the bearers and the lower fin was done with the EDM, but the part below the bearers was done by hand with a file, then polished. After that I masked up the case with tape and used a small bead blaster with glass beads to make the whole back part of the case above and below the bearers look the same. The front and fins were masked to keep them shiny.
Charlie
Old Jul 15, 2011, 11:38 AM
SAslinky is offline
Find More Posts by SAslinky
SAslinky's Avatar
Umkomaas, South Africa
Joined Mar 2010
Originally Posted by earlwb View Post
Do post some pics. Nice find. Is it like one of the Valentine Reproductions?
ref http://www.ronald-valentine-engines....5_DR_Mk_I.html
You know, I never thought about using a fuel tank pressure tap straight off the exhaust port on the engine before.
I wonder how well that worked on generating a little fuel tank pressure.
That is a prime tube, it is connected to the multi-function valve which acts as a shut off/and fueling device used in F2C control line team race, the multi-function valve also primes the venturi when filling the model. You will find a tube like that, either a nipple or thin copper tube, on the team race engines that where designed after the introduction of the multi-function valve.
I will look for a picture of a B.P. that I have and post it to show what I mean.
Lionel.
SAslinky is offline Find More Posts by SAslinky
Old Jul 15, 2011, 01:02 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Lionel.
Thanks for the info, yes I would like to know more about how that would work. I was thinking as to why prime through the fitting if the exhaust port is already there open so there must be some other purpose for it.
Old Jul 15, 2011, 02:16 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The exhaust port is no normally easily accessible in an F2C model. And the pitman wouldn't want to be looking for it during pitting. Look up an F2C race on you tube to see just how fast a pit stop is.
Greg
gkamysz is offline Find More Posts by gkamysz
Diesel Engines Aeromister Engines 15 Aug 23, 2016 09:57 AM
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
