Old Sep 25, 2009, 05:46 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Wheelie Bar Mk 4
Well after paying 30 for my second seat and tank unit I thought I would try and make the mother of all wheelie bars !! 3mm piano wire, alloy Rx and body mount. Piano wire slides in to the rear of the mount and then held in with two 4mm grub screws, I have some 4mm wire waiting in the wings but this wont bend will it
steve bisco is offline Find More Posts by steve bisco
Old Sep 25, 2009, 07:02 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Wow, Steve, you're definitely not messing around any more.
Guidoracer is offline Find More Posts by Guidoracer
Old Sep 25, 2009, 07:09 PM
canvey island
Joined Jul 2002
Nah Im going to beat this thing
Old Sep 26, 2009, 04:37 AM
nobita is offline
Find More Posts by nobita
Jerez De La Frontera La Parra, Spain
steve
I believe that seat and tank must go surely screwed that it enlists with something. the material is carbon fiber
http://img147.imageshack.us/img147/9291/cimg2852.jpg
bye
nobita is offline Find More Posts by nobita
Old Sep 26, 2009, 05:38 AM
canvey island
Joined Jul 2002
Well I think this might work, test it to the limit tomorrow!!
Old Sep 26, 2009, 06:05 AM
nobita is offline
other mods
the fork oil
pre charge of fork
Old Sep 26, 2009, 03:56 PM
canvey island
Joined Jul 2002
Nobita, I would not pack out the shock with those washers as when the shock is fully compressed it will lock out the piston rod, it needs to float up in the cap, you will damage the shock, just fit them as they are as they work fine.
Steve
Old Sep 26, 2009, 04:15 PM
nobita is offline
ok Steve
and if I put the washer enters the plastic and the spring B
Antonio
Old Sep 26, 2009, 04:50 PM
canvey island
Joined Jul 2002
Originally Posted by nobita
ok Steve
Antonio
I really cant see what you are trying to do, trust me, just build them as they are!
Old Sep 27, 2009, 06:44 AM
nobita is offline
ok, no problem
thanks
Old Sep 27, 2009, 07:36 AM
mark675 is offline
Find More Posts by mark675
scale microlights
mark675's Avatar
midlands uk
Joined Sep 2004
ok its gotta be asked.. so whose gonna be first to nitro one of these then??
mark675 is offline Find More Posts by mark675
Old Sep 27, 2009, 10:21 AM
Squidlips is offline
Find More Posts by Squidlips
I once beat Colin McCabe
Squidlips's Avatar
Southport, England
Joined Oct 2005
What??
And spoil a great little bike like the M5??
I believe ARX do a nitro version of their bike.FYI.
Squidlips is offline Find More Posts by Squidlips
Old Sep 27, 2009, 11:47 AM
mark675 is offline
scale microlights
mark675's Avatar
midlands uk
Joined Sep 2004
yeah i know arx do one but i reckon one of these would be pretty cool as a nitro,
just out of interest why would converting it to nitro spoil it?
do you mean the extra weight or the added complications (engine tuning etc)?
Old Sep 27, 2009, 02:17 PM
canvey island
Joined Jul 2002
Gave the new wheelie bar a real work out today, pleased to say it worked a treat, spanked it time and time again did not move what so ever another 4 sets of cells gyro still ok, still bonkers fast !! such a cool bike, rear tire finished now.
Old Sep 28, 2009, 05:06 AM
hunterz is offline
Find More Posts by hunterz
hunterz's Avatar
UK
Joined Mar 2007
[QUOTE=spenny]
Originally Posted by t-maxed
Thought id let you all know what ive done to mine so far. Start at front and work my way back.
Front wheel spacers are now alloy and correct size to eliminate the sloppy play, helps to calm down the headshake.
5000 wt oil smeared on piston and fork tubes for some damping of sorts. also tighten everything up as were quite loose. Also cut 5mm off each plastic spacer to give a little more travel.
Shimmed up the headstock so there is no up or down play, this also helps with headshake.
Silicon tubing over the crashback spring and tighten bolts a little more on upper frame.
Rear wheel shimmed correctly in the gyro
what size are the spacers in the steering pivot that you used and were did you put them in the gyro
spence
Hi I want to put some spacers in mine did you get any info
hunterz is offline Find More Posts by hunterz
