Espritmodel.com Heli Air
Old Apr 08, 2011, 05:25 PM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
What type of temp' device ? I find IR types on silver alloy are incorrect when compared to HP stick on.
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Apr 08, 2011, 06:36 PM
Ancaster, Ontario, Canada
Joined Oct 2005
NX-687, for a .15 size engine to pull 65 ft lines around, and do fig. 8's, I'd say you have more power than a glow. What's the all up model weight?
I remember I once had a 1/2A model with an OS Max.15 on 52 ft lines and it moved right along. It was more like an under powered rat racer. If your diesel is running cooler than glow,I wouldn't worry about the head temperature, that what keeps the diesel firing up there.
JohnAV8R is online now Find More Posts by JohnAV8R
Old Apr 08, 2011, 10:39 PM
Joined Aug 2007
Hi John
Yes 24.5 Ozs ,
It would be hard to measure a diesel head temp as the contra piston is usually buried inside an aluminium cooling jacket,
with 30% oil my engine is pretty well protected even with a lean run it seems no ill effects
just richen it up and it springs back to life for the next flight with no aparent damage done
NX-687 is offline Find More Posts by NX-687
Old Apr 09, 2011, 01:23 AM
Voices through wires? Ha!
Chas's Avatar
Joined Feb 2003
I don't see how a diesel can have a lean run. If it goes too lean it stops.
Chas is offline Find More Posts by Chas
Old Apr 09, 2011, 03:32 AM
Joined Aug 2007
Hi
Ive got an Enya 35 NVA in my OS 15 diesel and on one flight it was sputtery and a little slow , so next flight I opened up about between 1/8 and 1/4 turn and the power came back ,,
I just flew,,,,,,,, and the model is slowing a little thru 8;s it may be rich or my homemade piston may be stuffing up, it flips over nice so I hope its just the tune , also my baffle is so close to the head that I didnt expect it to last what 12 flights that its had so far , if it stuffs up I dont know what to get , a little, more power would be nice,
and after the engine starts I always try to remove the glow plug leads
Old Apr 09, 2011, 05:35 PM
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Originally Posted by phil_g View Post
Could I just ask does anyone know if there are any new small diesels being made or imported to the UK at the moment?
Just a follow-up, my nice shiney brand spanking MP Jet 040 arrived today and its lovely. Lovely, lovely, lovely.
Happy chappy. Many thanks to Sion for the tip-off
Cheers
Phil
phil_g is offline Find More Posts by phil_g
Old Apr 09, 2011, 05:48 PM
Joined Aug 2007
Need more power
I opened the venturi up from 6 to 7mm with a 4mm spray bar going through it
and took out the 0.15mm head gasket , but then the piston was hitting the head
so couldn't run it like that , Its pretty black in there ,,,,, wonder what that means,
not much more options except to get it right on tune
My piston fit may have slackened because I did not clean the lapping paste out well enough or maybe the piston matl is not good or the leanish runs may have lost a little power . I will try and tune for max power today and see if it comes back
I dont want this engine to slow down , it was a lot of fun
Old Apr 09, 2011, 09:56 PM
Closed Account
Joined Nov 2009
Mills 1.3 instruction sheet
Guys, does anyone out there have a nice set of original instructions for an English Mills 1.3 Mk. II, that they could scan and email to me ? I have a NIB 1.3, but for some reason it came only with a .75 specific sheet. My email is - bobshirl@bigpond.com Many Thanks in advance ! BOB
Twin-Stack is offline Find More Posts by Twin-Stack
Old Apr 10, 2011, 02:49 AM
Joined Aug 2007
Hi
Can you use a brass contra piston in an aluminium head ?
I have to put one in , these fixed comp diesels can be hard to start at times , Ive got 2 blood blisters
Old Apr 10, 2011, 07:11 AM
Joined Oct 2005
NX-687, the black soot is common from burnt fuel/oil; synthetics [oils] don't leave much.
Try the brass inside the aluminum, but maybe keep the brass slightly less than real tight.
ABC engines are such that the expansion rates keep the engine from seizing when it gets hot. If the "new brass contra piston" is too loose, it may show up when the engine gets hot...it won't seal. If that is the case, then you will need a tight fit which may stick when cold. Cold starts...try a prime with more ether in the mix (50%?).
Old Apr 10, 2011, 09:08 AM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have seen a number of engines that used a brass contra piston, so yes you can use them.
yeah the black soot is pretty common. It usually is not a problem, I don't remember it building up over time like you see with gasoline engines etc.
As JohnAV8R stated maybe a prime with more ether in it would help.
The early era Drone model diesel engines with fixed compression heads used 75% ether and 25% oil to run no kerosene.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Apr 10, 2011, 09:18 AM
My experience in flying control line stunt stunt with diesels is that loading up in maneuvers is a sign of over compression, missing in maneuver is a sign of a hair too lean.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Apr 10, 2011, 12:43 PM
Chas's Avatar
Joined Feb 2003
And another thing....why do contrapistons wear out? They only move about ten metres in their bores in a lifetime of use.
Old Apr 10, 2011, 03:35 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The wear on a contra piston, comes from the tiny up and down movement during the combustion process. It gets a hard hit upon ignition that tends to cause it to flex and move ever so slightly in its bore. It is where the outer circumference moves up and down while the center stays put (due to the screw that sets the compression). Sort of like a reverse drum, as the center stays put, but the outer edge moves slightly. So the contrapiston is moving hundreds if not thousands of times a second up and down in a tiny fraction of a inch. Then there is the expansion and contraction as it heats up and cools off. So eventually it wears down in the bore where it is at. Usually the contra piston is made from a material that is more soft than the cylinder bore.
Old Apr 10, 2011, 04:18 PM
Gold Coast Australia.
Joined Jan 2005
I do have what your after, but we have a problem with the scanner not scanning into the 'puter.
If you PM me your address I'll copy it and post it to you if you have no joy somewhere else.
My 1.3 is a late one with the RC carb. on it, and the instructions are for both 1.3 and .75.
gossie is offline Find More Posts by gossie
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
Discussion Need help with two diesel engines ! cosmin Engines 3 Feb 17, 2005 05:27 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
scale model of engines dw1122 Life, The Universe, and Politics 2 Apr 23, 2004 05:43 AM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
