Old Mar 11, 2012, 02:47 PM
schroeder4 is offline
Find More Posts by schroeder4
Why Yes I Fly!
schroeder4's Avatar
United States, IA
Joined Oct 2009
It's finally finished!
Description: Name: Citabria 1.JPG
Description: Name: citabria 3.JPG
Description:
After about 2-1/2 years my Citabria is finally finished! I still have some issues with my radio to work out before final pre-flight trimming, but then will just be waiting for warmer weather for the maiden flight. Thank you again EJWalsh for creating this bulid log as my plane is certainly better for it.
Bernard
schroeder4 is offline Find More Posts by schroeder4
Old Mar 11, 2012, 04:43 PM
mamethot is offline
Find More Posts by mamethot
Builders Cult Member
mamethot's Avatar
Montreal, Qc
Joined Jan 2007
Beautiful!
mamethot is offline Find More Posts by mamethot
Old Mar 11, 2012, 05:33 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Oh man, is that sweet!
Great finish! Did you end-up painting the white covering?
Please post pics of the maiden when you get to it.
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Mar 11, 2012, 08:48 PM
Why Yes I Fly!
schroeder4's Avatar
United States, IA
Joined Oct 2009
Thanks, it's not perfect, but I'm pretty happy with it.
The paint is one thing I will do differently next time. The white covering is precolored white Solartex, with yellow LusterKote spray can painted trim. This worked well. However, the white cowl, landing gear and struts are painted white with Testors spray can, with Lusterkote yellow trim, and a LusterKote clear over the top to make the Testors paint fuel proof. Unfortunately, the Testors and LusterKote finishes were not entirely compatible, causing some runs and peeling yellow trim when removing the masking tape. It's not very noticeable, except to me, but it was kind of aggravating at the time.
Bernard
Old Mar 11, 2012, 09:07 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
We are always our own worse critics.
I find that the difficulties I experienced during the build all blend-in and go away at the maiden.
EJWash
Old Mar 11, 2012, 10:00 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Gorgeous! I hope you're going to put some pants on!
Maybe a set for the plane might be an idea too.
Curare is offline Find More Posts by Curare
Old Mar 12, 2012, 10:18 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"Thanks, it's not perfect,"
I have been building a LOT of years, and I don't think I have EVER done one that was "perfect", but a lot of other people thought so":-))))))))
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Mar 12, 2012, 10:25 AM
yel914 is offline
Find More Posts by yel914
yel914's Avatar
SLC, Ut
Joined Apr 2010
Beautiful job and ditto on the pants thing.
yel914 is offline Find More Posts by yel914
Old Mar 15, 2012, 04:41 PM
Nav_Aids is offline
Find More Posts by Nav_Aids
Nav_Aids's Avatar
Canada, MB, Winnipeg
Joined Nov 2011
Thrust Line and Plastic
Nice build EJ, a very good read, lots of clever little ideas, and a nice plane. Love to see it painted and flying. Anyway I just wanted to toss in my 2 cents.
In posts #356 - #367 (page 24 & 25) there is a discussion about how the hood line is sloped on the model and the real plane has little or no slope. Everybody agreed that kit manufacturers have to make adjustments so that the model will fly. You were very close to the right idea when you started thinking about the thrust line. We balance a plane's cg nose-to-tail at the wings and the Lateral Balance (left to right).
In order to propel an object correctly (straight) the thrust line must go through the center of the mass. The mass (weight) must be or close to where you have 50% above and 50% below the thrust line. On the real Citabria the fuel tanks are in the over head wing, which makes the plane top heavy because there is not much below the thrust line. In the model the fuel tank is low in the fuselage along with a battery(ies), RX, and servos so now the thrust line has to be a lot lower. I think and I guess the engineers thought a sloping hood line looks better than a flat raised (kind of bulging) hood line. In both cases (Real and Model) the engineers have to take all this into account and make a very good guesstimate where to put the engine for the best thrust line.
A good analogy about how this works would be a toy boat with a keel. If you put the pull string on the right side the boat will want to go to the left when pulled but, will go straight once you stop pulling. In our case the plane will want to ascend or descend under power. You could trim up the radio but, with the control surfaces neutral the plane should not slowly ascend or descend under thrust or wind gusts.
As for the plastic and the crazing, I call them shadow cracks because they will cast shadows onto a sheet of white paper placed behind the plastic. The only way to stop it is to use a mold of some sort that is close to the shape you want and slowly heat the plastic until it can be softly pushed down around the mold. Problem is getting the heat just right; to much heat and the plastic will shrink, thicken, and stiffen, not enough heat and the plastic will still develop crazing. I have found that UV light will cause this type of plastic to become very brittle with age and the UV also causes more crazing. I wish I could remember the type of plastic that I use to use, all I can remember is that it is the same type they use for vacuum molding.
Ray
Nav_Aids is offline Find More Posts by Nav_Aids
Old Mar 16, 2012, 10:47 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"all I can remember is that it is the same type they use for vacuum molding."
PET G.
Les
Old Mar 17, 2012, 08:19 AM
jollyroger is offline
Find More Posts by jollyroger
Central Lake, Michigan
Joined Dec 2002
Great looking plane. I noticed you don't have the wheel pants on, but that's no big deal. They're difficult to keep on if flying from grass fields.
Do you have any close-up photos of the windshield? I'm having a heck of a time trying to get mine to fit and I have no idea just how it is fitted around the upper fuse former that's airfoil shaped. I've ruined a couple sheets of plastic even though I used paper patterns to get it set up. Cutting around the very tight curve at the top of the cabin has been the worst problem.
jollyroger is offline Find More Posts by jollyroger
Old Mar 17, 2012, 01:18 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks Ray!
EJWash
Old Jul 16, 2012, 11:23 AM
Why Yes I Fly!
schroeder4's Avatar
United States, IA
Joined Oct 2009
This thread has not been very busy. We maidened the Citabria and did not like it at all. It is the most squrily, bad flying plane I have ever flown. Luckilly I was able to make a video of it before it crashed due to it's squrilyness. I was really dissappointed I was expecting a lot more from this plane. It cold not even handle a 5 mph crosswind without it flying out of control. I do not think there is anything we can do to make this plane fly well so we are just going to put the engine into a ucando3d .46. Enjoy the video.
(we had dual rates on it and it still flew awfully)
Flying the Sig Citabria: One Last Time (5 min 24 sec)
Old Jul 16, 2012, 11:58 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Well, I watched the video twice, and I couldn't see any "squirlyness" - but I was not at the controls, you were. Your report is appreciated.
I built this kit to take out to the flying field with me so my friends that are not into R/C can get a "taste". I did not build it for any higher performance than that.
I can understand the model being a tad "pitchy", as it has such a short tail moment. I bet that pushing an aft C.G. (NOT saying this is the case with yours) can turn it into a handful...
I waited too long to paint mine, so now I'll have to wait until early fall.
EJWash
Old Jul 16, 2012, 02:23 PM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
I can say my Great Planes version is a bit squirrelly too. I found its more of finding out how they fly.. and what techniques it takes to keep her straight.. and they do take a few different techniques. I would imagine the Sig version is a bit easier then the GP's, as the GP's has a fully symetrical wing.. and is a tad smaller.
Do you have any other experience with a high-wing tail-dragger? Overall theyre just a bit different then a low-wing sport plane.. don't give up though.. you'll get it flying good... I'm thinking its just a learning curve.
DGrant is offline Find More Posts by DGrant
Discussion SIG 1/5 scale Cub MJFinegan Glow to Electric Conversions 14 Jun 08, 2007 09:20 AM
For Sale Sig 1/6 scale Citabria kit. Gerald Aircraft - Fuel - Airplanes (FS/W) 1 May 28, 2006 04:34 PM
Sig 1/5 scale Piper Cub Michael in Toronto Scale Kit/Scratch Built 5 Oct 04, 2002 11:30 AM
