Old May 22, 2009, 06:31 PM
Don Moretti is offline
Find More Posts by Don Moretti
Joined May 2009
Help!
dragon osd current sensor problem
Hi,
I've finally just received my new 100Amps current sensor from IF for my dragon osd. Before I used a 50Amps current sensor from NGHobbies. Before with the 50Amps current sensor the lowest current draw has been not less than 0.2Amps. Now using the 100Amps sensor, current draw is 0Amps.
Is the sensor broken or is there another problem with the new 100Amps sensor I'm not aware of?
I hope there is some1 who can help me.
Thanks a lot!
Don Moretti is offline Find More Posts by Don Moretti
Old May 22, 2009, 11:57 PM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Hi Don,
Two things come to mind immediately - first of all, did you change the IMULT setting in the menu to accomodate the new sensor. If not, you should do that.
Assuming that you did, you should know that the 100A sensor is less than half as sensitive as the 50A sensor, so you will get less resolution with it than you did with the 50A. This is one of the reasons why I prefer the 50A unless I am really drawing that much current as to need the 100A.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old May 23, 2009, 03:53 AM
Joined May 2009
Hi Daniel,
thanks for your answer.
No I didn't change settings yet. Ih hope this will solve the problem.
Now you say, the 50Amps sensor is more precise; is it possible to run it even my max current is up to 80Amps?
Thnaks a lot
Discussion BlackStork OSD - Current sensor pinout jacky65 FPV Talk 0 Jan 06, 2009 05:06 AM
Sold Vizion OSD with current sensor ($50 shipped) + video switch VasMan Aircraft - General - Miscellaneous (FS/W) 1 Dec 21, 2008 05:21 PM
Discussion Black Stork OSD Current Sensor Calibration Question:) danje FPV Talk 6 Oct 31, 2008 01:25 PM
Sold Vizion OSD (V3) with Current Sensor - $80.00 SHIPPED VasMan Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2008 02:39 AM
Discussion Current sensor/limiter dusty IV DIY Electronics 3 Aug 07, 2006 04:13 PM
