| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
I'm going flying..........
"The Power System Corner" -INDEX- w/Lucien Miller on AllThingsThatFly&InsideHeli
AllThingsThatFly and InsideHeli podcast are great podcasts, The originals in my opinion.
I find it... 1. Very entertaining. Like setting at the field w/the guys and just BSing about RC. 2. Very informative. Great to hear others comments on products and experiences. 3. A resource. If you know nothing about RC flying and just listened to every episode you could gain A pretty good knowledge of RC flight. One of these resources is "The Power System Corner" sponsored & hosted by Lucien Miller of http://www.innov8tivedesigns.com/ the US dist. for SCORPION Products. I have found myself wanting to go back and listen to specific questions & answers but have had a hard time finding them. SO..... This will be the -INDEX- This is in no way an attempt to cut out the hard work that the Host's(Jamie, Chris, Diggs & James) put into each episode. You would be missing alot if you skipped the full episodes and jumped around. THE -INDEX- I am going back and listening to all episodes and pulling out the episode # and the time stamp of the questions and will form this index as a resource for myself and others, If you don't want it, don't look. All comments and suggestions will be accepted. IE; If you have better/different verbage to describe the question being addressed, that would help other understand what is being asked, please post and I'll ad/change the list. This will be a work in progress, and will be updated/added to.
#2 | |
Introduction of the PSC by Lucien......
#3 |
The PSC -INDEX- To scroll through all episodes on one page. ATTF#71 at 44:15 Motor timing? ATTF#71 at 51:00 What are PWM settings? ATTF#71 at 55:00 AMP ratings of ESC/system at partial throttle? INHE#39 at 6:50 Cell counts for Scorpion motors? & Do motors produce more power at higher voltages? INHE#39 at 6:50 Advantages of higher cell count systems. How does amp+wat rating of motors factor into motor choice. INHE#39 at 14:20 What voltage to run a system at? Also Limits of a Motor. ATTF#73 at 50:27 Basic differences of inrunner vs outrunner? PSC12/08at 0:00 Pros and Cons of BEC's, linear/switching, internal/external? ATTF#74 at 28:00 How to pick prop pitch for speed? INHE#42 at 36:25 A123 & motor kV, when do you change motor kV vs regearing/reproping? ATTF#76 at 44:33 Prop choices for Electric motors. ATTF#76 at 52:00 Electric power system jargin "static thrust" & "prop's unloading" ATTF#76 at 1.00:00 Importance of balancing props and techniques. INHE#44 at 10:00 Setting up for peak efficiency & power. INHE#44 at 12.30 Using Scorpion Calc for heli's. ATTF#79 at 20:58 Paralleling BEC's in a twin set-up. ATTF#79 at 24:38 Dual brushless motors on a single ESC? ATTF#79 at 28:35 Difference of star and delta motor winds? ATTF#79 at 34:40 Efficiency of different types of motors? ATTF#79 at 43:00 Is a motors kV a constant? ATTF#79 at 52.08 Can you rewind a brushed motor? ATTF#79 at 53.35 Glow to Elec conversion guidelines. ATTF#82 at 40:00 Features of new SII Scorpion 30mm motors. ATTF#82 at 42:40 What happens when prop is installed backwards? ATTF#82 at 46:41 12v power source for charging? ATTF#82 at 46:41 Modding PC power supply. ATTF#82 at 55:30 Hot wire foam cutting? ATTF#82 at 58:55 Highend 12v power source. ATTF#82 at 1:03:21 Auto Cig lighter socket charging? ATTF#83 at 55:00 How to decide what voltage/cell count when planing power system? ATTF#83 at 59:05 "C" ratings of LiPo's explained? ATTF#83 at 1:07:55 LiPo's and cold temperatures. INHE#48 at 45:40 Is there a point when increasing system voltage is not prudent? INHE#48 at 51:56 As motor kV drops, does motor power rating go up? ATTF#84 at 50:40 Do the larger out-runner motors have any gyroscopic effect? ATTF#84 at 53:39 Can you use endpoints to control/limit full throttle? ATTF#84 at 57:09 How does running a gear box effect power system requirements? ATTF#84 at 1:00:44 Does throttle trim effect power output? ATTF#84 at 1:04:57 Trimming throttle for flight & ESC brake settings. ATTF#85 at 24:14 Power system wiring adapters & wire gauge/temps. ATTF#85 at 31:31 Wiring system needs. ATTF#85 at 45:15 Length of wires from motor-ESC-battery. ATTF#85 at 58:34 Can you solder motor wires to ESC board? INHE#51 at 24:17 How do you determine a motors kV? ATTF#89 at 53:34 My motor does not freewheel when attached to a unpowered ESC? ATTF#89 at 57:59 What if your motor leads touch/short? ATTF#89 at 59:33 Pros/Cons of using bullet connections from motor to ESC? ATTF#89 at 1:06:09 How do you compare 3 or 4 blade props to 2 blade props. Do 1 blade props exist? ATTF#89 at 1:11:34 Switching from Star to Delta in flight. ATTF#89 at 1:15:09 Overview of motor magnets, limits and cooling. ATTF#98 at 46:15 Servo loads on a BEC. Interaction of servos, ESC, Rx, Etc. ATTF#100 at 39:37 Analog vs. Digital servos of the same specs? ATTF#100 at 45:05 What part of a power system do you pick first? ATTF#100 at 1:06:30 Bullet connection tips. Attf#100 at 1:12:20 Do you really need a high quality motor w/smaller models? IE, superfly or slowstick ATTF#100 at 1:24:52 Scorpion Heli edition Speed controllers? ATTF#100 at 1:39:30 How to spot and prevent cold solder joints. Bullet and Deans solder tips. Crimp vs Solder? ATTF#102 at 1:14:20 At what point do you switch to stand alone Rx power Vs Esc mounted BEC? ATTF#102 at 1:26:50 What does battery cell resistance mean? INHE#64 at 3:25 Running unregulated 2cell 7.4vLiPo as Rx power and the effects on non-HV(high voltage) servos. ATTF#104 at 51:26 Why do motors of same physical size have different max continuous current specs w/different kV? ATTF#104 at 1:00:03 Can you run more than 1 BEC circuit into a Rx? IE; twin motor set-up. ATTF#104 at 1:04:24 Why can't you run 1 brushless ESC to 2 brushless motors? ATTF#107 at 37:50 Digital vs Analog servos? Why do Gyros have a Digital/Analog switch and Rx's don't? ATTF#107 at 52:17 Multiplex, Himax power combos? ATTF#110 at 38:00 LiPo's in Tx? ATTF#110 at 1:09:50 LiPo's C ratings and their size and weight? ATTF#112 at 52:08 Connector power ratings? ATTF#112 at 1:04:00 ESC set to brake off, in a vertical dive motor gets hot? ATTF#113 at 54:00 Motor won't start, just quivers back and forth. W/more soldier tips. ATTF#114 at 33:20 Motor timing settings in ESC? ATTF#114 at 45:26 Multi brushless motors on 1 ESC. ATTF#114 at 47:24 What makes the sound at arming or Music. ATTF#114 at 50:08 Electric power generation off IC engine. ATTF#115 at 1:05:56 NiCd+NiMH, charging of transmitter packs w/stock wall wart charger. ATTF#115 at 1:08:00 How does a charger get the "Auto Detection" current right? ATTF#115 at 1:10:40 Restoring LiPo packs that have been discharged below 3v per cell. ATTF#115 at 1:14:40 Can a brushless ESC be damaged w/a short 2 second "stall" or stopped motor? ATTF#115 at 1:21:18 Unbalanced cells and charging threw the balance port. ATTF#116 at 34:50 Rx glitch, failsafe and antenna aiming. ATTF#116 at 44:38 Brushless motor cogging. ATTF#116 at 52:25 Power supply and charger ratings. ATTF#116 at 59:34 Charging threw balancing taps, revisited. ATTF#116 at 1:06:48 Maiden flight failure after throw bench inspections. ATTF#117 at 1:18:02 Like RC cars why do we not use plastic shells on our LiPos? ATTF#117 at 1:20:12 Pusher vs Tractor props, power, efficiency, etc ATTF#117 at 1:27:45 How long does a brushless motor last? ATTF#117 at 1:33:16 A way to test solder joints? More Deans/general solder tips. ATTF#118 at 41:37 Can packs of differing Mah capacity be used in parallel. ATTF#118 at 45:45 Mixing and matching LiPos. What can and can't be done. ATTF#118 at 49:47 Long explanation of motor Kv. ATTF#119 at 34:25 Electric conversation tips for bigger models. ATTF#119 at 40:38 2 or 4 phase brushless motors for RC use? ATTF#119 at 45:41 Can you put a circuit breaker/fuse in a power system. ATTF#119 at 54:17 Sizing ESC to motor/prop combo. ATTF#119 at 58:25 Changing prop hub width on a folding prop set-up. ATTF#119 at 1:01:30 Power system accidentally left on for extended period of time. ATTF#121 at 54:36 Can I rate/test my LiPo Mah Capacity. ATTF#121 at 56:56 Dual brushless motors start-up at different times? ATTF#121 at 1:01:55 What determines a motors Kv? ATTF#121 at 1:04:20 Is there a weight to power output measurement for a motor? ATTF#122 at 35:14 What type of solder to use? ATTF#122 at 42:19 How does a ESC soft start work. ATTF#122 at 45:38 Setting up a "Idle-up" on electric power system. ATTF#122 at 49:59 How to store LiPo's. ATTF#122 at 54:54 Using slightly puffed LiPo cells. ATTF#122 at 57:40 Using 3cell LiPo in Tx in place of 8 alkaline batteries. ATTF#122 at 1:05:08 3 blade props? ATTF#125 at 46:20 Will adding a capacitor to a 2.4Rx prevent "Brown-Out"? ATTF#125 at 49:42 External BEC's? When to use them. And control surface to servo rating, quick guide. ATTF#125 at 54:10 Compensation for flying from high altitude. Why does my brain ache?
#4 |
Reserved, To be used if additional details need to be added at a later date.
#5 |
sweet.
couple times i have wanted to go back and re listen to stuff that is way beyond my primitive mind's ability to understand. or i simply forgot. this will help a bunch i pulled up 79 the other day for someone to listen about dual motors on a single esc. its at the 24:40 mark there are some others in that episode i.i.r.c. just remember that one specficially from the other day |
#6 |
Someone made a nice compilation episode of all the PSC segments and they posted it on the ATTF site before SEFF. I've listened to it a couple of times while waiting to pick up my kids.
#7 |
Yes but I do not believe it has all the content in it, Does it?
#8 |
Ah yeah. I am there when Lucien does the PSC and I am happy to see this. He has great info and has helped me a ton! Thanks for hooking us up with the index!
Diggs |
#9 |
i you have time make the data into links so people can dl the potcast straight away
#10 |
Good idea, I will look into that.
#11 |
This link will allow you to scroll through ALL episodes on one page.
http://insideheli.libsyn.com/rss Diggs |
#12 |
Thanks Diggs, I added that link to the index header.
#13 |
I am shocked how much material the show/shows have covered in just over 2 years. The PSC's are just a small portion of the total content. I find myself searching for the PSC's and stopping to listen through the hole show instead. Awesome job guys, Thanks
#14 |
Thanks for this! I'm sorry you have to listen to us so much... He is sacrificing for YOU guys!
#15 |
If I here Burkes voice in my head as I fall asleep tonight, I QUIT............
| Thread Tools | |
| Yippee! Another GREAT Bishop Power Sale - 5% off w/ Free Shipping on orders over $20 | BARNESJONR | Vendor Talk | 0 | Jul 03, 2006 09:54 AM |
| Cobra w/floats power system? | JIMOOO | Foamies (Kits) | 0 | Oct 17, 2003 02:56 PM |
| Permax 480 power system w/ESC and 8-cell packs | JohnM | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 30, 2001 08:08 AM |
| Speed 400 power system w/ESC and 8-cell packs | JohnM | Aircraft - Electric - Airplanes (FS/W) | 7 | Nov 26, 2001 10:08 AM |
| FS (USA): Logo 16 w/ power system | lgibjones | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 21, 2001 11:04 AM |
