Old May 22, 2009, 09:54 AM
nikita_flyer is offline
Find More Posts by nikita_flyer
Mason OH
Joined Sep 2007
Herr Piper Super Cub 30'' with floats
I was inspired by light weight builds of Herr kits posted by N2856S and vonJaerschky.
My son asked many times to make plane with floats. So I bought Herr Super cub with floats it is 30'' ws. Ordered already 5g HTX servos 2S 460mAh 26g Lipo and UH1811 10g motor.
Looking on plans right now and thinking - do I really need ailerons?
Or just make it elevator and ruder managed, any thoughts?
nikita_flyer is offline Find More Posts by nikita_flyer
Old May 22, 2009, 04:32 PM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
At that size I would stick with rudder / elevator and make sure you have about 5 degrees of dihedral each side.
Work in Progress is offline Find More Posts by Work in Progress
Old May 22, 2009, 04:50 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Photos ???
I have a friend that is considering this one ...I'm sure he'll be watching
-John
jofrost is offline Find More Posts by jofrost
Old May 23, 2009, 07:35 AM
Joined Sep 2004
They are super cute.
http://www.sigmfg.com/cgi-bin/dpsmar...0_2d_20Herr_01
Old May 24, 2009, 12:04 AM
Mason OH
Joined Sep 2007
Originally Posted by jofrost
Photos ???
-John
Sure
see my edited first message. Rudder is ready.
Old May 24, 2009, 07:47 AM
bosley is offline
Find More Posts by bosley
bosley's Avatar
United States, SC, Beaufort County
Joined Jun 2002
This is going to be cool, I am watching this for sure!!!
Jeff
bosley is offline Find More Posts by bosley
Old May 24, 2009, 08:36 AM
shrub wacker is offline
Find More Posts by shrub wacker
Got Epoxy
shrub wacker's Avatar
Salisbury Ma
Joined Dec 2004
Looking good , I just picked this one up a few weeks ago from a friend , I'll be watching for sure.
Glenn
shrub wacker is offline Find More Posts by shrub wacker
Old May 24, 2009, 08:39 AM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
Glenn
I knew you would find this one !
Old May 24, 2009, 07:12 PM
brennanj2 is offline
Find More Posts by brennanj2
brennanj2
brennanj2's Avatar
Australia
Joined Mar 2005
I am half way through building this one my self, as my first foray into the use of tissue for many years ( back to the sixties in fact). I intend to use doculam for the floats although I really dont expect to fly it off water.
It has been sitting on the shelf part built as I have been waylaid by a Tom Boy ( now completed) and the Fokker M10. But I intend to get back to it ASAP.
It is a cutie thats for sure.
I will watch with great interest, good luck with the build.
John
brennanj2 is offline Find More Posts by brennanj2
Old May 24, 2009, 07:21 PM
brennanj2
brennanj2's Avatar
Australia
Joined Mar 2005
By the way,
After completing both wings I noticed a fair bit of difference in weight between the two wings, that required an amount of sanding to equalise. Clearly the wood weight was a little different. Its not a disaster but forwarned is forarmed.
John
Old May 29, 2009, 10:05 AM
Mason OH
Joined Sep 2007
Originally Posted by brennanj2
By the way,
John
Yep, I find that some sticks have a different weight, think that some was dedicated for wing struts some for wing
I used harder sticks for leading edge and lighter for tailing.
Old Jun 01, 2009, 11:04 PM
Mason OH
Joined Sep 2007
wing and tail surfaces are prepared. Started work on floats while awaiting for the gears from UH.
Old Jun 04, 2009, 09:21 PM
Mason OH
Joined Sep 2007
motor mount to firewall
Using vinyl panel which I had from old guillows kit parts for motor mount. Added some balsa sticks to make motor sits more behind the firewall.
Do we need down and right thrust, If I will use 5x4 or 6x7 GWS prop?
Old Jun 04, 2009, 10:45 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
My guess is yes, you will need a bit of both. With no right thrust, my L-19 won't turn right at all.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jun 05, 2009, 11:05 PM
Mason OH
Joined Sep 2007
Thanks for advise. Will add then washouts under vinyl panel.
Piper Super Cub SoaringDragon Scale Kit/Scratch Built 3 Jan 26, 2003 04:59 AM
Buheur Piper Super Cub Park Flier airplane WITH speed 400 pval3 Aircraft - Electric - Airplanes (FS/W) 0 Jan 14, 2003 09:34 PM
Buheur Piper Super Cub Park Flier airplane WITH speed 400 motor. pval3 Aircraft - Electric - Airplanes (FS/W) 1 Jan 13, 2003 10:06 PM
Piper Super Cub 95 (Electric Conversion) genovia Electric Plane Talk 0 May 24, 2002 09:14 PM
Article The Herr Piper J3 Cub and the Hobby Hangar 1/2A Super Cub Robert Buonfiglio Electric Plane Talk 0 Mar 09, 2000 12:00 AM
