Old Sep 13, 2009, 05:24 PM
Jena67 is offline
Find More Posts by Jena67
AR Racing
Jena67's Avatar
Italy, near Milan
Joined Mar 2005
Of course I follow it!
As I do with most of the forum latest threads!
Jena67 is offline Find More Posts by Jena67
Old Sep 13, 2009, 05:29 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Good Man
steve bisco is offline Find More Posts by steve bisco
Old Sep 13, 2009, 05:51 PM
radical ron is offline
Find More Posts by radical ron
I'm not totally useless..
radical ron's Avatar
Drunen. NL
Joined Sep 2003
So, when will the ARX hydraulic forks will be available then, LOL
radical ron is offline Find More Posts by radical ron
Old Sep 13, 2009, 05:57 PM
canvey island
Joined Jul 2002
Anderson Bike forks very simple, but work so good, no leaks after 4 sets of cells.
Old Sep 13, 2009, 06:03 PM
Drunen. NL
Joined Sep 2003
That is as with most good "inventions"...keep it simple. Good to hear the Anderson's are holding up so well!
Old Sep 14, 2009, 02:44 PM
notsoquick is offline
Find More Posts by notsoquick
notsoquick's Avatar
Rochester England
Joined Jun 2006
Hi Steve Bisco
I was at southend offroad track on friday, meet you son, are you going to the offroad meet on sunday at coventry?
cheers graham clarke
notsoquick is offline Find More Posts by notsoquick
Old Sep 14, 2009, 02:57 PM
canvey island
Joined Jul 2002
Originally Posted by notsoquick
Hi Steve Bisco
PM Sent
Old Sep 14, 2009, 04:44 PM
notsoquick's Avatar
Rochester England
Joined Jun 2006
steve PM Sent
Old Sep 15, 2009, 11:32 AM
hunterz is offline
Find More Posts by hunterz
hunterz's Avatar
UK
Joined Mar 2007
Has anyone found a different way of keeping the body on instead of the screws
hunterz is offline Find More Posts by hunterz
Old Sep 15, 2009, 06:06 PM
magnuts is offline
Find More Posts by magnuts
Adelaide, South Australia
Joined Feb 2007
Ruber bands!
magnuts is offline Find More Posts by magnuts
Old Sep 16, 2009, 07:17 AM
spenny is offline
Find More Posts by spenny
UK
Joined Oct 2008
[QUOTE=t-maxed]Thought id let you all know what ive done to mine so far. Start at front and work my way back.
Front wheel spacers are now alloy and correct size to eliminate the sloppy play, helps to calm down the headshake.
5000 wt oil smeared on piston and fork tubes for some damping of sorts. also tighten everything up as were quite loose. Also cut 5mm off each plastic spacer to give a little more travel.
Shimmed up the headstock so there is no up or down play, this also helps with headshake.
Silicon tubing over the crashback spring and tighten bolts a little more on upper frame.
NF steering springs cut down so they are 5mm longer than the std items as i think they are too soft to give a decent response time. Still holds down well in the corners without pushing the front though.
replaced the steering rod end and ball as it was quite sloppy.
Trimmed out the battery tray to allow easier routing of lipo cables.
Rear shock is on the lower holes, with an extra 1mm hole using 3000wt oil, feels really smooth and the rear end now doesnt skip over bumps, just floats really nice.
Layshaft spacers made up to the correct size out of alloy to stop side to side play, and gear mesh set correctly.
New bush for lower shock end to eliminate slop and free play.
All weights remove from giro, still very stable but get more steering response.
Rear wheel shimmed correctly in the gyro
Most screws replced for allen screws.
Oh yeah, and a steering damper too. All these mods have made it an excellent off road bike. I can drive it really hard on gravel, grass and loose/rutted soil no problem at all.
Heres a couple of pics
what size are the spacers in the steering pivot that you used and were did you put them in the gyro
spence
spenny is offline Find More Posts by spenny
Old Sep 18, 2009, 03:56 PM
kennyrccars is offline
Find More Posts by kennyrccars
Elcon Cleon, Hormann HT2 TK 09
Bolton
Joined Sep 2009
Just finished fitting a Mamba Sidewinder Brushless ESC & 5700 Motor, gave it a quick blast up & down the street
The gyro was screaming its nuts off
kennyrccars is offline Find More Posts by kennyrccars
Old Sep 19, 2009, 04:32 AM
Dez82 is offline
Find More Posts by Dez82
Dez82's Avatar
Warwick - UK
Joined Feb 2006
So Kenny, coming to rip some grass up at Coventry on Sunday with the Boys?
Dez82 is offline Find More Posts by Dez82
Old Sep 19, 2009, 04:48 AM
canvey island
Joined Jul 2002
Fitted new alloy swinging arm, looks nice and no flex, with that gyro spinning that fast it twists the plastic one and best of all it looks so cool, anyone fitting the alloy front forks make sure you thread lock the top caps as lost one of mine, but cheap as chips from Steve got to say spares back up is fantastic, bought a new rear tire as the old one is showing some stress good luck tomorrow men hope the weather holds.
Steve
Old Sep 19, 2009, 06:43 AM
Bolton
Joined Sep 2009
Would love to but will be working away from home, even missing this weekends BRCA LSOR at the Nook,
