Old Jun 09, 2011, 07:04 PM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Nice link
NX-687 is offline Find More Posts by NX-687
Old Jun 09, 2011, 09:00 PM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Brass is also good for laps.
olmod is online now Find More Posts by olmod
Old Jun 09, 2011, 09:35 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
NX-687, nice work. You may end up with a "better than new" crank, smoother, less vibration, and a little more power. Are you setting the crank at 90 degrees for "zero" balance (with the rod and piston attached)?
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Jun 10, 2011, 12:16 AM
NX-687 is offline
Joined Aug 2007
Hi John
It doesn't even balance out 50% of the reciprocating weight ,with all those weights
And my honing , oh no ,may not even run,
and I might have my 5th crank failure in 5 weeks coming up , I hope it holds together, at least for 6 flights
Its tight and flicked for about an hour with a 10x6 until it ran slow
the piston is barrel shape not touching at the top
Old Jun 11, 2011, 02:23 AM
NX-687 is offline
Joined Aug 2007
Some Progress
3 flights OK at full power , 2 tanks on ground , rich, to run in the P/L ,, needed it ,
I leaned it on the first tank and it stopped hot,
power OK slightly down as the inlet and EXH ports are a little smaller,
holds its tune OK,
Ive got 20/40/40/1.5 fuel, and 8.5 x5 prop
Crank is pretty smooth not much vibes at all , although its probably got only 10 flights before the pin goes
Good bit of Diesel mess on the wing
Maybe engine parts coming out the exhaust?
Old Jun 12, 2011, 08:14 AM
JohnAV8R is offline
Joined Oct 2005
NX-687, looking good. That's a lot of prop for a .15 (if glow), but the diesel is pulling through.
Smoother run, less vibration....you may be getting closer to the balance point.
That "black" residue may indicate that you have severe wear going on inside. Maybe bump the castor up to 25%, and don't push for a lean run.
John
Old Jun 12, 2011, 08:41 AM
Gluehand is offline
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Mainly black residue indicates high loads.....I usually aim for a 'brownish-black', or brown goo, which makes me feel like playing on the safe side...
25% castor helps in this respect, as well as not using too high pitched props.
Most of my '15' diesels, typically thrive on 9x4 props, providing a good acceleration/low speed pull, at a slight cost of top speed...
My 2 C's....
Gluehand is offline Find More Posts by Gluehand
Old Jun 13, 2011, 01:22 AM
NX-687 is offline
Joined Aug 2007
Hi
Its a challenge to start as its my own parts in there ,my finger is bruised and black , needs a rest , I dont think my piston seals well until it get to the top and then its tight , and also my cyl is loose in the case and so my case compression may be bad , that may explain the poor starts , heating with LPG helps , a glow is pretty easy after this. Gluehand , yes I think the 9x4 is a good choice ,
John
It looks like what they say about balancing 50 % of the reciprocating weight is right , seems closer I get to that the smoother it is, at the risk of increasing the secondary , sideways rocking
Old Jun 13, 2011, 08:11 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
John
You might find this article helpful in your quest for better dynamic balancing,
http://modelenginenews.org/etw/etw_bal/p2.html
sparks
sparks59 is offline Find More Posts by sparks59
Old Jun 13, 2011, 05:38 PM
NX-687 is offline
Joined Aug 2007
Good article, and it says about 50% of the reciprocating weight
My Chinese engines have very thick pistons , so they are up against it
Old Jun 16, 2011, 01:39 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Im hoping this will go better
Next one I will make with a thicker web towards the conrod about 1mm at least
For those interested, here are some pics of the crankshaft of a YS DZ-160.
It is the first time I've seen the use of a ring on the web of a crankshaft, I was quite surprised when I dismantled the engine but then I realised that this was probably needed on this engine because of the use of the air-chamber
greetz Reggy
Reginald is offline Find More Posts by Reginald
Old Jun 16, 2011, 01:46 PM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
These are the pics that go with the text elsewhere
Old Jun 16, 2011, 02:44 PM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Originally Posted by Gluehand View Post
I just asked my "better half" if she checked the mailbox yesterday afternoon.....no, she'd forgot about it......
So, rushed out (half an hour ago), and...among the 'lesser' mail was a little cardboard box that's beeing sitting there since YESTERDAY.....obviously the Schlosser !
What a little jewel....so well made....and I particularily like that the NVA is proportional to the engine size (such details make a lot)....not always seen on small engines, where manufacturers sometimes use the same NVA to a number of engine models, making it look giant on the smaller ones...
Now I have to find a couple of suitable props...a run-in report will eventually be posted here...
Here's a picture of my Schlosser 0.25, prop is a 15-10 or 6-4 inch Graupner
Of all the very tiny diesels I have this Benno Schlosser is the top of the pops.
You have probably experienced yourself the wonderfull compression-feel, I have often wandered how he managed this delicate feel. Have another one NIB
Old Jun 16, 2011, 02:47 PM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Originally Posted by JohnAV8R View Post
Thanks Mike. If we all add a few pictures now and again, we should be good for a long time.
I've still got a few more pics of the Merco 5 cc. It's back together.
I'm still waiting for someone to have another shot at the "unknown" diesel with the strange logo print on the side. I think I've found the logo on another diesel so I'll post it later.
A pair of Clans, .48 and .24 cc ? Have you run them, and if so, what size props?
Hello John, my experience with the Clan was leaking on the intake probably caused by the choice of plastic for the intake greetz Reggy
Old Jun 16, 2011, 03:24 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The ring in the YS crank is to aid in increasing crankcase compression ratio, similar to stuffing the crank in a two stroke.
Greg
gkamysz is offline Find More Posts by gkamysz
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
