Old May 28, 2009, 02:12 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Hi Fred,
I was referring to when WW used the pletti motor in this model.
"The first flight was with a Pleti on 10s and we were registering 5.8 Lbs of thrust, the upgrade to a lenher 2250/16 got that up to 8lbs at 2,800 watts (100mm outlet, did not know better at the time), did not actually improve the performance that much.
How things have move on eh?"
Your Dyn-E-Max worked great for Kevin.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old May 28, 2009, 03:27 PM
Whistling Watts is offline
Find More Posts by Whistling Watts
Braintree, Essex
Joined Mar 2006
Originally Posted by bladexz2
Wasn't that current EDF/motor combination a Dyn-E-Max Fan /scorpion motor?
Mack 1, have fun!
Fred / Dyn-E-Max.com / 317-293-6449
Fred, You are about as subtle as falling masonary LOL!
Look forward to seeing mine arrive in due course
Steve
Whistling Watts is offline Find More Posts by Whistling Watts
Old May 28, 2009, 05:08 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
and why surprise Stu? if it flew on old 120mm 2.5 kw then why wouldnt it fly on 90mm with same watts and thrust but higher efflux of modern sytems. 9 pound sis 9 pounds but higher efflux is always higher efflux. And with a smaller fan pulling less amps then why wouldnt it make more sense in a draggy plane where lotts watts for top end would get lost anyway, so smaller fan less load less mah higher efflux to maintain decent flight speed in draggy model.
monkamarm2000 is offline Find More Posts by monkamarm2000
Old May 28, 2009, 05:40 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Barry, I'm surprised because I heard lots of stories about it being a very bad flier. There was never going to be a problem giving it enough power, but having a model which flies nicely is a different story. If you go 90mm you won't have the same thrust down low, and will need to reach a much higher airspeed for the dynamic thrust to be the same as for a 120mm fan with the same power. That's the issue, as I think it will be speed limited by the draggy airframe. It will probably work fine, though, and if you wanted to make a meal of it you could close off the inlets and go scale and it would work much better. BTW, the fuselage looks a little "tubby" in the pics, is it "tubby" or is it close to scale?
Stu.
stumax is offline Find More Posts by stumax
Old May 28, 2009, 08:27 PM
Joined Aug 2002
Yeah gotcha! know exactly what you mean now. There not the greatest flying for sure, that and there just cheap for me it didnt make sense to throw lotta money in fan into it. And down low is kinda subjective at this power level range (i.e 2-3kw range well within the realm of both fans) big fan makes low thrust at 70 of its 100 lets say and the smaller fan makes same thrust but at maybe 65 or 70 of its 90 in that power range, same watts same thrust, the bigger fan could just make more if ya added more power, otherwise 7 pounds is 7 pounds one just pulls different amps. Yeah the fan is spinning faster to get there but it spins faster all around the band by nature.
Old May 28, 2009, 08:35 PM
Joined Aug 2002
oh! and totally agree again on inlets, they would help alot if they were smaller, but again just couldn't bring myself to dig deep into this one. Plus I have a turbax that'll need a home later and it would make a ideal test bed for it.
Barry
Old May 29, 2009, 01:20 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by stumax
... I heard lots of stories about it being a very bad flier. ...Stu.
It would not have been the first one to get labeled as a "very bad flyer" on RCG - because people just can't set them set up right, and end up with an overweight pig
But this Hawk looks nice esp. for the price. Unfortunately it is a bit tubby, the proportions just aren't quite right. Also, I think 90mm is not going to do it on this one.
Herb is offline Find More Posts by Herb
Old May 29, 2009, 01:36 PM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
This plane is a bit "tubby". it looks a bit better in person but you can obviously see where they cheated in the pics.
It flies good, even at 13lbs 12oz. ... much better than I had expected after going through some of the threads here and on rcu. The flap throw recommended in the manual is a joke, it needs much more.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old Jun 06, 2009, 11:16 PM
kevin is offline
kevin's Avatar
Joined Aug 1999
just charged up the packs to get ready for some flying tomorrow.
The last flight was about 5 1/2 minutes from takeoff roll to touchdown. Capacity put back into the batts just now was 4127mah.
the resistance of the xps 5000 packs (according to my duo) is 51 mohm. anyone else checked theirs?
Old Jun 07, 2009, 01:17 AM
Joined Aug 2002
I checked a bunch the other day and it was 10. Maybe got a bad connector? I've seen times here and there where funny solder or bad deans gave false reading.
Barry
Old Jun 07, 2009, 01:17 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by kevin
... the resistance of the xps 5000 packs (according to my duo) is 51 mohm. anyone else checked theirs?
Normal. My 6-mo old evos are up to 95-100 mO (same charger as yours); new TP's are much lower. Check them again in 5-10 flights...
Old Jun 07, 2009, 03:11 PM
kevin is offline
kevin's Avatar
Joined Aug 1999
No flight on the hawk today. The cc110 went poof on the taxi out....
Old Jun 07, 2009, 03:23 PM
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
WOW it poofed all right! I wounder why that happend? Are you going to try the 140 now?
gunradd is offline Find More Posts by gunradd
Old Jun 07, 2009, 07:20 PM
kevin is offline
kevin's Avatar
Joined Aug 1999
i am going to send this one back for repair/replacement.
Old Jun 07, 2009, 07:50 PM
gunradd is offline
KingtechUSA
gunradd's Avatar
Joined Apr 2009
If you do need to get one the market I think is getting flooded with them since the new 140s came out. I sent my system for update at BVM and they are flooded with old 110s now. I bet they are getting real cheap now.
Discussion Dyn-E-Max Ducted Fan bladexz2 Electric Ducted Fan Jet Talk 1140 Jul 15, 2014 11:37 PM
Discussion Dyn-E-Max variable exhaust nozzle bladexz2 Electric Ducted Fan Jet Talk 10 Feb 04, 2009 01:39 PM
Discussion Tam Jet F-16 w/ Dyn-e-max Eagle15 Electric Ducted Fan Jet Talk 28 Jan 23, 2009 08:33 AM
Hawk sport e conversion info basmntdweller Electric Heli Talk 12 Feb 11, 2003 02:50 PM
Ken Stephens' Curtis Hawk P6-E dave_lilley Electric Plane Talk 4 Nov 13, 2001 09:45 PM
