Old Mar 22, 2011, 09:14 PM
Joined Aug 2007
Hi
I like the look of that French Micron 5 cc Fixed comp diesel in the Drone article
Looks like a powerful sturdy Controline piece
I was wondering where the first controline engines came from,,,,, and I could not imagine anyone flying one of those big ignition jobs in Controline
NX-687 is offline Find More Posts by NX-687
Old Mar 22, 2011, 09:52 PM
Size Matters!
RocketRob's Avatar
San Francisco Bay Area
Joined Dec 2002
Thanks JMP!
RocketRob is offline Find More Posts by RocketRob
Old Mar 22, 2011, 10:58 PM
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Why not? We had a few guys with big 60s flying on 70' lines, talk about a rock on a string! With all that weight, even wingovers were a hazard.
TLyttle is offline Find More Posts by TLyttle
Old Mar 22, 2011, 11:23 PM
Joined Aug 2007
The French are good
Micron Diesel ,,,,,, Renault F1 engine,,,,,,, Citroen AX,,,,,,best car in the World according to James May
Old Mar 23, 2011, 10:04 AM
Ancaster, Ontario, Canada
Joined Oct 2005
OS 40 diesel
Earlwb has a really nice engine mount for his .40 OS diesel.
See the following link for what he has to say about this engine.
http://www.rcuniverse.com/forum/m_10411369/tm.htm
Is anyone else running one of these conversions?
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Mar 23, 2011, 04:03 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Thanks.
I am thinking about starting a thread in the engines category as the modern model diesel engines with ABC, ball bearings et cetera may not quite be considered vintage in this thread. I also have a Fox .15 diesel conversion I want to play with, as well as a Fox .45 diesel conversion too. Now some folks had used the Fox .15 engines, but they had put in some plugs in the bypass ports to reduce or plug them up to improve the engine's performance. I was thinking that maybe something to reduce the intake might work better, but that is another thread.
I found and bought a couple of different 20-25 size carbs, but I am waiting for them to arrive to try on the 40LA to see how that works or not.
Someone found that the early high compression Saito FA-80 engines worked running as a diesel too. You just don't worry about the glow plug or put in a bad glow plug. So I want to have a go at it myself on my old well used FA-80 and see if it'll run OK or not.
Then I have a Russian 2.5cc Marz engine that had two of the head bolts strip out on it while running, so I was going to fix that and see if it works better or not. I have it apart, I just need to drill and tap it for slightly larger screws.
Anyway, I was waiting for the weekend to see how many engines I can get going to mess around with.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Mar 23, 2011, 04:47 PM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Earl, have you considered Helicoils for that Marz? I saved a Webra T4-40 crankcase that way. The crankcase hardness was somewhere between cream cheese and mozzarella.
Greg
gkamysz is offline Find More Posts by gkamysz
Latest blog entry: A tiny diesel engine AE 0.1CC
Old Mar 23, 2011, 05:13 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
yes I am concerned about that myself. I am going to try to tap for 4/40 screws first and see what happens. If they strip out again, then the metal alloy on the crankcase is really too soft. But one screw did hold up OK and was still tight. So I am thinking they did a poor job drilling and tapping the other two screw holes. or they overtightened the screws and stripped them out when it was assembled.
Unfortunately there isn't a lot of room left for heli-coils. I might have to resort to trying to machine slots for nuts below where the threads are exposed. But it depends on if there is room to notch the cylinder or not there. Of course maybe a little JB-weld is the fix for that too. Another thought was to drill out the hole slightly, maybe for a 3.5mm screw, if there is material for it, thread it and screw in a threaded aluminum plug (better alloy of course, or even a brass plug) using red locktite. Then let it set up good for a couple of days, and then drill and tap that for 3mm screws like they used originally.
Someone else in Australia noticed that on a Marz engine he got, and he pre-empted it by redrilling and tapping the holes for 4/40 screws before he ran the engine. It worked OK then.
I also have to double check the bearings on it. Earlier after removing the cylinder and head, I was turning the crank a little, and it sort of felt a little rough with the bearings, so I need to double check that as I might be replacing the bearings too.
I have another Marz 2.5 and the bearings are bad on it as they have about a 1/32 of a inch forward and backward movement to them right out of the bag.
Plus I haven't addressed the crankshafts either. Some people were advocating stabilizing the cranks so they don't break in some cases. Questionable hardening practices from wherever the cranks were made. But then if it breaks I have something I can copy to make one myself.
Old Mar 23, 2011, 06:48 PM
Joined Aug 2007
Hi
Im not surprised little diesels existed back before WW2,
If you read about the availability of ether, you could buy it over the bar , a lot of people were drinking it , in one place its rate of smuggling was higher than Alcohol ,it was cheaper than Vodka , and you needed less of it to get intoxicated
Earl , the best thing you can do to increase the fatigue life of a crank is to remove all the sharp edges around the rotary port with fine emery paper around 1200 grade
You can retemper it to a lower harness value but that would surely bend the crank and ruin it , and you need a temperature controlled, inert atmosphere , furnace to know just how hot your getting the crank
Old Mar 23, 2011, 11:09 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
When I took my Marz 2.5 apart to redo the head screws, I discovered that the two screws I thought had stripped out, had in fact broke off. I didn't think that the cylinder and head were one piece at the time.
With my micro-drill press, I used a small drill bit to drill a hole into the two stubs (I used a center punch too), and then I tapped in a small hex driver and unscrewed the stubs. The threads look OK, but I'll chase them with a tap later. The screws were really too easy to drill into, which means they are made from a really soft steel alloy of some type. Definitely worth replacing the screws before you ever run one of these engines.
The bearings were horrid, rough and scratchy feeling and they were more or less new. One really needs to replace them too.
It looks like the front bearing is a OD=15mm, ID=6mm, width=5mm. The rear bearing is OD=19mm, ID=7mm, width=6mm.
Boca Bearings closest bearing matches look to be MR696-ZZ and MR607-ZZ.
Before the head screws broke off:
Screws broken off in the crankcase top.
Drilling small holes in the screw and using a hex wrench driver to unscrew the stubs
Broken screws
Marz 2.5 engine disassembled
Old Mar 23, 2011, 11:29 PM
Joined Aug 2007
Earl
looks like 3 soft screws are not up to the running pressures of the engine or the bearings , nice pictures , thanks
Old Mar 24, 2011, 12:23 AM
Closed Account
Joined Nov 2009
Engine test of Frog 50 Mk. 1 & photo's of a Mk. 2 BOB
Twin-Stack is offline Find More Posts by Twin-Stack
Old Mar 24, 2011, 12:32 AM
Closed Account
Joined Nov 2009
Love these old D.A.'s ! BOB
Old Mar 24, 2011, 01:15 AM
Closed Account
Joined Nov 2009
Stuff
Old Mar 24, 2011, 01:24 AM
Closed Account
Joined Nov 2009
More
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
Discussion Need help with two diesel engines ! cosmin Engines 3 Feb 17, 2005 05:27 PM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
scale model of engines dw1122 Life, The Universe, and Politics 2 Apr 23, 2004 05:43 AM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
