Old Jun 29, 2009, 07:07 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Warren, a very nice collection of Mills. They all look like they are new. Obviously you are giving them the care and nurture that a fine old engine deserves.
Do you use anything other than (ether, kerosene) castor oil lubricant in your fuel?
Years ago I had a Mills similar to the one in the bottom left of the first picture. I ran it too hard and fast on a 5x3 prop and broke the rod.
It really was a nice little engine, very easy to start and a steady runner.
Perhaps if you get time, one engine at a time, multiple pics, to show us all their wonderful “lines”.
JohnAV8R is offline Find More Posts by JohnAV8R
Old Jun 29, 2009, 08:01 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
If you still have the remains of the motor it can be repaired
olmod is offline Find More Posts by olmod
Old Jun 30, 2009, 04:27 AM
Warren B is online now
Find More Posts by Warren B
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
Hi John,
I use a reasonably standard brew 40/35/23 with about 2% DII (I think it's iso propyl nitrate). The Mills don't need the addition, but the others like it.
I don't use after run which does tend to make the engines gum up ion teh castor after a while, just gives me an excuse to give them a run (I don't need much of an excuse).
My Mills 75's run on 8x4's or 8x3's. I've tried 7x4's experimentally but theyuse the tank too fast. Can't imagine running a 5x3 - must have screamed. That's the size I use on my Schlosser 0.25 (1/3 the size of the Mills).
Warren B is online now Find More Posts by Warren B
Old Jun 30, 2009, 01:12 PM
Snorks is offline
Find More Posts by Snorks
Africa
Joined Jan 2005
ETA 5 someone say thumper?
Here's my ETA '5' (5cc) about 1948. This one is a real thumper. As you can see it has a choke & cutoff. It swings a massive 16 inch prop & is quite easy to start once you have the technique sorted. NV open 3 turns, back comp off a little,choke almost closed, ex prime... 4-5 flicks later she's away. Open choke as it warms up while leaning at the same time and tweaking the comp...finally refill the tank again. All quite simple really
I did fit an OS prop driver as the original was just a washer on the shaft with no way of posotive drive I've never measured the rpm but I guess somewhere around 3-4000 rpm.
I believe they're quite rare because eta bought out the lovely .29 BB rear induction glow at the same time.
Incidentally I bought a czech repro of the ETA .29 & although it looks good quality it runs quite poorly. I read on a CL forum once that they required some 6-8 hrs running in??
cheers
Simon
Snorks is offline Find More Posts by Snorks
Old Jul 03, 2009, 06:43 PM
JohnAV8R is offline
Joined Oct 2005
A Rothwell, not an Oliver
Here are a few more pictures sent from Peter in Australia.
A ROTHWELL 250 - zoom in on the jpg - crankcase marked R 250.
Enclosed for interest a further attachment, see http://www.smrpl.com.au/
The other smaller engine is an MP Jet 0.6 cc, about the size of the above PAW
The PDF files contain aditional info on each diesel.
Old Jul 03, 2009, 07:26 PM
JackHiner is offline
Find More Posts by JackHiner
JackHiner's Avatar
Joined Jan 2005
John, thanks for the photos and the tip document for the Rothwell 250 engine. I have the little MP Jet diesel I got from David Owen. A nice little engine. Also a GB also from David Owen shown on the test stand. The GB has been flown in a Playboy Cabin for sport flying. I have not built a model for the little MP Jet at this time. Jack
JackHiner is offline Find More Posts by JackHiner
Old Jul 03, 2009, 07:46 PM
Snorks is offline
Africa
Joined Jan 2005
must be the cleanest test stand I have ever seen. Mine was a thick black oily mess until i soaked it in some dishwasher powder and hot water. Whats the blue prop?
cheers
Simon
Old Jul 03, 2009, 08:14 PM
JackHiner's Avatar
Joined Jan 2005
Simon, the blue prop is a Master Airscrew 8/3. I clean the test stand after every use. I let the engnes set a day or so with the piston down and then oil up with automatic trans fluid. In the 1950's and 60's I would use engine oil or 3 in 1 oil. I have never had an engine gummed up with castor. Jack
Old Jul 03, 2009, 08:27 PM
JackHiner's Avatar
Joined Jan 2005
Here is my Playboy Cabin with the GB. Also flown with reproduction Oliver Jaguar 2.5 cc diesel. Jack
Old Jul 03, 2009, 08:51 PM
JackHiner's Avatar
Joined Jan 2005
Here is a photo of my Playboy Cabin and Oliver Jaguar. Also Allan Laycock holding Glen Poole's Viking with a PAW .15 diesel. Allan was visiting the USA from Australia in 2004. Jack
Old Jul 04, 2009, 08:18 AM
scrubs is online now
Find More Posts by scrubs
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
I'm completely diesel illeterate but I ran across this on another forum.
http://www.ronald-valentine-engines.com/
This guys smallest homemade/handmade is 1/10 the displacement of a TD .010.
These things are little jewels with prices to match.
bill
scrubs is online now Find More Posts by scrubs
Old Jul 05, 2009, 04:41 PM
JohnAV8R is offline
Joined Oct 2005
PAW running and maintenance instructions.
Davis Diesel Instructions
Sorry about the poor quality of the Davis instructions. Open in PhotoShop; boost the contrast and sharpen the text and they will be easier to see.
Old Jul 05, 2009, 04:47 PM
patmcc is offline
Find More Posts by patmcc
Northumberland, England
Joined Jan 2007
John, the PAW instructions are on their website. PAW instructions
patmcc is offline Find More Posts by patmcc
Old Jul 05, 2009, 05:05 PM
patmcc is offline
Joined Jan 2007
Here's a copy of a booklet inserted with an issue of Aeromodeller sometime in 1965.
The first page needs to be rotated clockwise to view.
Old Jul 05, 2009, 10:32 PM
Snorks is offline
Africa
Joined Jan 2005
Barton model products also had an excellent 'engines of the world' poster for 1 or 2 pounds.Not sure if its still available. I have one on my workshop wall. Mostly from Aeromodeller but a good reference.
scale model of engines dw1122 Life, The Universe, and Politics 4 Apr 11, 2016 10:39 AM
Discussion Need help with two diesel engines ! cosmin Engines 4 Apr 18, 2014 07:18 PM
Diesel Engines Aeromister Engines 8 Sep 01, 2009 07:17 AM
WTB-Model Diesel Fuel slogo Aircraft - Fuel - Airplanes (FS/W) 3 Nov 13, 2004 09:42 PM
diesel engines wyflyer_55 Fuel Plane Talk 7 Apr 22, 2002 02:45 AM
