Kuala Lumpur, Malaysia
Joined Jul 2007
WOO HOO!!! It looks like it's a go for you KoneWone! I think you've just inspired me to get moving on mine too..... bought all the parts and everything for her yonks ago but never really got going because I'm trying to strip off the old paint (not easy when it's 15 year old aerosol spray and you're dealing with ABS under it) and I haven't figured out how to give her a timber deck.
Once I've figured out the timber deck I'll STILL use the holes around the gunnel for their intended purpose- to install the stanchions for the pulpit railing (which you can buy replacements for) and install the timber over the rest of the deck. It's amazing- Fairwind is well over 20 years old but is still one of the better yachts out there and still available in GenIII guise today. Definitely one of Kyosho's masterpieces.... and parts are still readily available. Sails, rudder, NO PROBLEM! Oh... but junk the servo board. The consensus over at the Fairwind's home page here is that it's rubbish. I'd tend to agree and when I rebuild mine it'll be just a solid piece of plywood epoxied into the hull with just cutouts to receive the servos. Do it that way and you can use a 1/4 scale sized proper sail winch servo- in my case it'll be the Hitec HS785HB (also already bought yonks ago) which'll give it a nice "scale" gradual sheeting-in action! Go for it mate...... I might just get started (again) on my own Fairwind's restoration and tag its story to this thread! Darth |
For all the faults of the FW, it still is a good boat. Best of luck with your project.
A few pointers from my building experience. I built 20 boats for the local yacht club. Scrap the radio box and use cross beams (suggested in an earlier post). Fill the corners of the transom with a little epoxy and filler. Use wax to hold the ballast in place, not epoxy. Epoxy gets too hot! The Bakersfield building guide is great, and you can find lots of info on line. Keep posting pictures of you progress. Dave
Wooden decking experiment
Thanks for your tips Dave I will incorporate those into the old girl
![]() Well today was experimentation day with wooden decking, couldn't find anything on the net on the subject so had burn a few brain cells & I don't have many of those anyway, whipped down to the local model shop and picked up a few strips of balsa 2.5 mm thick.Started thinking that all the problems working with strips, glue and silicon so first attempt was to cut small strip and use black ball point to imitate the lines on wooden deck, thinking if it looks ok I would cut a cardboard template of the deck and transpose it on balsa sheet and draw lines, well as you can see from the pic’s it looks ok ... but close enough ain't good enough for me, it’s gotta be perfect Cutting strips of equal width is a hit and miss exercise so made up a jig which mounts knife blade onto it and bingo works perfectly. Next instead of gluing planks to the deck, found double sided carpet tape that is strong as hell, stuck it along one side of the deck and then simply followed the line of the rail with balsa strip ...bloody riper ! it bends nicely cool Only had grey silicon in the workshop so ran a line along the gap, recessed it by running my finger along it and then using straight edge scraped the excessive silicon off ....unbelievably easy and looks great Ok it’s only an experiment and it works, now need to consider the pro’s and con’s of using balsa for the deck. Need to waterproof it (wood sealer should do the trick) Should use double sided tape of glue (holding strip into place while glue sets is a pain in the butt) Need to put little tint in the varnish to give that TEAK DECK look, but not sure how balsa going to weather ? ... sigh !!! ...
