Joined Jun 2012
United Kingdom, England, Ware
Joined Aug 2012
Good lead and will go a check out a few cycle shops . |
![]() Maybe the next version. I have a rider in very good condition, with his head. But in 2 pieces lol, so the project is to temporarily glue the head, fill then with foam and maybe something inside (1 or 2 long screws) for more strength. BUT as always, I keep it in mind and will try it later
At least with polyurethane foam. I don't know for other materials... And don't forget: When you mess with polyurethane foam, always use gloves. It's too sticky and you will spend all of your wife's acetone bottles ![]()
Joined Nov 2009
Had to show Ian G's latest creation.
On another note, what oil should I be putting in the rear damper? After going through 50 pages of this thread, I'm tired and not looking forward to re reading the DX450 threads. So far I've found Dave A's suggestion of an extra 1mm hole and 3000 diff oil and a conversion to Revo shocks (but with no reference to spring/oil )Help! |
Im not a nitro guy but that is cool, so good job to the maker.
As for the reading lol JB, I did the same thing AND all the dx450 tip thread pages...shewww! I took notes on everything I was interested in doing to the bike. Its been about 8 months since Ive used the bike - need to fix the owb again. Anyways, I had to dig up my thread about my dx450 to see what I did with the revo shock. Revo used a 3 hole piston maybe 1mm holes and "blue" coded spring, even though color is red. Ive heard of others using 3000, even 7000. I was trying 1000cst. If curious heres my link. Fixing up a dx450 for local dirt track. Once I get bike back up and running I may try the big bore shock that chktm (chris) is using on the mm450, only Ive seen it set up on an m5 in a video before that was installed on the right side of swingarm where that mounting plate is.
Australia, QLD, Burua
Joined Jul 2012
Joined Nov 2009
Ta for the replies lads.
I'll have a read of your thread JMc today. I can't face doing the main DX thread just yet Timmah's thread will be read before trawling that one! The M5 thread seems to be page after page of what brushless setup to use That's an easy one for me. 6000Kv and the biggest battery I can squeeze into the battery tray!I'll give the 3000 oil a bash and see how it goes and maybe buy a Revo shock for a spare and as a comparison. Hopefully it shouldn't take too long to get some nice front to rear balance, something lacking at the moment. I'm either out of balance or the rear is spending too much time in the air rather than on the ground transmitting power. The track I run at is not very smooth, especially at the worst places, the middle switchbacks where I'm losing gyro speed. The 1/8 nitro buggies have dug some nice solid bumps to try and tackle, which is easy for them, not so easy for me Hopefully, by getting the suspension right, I can stop the collywobbles developing because of the diminishing gyro speed. The M5 E-gyro is just too far out of price range at the moment and of course it wont produce the miracle cure when the suspension is wrong in the first place!I'm on a bit of a mission you see, if I can scare them down the straights and make them worried everywhere else then I'll call that mission success! I wont beat them of course outright, but if I can get them worried...
you gotta love the nitro it gives it that little bit extra cool factor.![]()
