May 25, 2009, 03:30 PM
Carlsbad, CA
Joined Aug 2004
The "flying Breadboard" is to be used to evaluate all of the components of the UAV system before transferring to the next airframe. We kept a record of each flight and the changes made between flights. I made up a check list and mission log form.
UAV MISSION CHECK LIST
FLIGHT _____
DATE: ______ AIRCRAFT: _______________ LOCATION: _____________
TEMP:______ WIND SPEED/DIRECTION _____/_____ CLOUD COVER_______
AIRCRAFT PRE FLIGHT:
[ ] Control Frequency/ clear (pin) _____________
[ ] Check and record flight battery voltage. _____________
[ ] Check and record other batteries: _____________
[ ] Range Check
[ ] Verify proper CG
[ ] AttoPilot SD Card # installed _____________
[ ] RC Transmitter set to proper aircraft
[ ] AttoPilot mode selection verified: RC, ARC, LARC, AUTO
[ ] Verify number of GPS satellites ____________
[ ] Verify pitot and static tubes are clear
[ ] AttoPilot mode set to RC
[ ] Check aircraft control surfaces move are in correct direction,
deflection
[ ] AttoPilot mode to AUTO, Check control surface movement is correct
for Roll and Pitch
[ ] AttoPilot mode back to RC
[ ] Take off and start timer
[ ] Post flight. Record flight battery voltage. _____________
MISSION LOG
Aircraft Configuration: ___________________________
______________________________________________
Aircraft changes since last flight:
Software (SET) changes since last flight:
Payload: _______________________________________
_______________________________________________
Mission Objectives: ______________________________
WP File configuration:
Flight Data: _____________________________________
________________________________________________
Additional Notes: _________________________________
SET File logged as: _____________________________________
WP File logged as ______________________________________
LOG file logged as: _____________________________________
form updated 05/17/09
You don't need to have a laptop at the field but it makes the tuning process go much faster.
Make sure there is no LOG file on the MicroCard for the first flight of the day. After each flight you should rename the LOG file. If you don't the second flight will have its data appended to the same LOG file as the first flight. That is OK but that can make the Google Earth plot very busy.
I download the SET, WP, and Log files to the main computer after each session and save them as SET.date, LOG.date and WP.date
(ex. SET.05-24-09) That way I can recreate any session if questions come up later.
All of the first phase goals have been met.
1) Demonstrate the ability of an RC airframe under autopilot control to perform tasks such as fly a specified path at a set altitude and airspeed, and release a streamer at a designated point along the flight path.
2) Learn as much as possible about the "care and feeding" and the potential uses of the AUV system.
3) Do all of this at as low an initial cost as possible.
It has taken us 30 flight to get there.
AttoPilot has done everything we have asked of it!
Next - add the 9XTend TX/RX modems to the system for real time flight display and control
Add the video system and test for compatibility.
