Old May 23, 2009, 05:01 AM
twolter is offline
Find More Posts by twolter
Joined Jan 2009
Help!
Eflite 60 amp esc & eflite power 32 motor
Please help ! I have an eflite 60amp esc and eflite power 32 motor hooked up to a flightpower 4s lipo. I have it connected to my dx7 receiver and all servos etc work fine but i can't get the eflite power 32 motor to run at all. I am new to electrics so any help or suggestions would be appreciated. Thanks
twolter is offline Find More Posts by twolter
Old May 23, 2009, 08:12 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Try putting the throttle trim all the way to the bottom. Welcome to the biggest RC club in the world.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old May 23, 2009, 10:00 AM
twolter is offline
Joined Jan 2009
Thanks Gord. Just tried putting throttle trim all the way down and still no go ... any other suggestions ?
Old May 23, 2009, 10:21 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The ESC should play you some tunes. When it powers up it makes a jingle and follows it with N beeps, where N= the number of cells in your pack. If it makes a different number than 4 (for your 4S) then you need to program it!
Next, when it sees the signal from your receiver, it will play another tune. That tells you it's armed.
If you don't get the second tune, your ESC is not getting the signal from the rx. Try putting a servo on the throttle channel and the ESC (w/o motor) on something else (gear?). Does the throttle SERVO move correctly?
If you have a heli radio, make sure you aren't in Throttle Hold mode.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old May 23, 2009, 11:53 AM
TomM is offline
Find More Posts by TomM
Rust: The poor man's Loctite.
TomM's Avatar
State College PA
Joined Jul 2002
In case you already know this...I apologise, and nevermind,
But TAKE THE PROP OFF while you're experimenting!!!
TomM is offline Find More Posts by TomM
Old May 23, 2009, 11:59 AM
TomM is offline
TomM's Avatar
State College PA
Joined Jul 2002
Do you hear a musical tone, or just 2 beeps when you plug it in?
With the prop off!!, just try putting the throttle stick all the way up(max) and then plug it in. If it arms, and works in reverse, then you throttle needs reversing in the transmitter.
Old May 23, 2009, 06:05 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I take it the ESC is plugged into channel 1?? You might also try dropping the lower throttle end point further down.
Gord.
Old May 24, 2009, 12:23 AM
twolter is offline
Joined Jan 2009
Hi Guys, Thanks for your suggestions.
Tom, I have removed the prop ... thanks for that advice ... could get messy !!! here's a summary of what happens ... first I turn on the dx7 transmitter, then I plug in the battery. I get a long low tone followed by a melody (7 notes), then a short break before i get another quick 4 tone melody (high low high low).
Andy, I tried your suggestion of plugging in another servo to the throttle input of the receiver and it worked. I was able to move the rudder this way.
Gord, I treid the full trottle thing and it didn't work.
Thanks heaps for you help with this .... I really appreaciate you all taking the time to post suggestions.
I might have to drive the one and a half hours to the hobby store sometime this week. The guy there is a bit of a grump and I really can't aford the time.
Happy to hear any further ideas.
Thanks, Troy
Wanted Eflite Power 32 Motor M3Aviator Aircraft - Electric - Power Systems (FS/W) 0 Apr 10, 2008 12:46 AM
Wanted E-Flite Power 32 Brushless + 60-Amp ESC Deaol Aircraft - Electric - Power Systems (FS/W) 0 Feb 17, 2008 12:24 PM
For Sale EFLITE POWER 32, 46, 60... outrunner motors kevin Aircraft - Electric - Power Systems (FS/W) 1 Feb 13, 2008 09:03 PM
Sold Eflite Power 32 Motor - Lowered AGAIN, to $60.00 SHIPPED Bajora Aircraft - Electric - Power Systems (FS/W) 4 Oct 05, 2007 01:38 PM
Wanted Eflite Power 32 Motor e-flythis! Aircraft - Electric - Power Systems (FS/W) 0 Feb 28, 2007 03:51 PM
