Old May 25, 2009, 07:06 PM
flyrcehelis is offline
Find More Posts by flyrcehelis
Why yes, I am an R/C addict!
flyrcehelis's Avatar
About 15 miles from Bristow, OK
Joined May 2009
What's the diff between the EXI 450 and EXI 450 "Squadron" edition?
What's the difference between the EXI 450 and EXI 450 "Squadron" edition? They are both available at www.xheli.com. the only differences I can see is the "Squadron" editon has a different canopy and hex screws. Any other differences that anyone can tell?
flyrcehelis is offline Find More Posts by flyrcehelis
Old May 26, 2009, 03:06 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Which "EXI 450" are you looking at?
the $39 one?
$39 EXI 450
The $39 one has the outer ring plastic instead of metal (no biggie).
I think the tail mechanics on the $39 is actually better. It has an additional C shaped piece on the top of the tail slider.
The $39 has plastic blades and the Squadron has Wood blades.
Melnic is offline Find More Posts by Melnic
Old May 26, 2009, 03:30 PM
MakMov is offline
Find More Posts by MakMov
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
the $39 one?
$39 EXI 450
The frame is all different as well.
MakMov is offline Find More Posts by MakMov
Old May 26, 2009, 03:44 PM
Sky_Dancer is offline
Find More Posts by Sky_Dancer
Sky_Dancer's Avatar
Eatonton Ga. United States
Joined Sep 2004
Can't comment on the Squadron because I've never seen one but I got to say I'm pretty impressed with the $39 EXI. Looks like it's pretty good quality. Of course I haven't flown it yet. The only thing I plan on changing right now is the tail pushrod. Way tooo flimsy IMO.
Sky_Dancer is offline Find More Posts by Sky_Dancer
Old May 26, 2009, 04:02 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Yeah, that tail control wire is very flimsy, bends easy too.
That might be part of my tail issues.
It's not too bad of a flyer. Pretty stable and doesn't get blown around by the wind too much. However, my Trex 250 IMHO flies better. Probably because of the stellar gyro.
I am going to order up a TT and CF PR.
Old May 26, 2009, 04:36 PM
Sky_Dancer's Avatar
Joined Sep 2004
I'm putting quality electronics in mine including a Logictech gyro and tailservo.
Only thing really "cheap" is the airframe and motor. I will upgrade mechanically as I go.
Just trying to figure out now if i need a seperate BEC with my Phoenix 35 ESC. All servos will be digital, might overtax the BEC on the ESC.
Old May 26, 2009, 04:58 PM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
I just helped someone at our field with the $39 EXI from Xheli. It's one hell of a deal. The heli flies very nicely. We had a couple of issues that are worth noting. The pin coming out of the swash for anti-rotation was loose. It has to be glued into the swash. The other not the fault of the heli were the HXT900 servos from HobbyCity. All 4 of the servos had stripped servo casings. We had to CA the cases together.
gquiring is offline Find More Posts by gquiring
Old May 26, 2009, 05:21 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
I've been serously considering upgrading to a Logictech or Align gyro for mine.
It might, but your probably don't need digis on the cyclic. My HS65HBs have been plenty good enough on the cyclic..
Old May 26, 2009, 08:20 PM
Sky_Dancer's Avatar
Joined Sep 2004
Well I'm certainly not capable of anything where I'd need digis on the cyclic but I got three Ino Labs metal geared digis for just a little less than the HS-65MGs. Came from Heli-Direct.
BTW I found the best price on the Logictech combo at Readyheli.com and Grand RC. Don't know how they fare on the gyro alone vs. other places.
Old May 26, 2009, 08:54 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Cool
I got it quite a bit better tonight by moving the ball to the closest hole on the horn.
the Gaui 210 might be better on a smaller heli.
Old May 27, 2009, 09:54 AM
Joined May 2009
i thinkin i might just buy a t-rex 450 metal head and buy the $39 EXI and just install the metal head on it and if i do that i might upgrade the tail too
Old May 27, 2009, 09:58 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
How much will that cost.
There are ebay sellers selling the copterx Head/Tail combo for $50 shipped.
I have that setup that I upgraded my Squadron 450.
Others have done the same.
What's the diff between brushless and coreless? cathode Power Systems 3 Jul 24, 2015 09:51 AM
Discussion What's the diff between Tbird and Phx? Charger Castle Creations 4 Jan 17, 2009 05:37 AM
Discussion What's the diff between 4CH co-ax and 4 channe single rotor? kryznic Coaxial Helicopters 2 Jul 22, 2008 01:14 AM
What's the diff between Heli & Fixxed wing TX? rc capo Radios 1 Feb 18, 2003 12:22 PM
What's the diff. between MAH and AE? Gonflyin01 Electric Plane Talk 3 Mar 19, 2002 05:56 PM
