This thread is privately moderated by Montag DP, who may elect to delete unwanted replies.
Old May 25, 2009, 01:55 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Cool
"Streak"
Someone made a thread about the Great Planes Electrostreak and I decided it looked cool and I wanted something like it, so I quickly whipped up this. It's got a mid wing and an MH-32 airfoil for speed (I'm open to other suggestions at this point).
It will be my biggest plane yet (I'm planning on building this one before the "Big AP Plane" a few entries down), with a 47" wingspan and 40" length. I'm planning to just make it hand-launch with no landing gear because I think LG is awkward on this type of plane, but it would be easy enough to include removable landing gear too.
I want to prop it for speed with a motor around 300 watts, and a folding prop. If anyone has any suggestions for a motor/prop combo let me know.
It will be laser cut from balsa and ply. The plan right now is to finish the design in the next couple weeks and then build it in August after my internship's over and before classes start again. Wish me luck.
Maiden Flight Video:
Grandpa Bob's Plane (1 min 36 sec)
Aerial video:
R/C Plane over Pendleton, NY (3 min 39 sec)
Montag DP is offline Find More Posts by Montag DP
Old May 25, 2009, 08:12 AM
Chestum is offline
Find More Posts by Chestum
USA, TX, Diboll
Joined Aug 2007
cool. be sure to post building pics and/or video as you go. i would like to see this one fly
Chestum is offline Find More Posts by Chestum
Old May 25, 2009, 11:03 AM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Thanks. I'll definitely keep the thread updated.
Old May 25, 2009, 11:29 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Very Simple 400.. I like it..
Tram is offline Find More Posts by Tram
Old May 25, 2009, 12:16 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Yeah I'm bad at thinking of names. If I ever did this for a living I'd have to hire someone to think of them for me.
Old May 25, 2009, 01:41 PM
nikolaus_c is offline
Find More Posts by nikolaus_c
Always Electric!
nikolaus_c's Avatar
Boise, ID
Joined Jul 2003
Just wanted to make another note encouraging you to update with pics. I've been kinda interested in this plane for some time...The GP ARF looks nice but I just like building stuff myself out of wood...
nikolaus_c is offline Find More Posts by nikolaus_c
Old May 26, 2009, 12:56 AM
AirBorne_AZ is offline
Find More Posts by AirBorne_AZ
Joined Nov 2003
From the sketches, it looks pretty nice! I am thinking, it could also be turned into a quickly-throw-together kind of plane, with the fuse and wings hot wired out of EPS foam.
Are you gonna publish plans? More photos? Could it also be used as a pattern plane?
AirBorne_AZ is offline Find More Posts by AirBorne_AZ
Old May 26, 2009, 10:23 AM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
You probably could hot wire it out of foam, but I have absolutely no experience doing that so I don't know what it would involve.
My usual course of action is to get the parts laser cut and to build them without plans, and then to give the files for the parts to whoever wants them so that they can do the same. My kits don't really need plans since everything keys together, but if other people want to build it it would probably be good for me to make an instruction manual or at least a build log so people know where all the parts go.
Old May 26, 2009, 09:12 PM
Joined Nov 2003
Well, if you plan on publishing plans, I might give hot wired foam a try. Let me know.
Old May 26, 2009, 10:27 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
How detailed do the plans have to be to hot-wire? I could give you the basic shapes of the fuselage, tail and wing whenever and you could cut it as you please.
Old May 27, 2009, 10:49 PM
Joined Nov 2003
Yeh I guess the basic shape and dimensions of the fuse, wing and tail would do. I may use a relatively slower airfoil though.
Old Jun 02, 2009, 11:28 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
This is a great project. I had a plans built Electrostreak. I modded it and built it light. 22oz with a 3S 2100 and Mega 16/15/6 Radared at 87mph out of a dive. Very quiet and floaty. Lost it to a midair (it's second).
feathermerchant is offline Find More Posts by feathermerchant
Old Jun 03, 2009, 06:04 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Cool. I'm going to try to build this one light too.
I'm still working on it but am going slower now because I started work for the summer this week. I should have an update in a few days though.
Old Jun 12, 2009, 11:41 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
I've got a good start on the wing. I've encountered unforeseen difficulties due to the angles - especially since the main spar is swept back and tapers as well. It makes it hard to create the tabs and notches, because it's impossible to get them to fit perfectly since the laser cutter can only make straight cuts into the wood.
I think I'm definitely more than halfway done with the wing now though. I have the ribs, main spar, cap strips, and the leading edge brace and dowel. Now I just need to make the trailing edge and ailerons.
