UK
Joined Oct 2008
Did you say 3S LiPo, what on kit electrics and ESC/motor and it handled it OK? Wow that would be impressive! My standard one works just fine on 2S, can't wait to try it on 3S, unless you changed the ESC and motor first?? Did you? |
canvey island
Joined Jul 2002
Oil Filled Front Shocks !!
My Anderson oil shocks arrived yesterday from Formby Models, (thanks Steve) they work very very well, super smooth and very plush
A bit of a mission to build as the o rings are held in with a C clip which is a nightmare to fit, you only get 2 of them so dont send them into orbit as you will never find them again ! as to how long the will last who knows, but its a good design and there is not any load on the piston rod or seals. There is no mention of the oil to use, I have stuck 20wt in there and it feels good, maybe could go a little lighter, just hope they dont leak as the oil would run down the inside of the fork leg and mix the dirt and make a right mess but they are a good price so worth giving them a go, and like I said they do work well.
canvey island
Joined Jul 2002
Oil Steering Damper
Well I think this must of been made for a different bike
as no way will it fit, it must be 20mm too long, such a shame as the forks were so nice. Will have a play and see if I can make it shorter, or may just do what I did on the oto and that is add some Tamiya friction grease on the steering rod, watch this space.
Steve, I notice your front axle is still behind the centreline of the fork leg, try it forwards mate, much better steering as it's reduced trailing rake and still stable as it's a slightly longer wheel base and gives more clearance to the battery box.
Confused by the steering damper, is that the genuine M5 Cross upgrade that doesn't fit of just a thundertiger one you tried to modify? |
