Old Dec 26, 2011, 06:24 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Ok just to make Phil happy I changed the servo on the elevator
The 645 was pretty old and had to much slop in it for my liking, I am eventually planning on moving this entire setup over to my falcon 120 so I went ahead and invested in a 7985mg so that's 172 oz an inch in torque and digital, way overkill but it was only a bit more expensive so thought might as well do it right since it will go in that huge falcon someday.
One thing that is an issue with this model is thrust tube, fan and elevator linkage alignment. The fan sits so high that the thrust tube will have lots of down thrust but it allows room for the internal flap linkage to clear the fan and the thrust tube will clear the elevator linkage. So moving the fan down helps align the thrust tube but then you are getting close to the flap linkage clearing the fan and then the elevator linkage rubs on the thrust tube. You will find its a big balancing act. I found that a 1/4" lowering of the fan was a good balance but it did creat a rubbing of the elevator horn on the thrust tube so I used a small shaped piece of wood to create some clearence for the elevator and all is good. I do think I have a slight amount of down thrust but it seems pretty minimal.
bri6672 is offline Find More Posts by bri6672
Old Dec 26, 2011, 06:58 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Hi, bri66! Can see my smile?
That a good choice of servo. I think I'll try pick one up too at the coming swap where there will be vendors selling at a very good price.
Have a great maiden.
Phil
PhilLin is offline Find More Posts by PhilLin
Old Jan 11, 2012, 09:09 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Well guys unfortunately I have decided to sell my hawk... I lost my favorite P-47 this past weekend from a linkage failure and the manufacture has agreed to replace it for half off but I'm tapped on planes right now and this one is on the bottom of the list.... If anyone local southern CA is interested I am selling it airframe with linkages and ducting for $200. Bummed to not see it fly but I was also pretty concerned about the 14.5 lbs and think my power system is just to heavy for this airframe and can't afford to loose my power system or lipos since they are going in my new falcon.
Old Jan 11, 2012, 10:52 AM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
Sorry to hear your loss, Bri77. Sometimes mishaps occur when one flies one's models; unless they're kept as hangar queens. Too bad you chose to sell your Hawk. Was looking to hear about its maiden.
My Hawk has gone back one space in my build queue as I try to complete a prior project. Have not had a chance to weigh mine; just hope my hybrid JHH/Haoye 4.5incher fan does not add that much weight. Hear high wing loading is not kind to this model.
Phil
Old Jan 11, 2012, 06:04 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
Phil
FYI, I maidened my AMD Hawk a few weeks ago with a total loss. I had one HS485 servo (I think about 90 in/oz) on the elevator. after take off I made a reduced throttle turn downwind to trim it and on the turn back up wind with increased throttle it didnt want to tighten the turn with increasing elevator. After a wide turn I got it back to the pattern and made another downwind, made the turn to upwind OK, and in a descending shallow dive crossed down the runway (upwind), pulled slight elevator and nothing happened pulled more and nothing happened. when it hit the ground at the end of the runway I was holding full up elevator and it never raised the nose. I think the HS485 was not strong enough for the full flying stab. I have flown other Dynamax powered jets with equivalent servos but they didn't have full flying stabilators. You need strong servos if you have a jet with flying stabs.
rfodor is offline Find More Posts by rfodor
Old Jan 12, 2012, 10:55 AM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
Sorry to hear of your loss, rfodor! & Thanks for sharing your experience. This is the second concrete example of an AMD Hawk stab servo.
I've learned my lesson from my F-4. Now I do a bench test to make sure the whole flying stab assembly can withstand the torque above 160 oz-inz (or 70 oz-ins per side, higher than the servo rating); just to make sure the torque tube is also adequately anchored in the stab panels. Better hav them give on the ground than in the air. You should see how much distortion the panels have at these tests
Phil
Last edited by PhilLin; Jan 13, 2012 at 09:13 PM. Reason: change ground to bench, clarified torque req.
Old Jan 12, 2012, 01:06 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Yeah, didn't Marvin lose one due to stab servo failure? Bummer, it's a nice looking model for the money.
scatsob is offline Find More Posts by scatsob
Old Jan 13, 2012, 01:14 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
His was a stab failure not servo failure from what I read.
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
I think I might keep mine and go with a 100mm fan on 10s to keep the weight down
Old Jan 13, 2012, 05:01 PM
rfodor is offline
Joined Feb 2009
After my experience, I believe that it would fly nice at 12-13 lbs. 14.5 to 15.5 (like mine was) is too heavy. It had plenty of thrust and it definitely flew ok. Maybe if the elevator authority was solid it would have been OK. I won't be trying another.
Old Jan 12, 2014, 05:53 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Two year bump....
Since Bob hooked me up with one, I decided to re-read most of this thread. I missed a lot from the first time I read it.
I believe I have the Will Hobby version. Canopy isn't as bulbous, and the hatch to the fan is really long, and it doesn't have a foam core wing.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jan 12, 2014, 06:26 PM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
My advice, keep it as light as possible or it will be problematic during landing. Mine flew good but was heavy. My dynemax was a beast in this plane.
Kevin Cox flew his on a jetfan 90 on 10s, and it flew well. I would go that route if I was starting from scratch now...to save weight.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old Jan 12, 2014, 06:30 PM
Hawk Fanatic
Joined Jul 2008
I'm flying the FlyFly Hawk at 9lbs with a Jetfan 90 on 8s. This is basically the same thing, but in fiberglass w/ built up wings. My FlyFly just isn't fast enough and I really liked the speed and vert that yours had. I'm just not sure a 90mm will do that. Thoughts?
Old Jan 12, 2014, 06:59 PM
kevin is offline
kevin's Avatar
Joined Aug 1999
To this point, this is still the only edf that I have had that had almost instant acceleration and powered straight up in the vertical ... and I have had a bunch in the last 5 years. In the video I am backing out of the power way before the top of those climb outs. It was definitely fun. But having said all of that, there is a lot to be said for a well behaved airframe as well and at the weight I was at it was not much fun to land unless there was a 10mph direct headwind. I also had to be very smooth on the elevator, no yanking or it would snap out.
I think Kevin Cox was right at 4000 watts, which is only just slightly less than I was running, obviously the dynamx flies the plane with more authority but the jetfan was no slouch. maybe jetfan on 12s?
Have you talked with Bob? I know he was surprised with the performance of the jetfan as well. Hopefully Kevin Cox will chime in...
Old Jan 12, 2014, 09:36 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Kevin is correct on all accounts. Mine no longer snaps and it was playing with the CG and the elevator travel the fixed it. I flew mine first with the E-turbax and 2 motors later (2-3 years of flying) then I put in the JetFan 90 V2. I think it does well and it is only about 3000watts. I am using 5 year old...or older lipos, you gotta love those Rhino packs . A 12S set up would be awesome but I'm happy with 10S. BTW...the E-Turbax had good vertical but not like Kevin's!
Kevin Cox is offline Find More Posts by Kevin Cox
Discussion Dyn-E-Max Ducted Fan bladexz2 Electric Ducted Fan Jet Talk 1140 Jul 15, 2014 11:37 PM
Discussion Dyn-E-Max variable exhaust nozzle bladexz2 Electric Ducted Fan Jet Talk 10 Feb 04, 2009 01:39 PM
Discussion Tam Jet F-16 w/ Dyn-e-max Eagle15 Electric Ducted Fan Jet Talk 28 Jan 23, 2009 08:33 AM
Hawk sport e conversion info basmntdweller Electric Heli Talk 12 Feb 11, 2003 02:50 PM
Ken Stephens' Curtis Hawk P6-E dave_lilley Electric Plane Talk 4 Nov 13, 2001 09:45 PM
