YEP. I thought I had a better picture of it somewhere but cant find it anywhere. Its just a stiff wire bent in 2 places. On end goes along the edge of the elevon and taped in place. Other end sticks up a bit with a control horn like old school torque rods did. I am very happy with this setup as it has proved very durable in very heavy combat useage.
Latest blog entry: Swith in battery chemistry for all my...
Could you please post some pictures details?
Tks, Quote:
Hi friends,
Sometime ago I went to the www.utahflyers.org and got LeeŽs foam cutting tutorial and found plans to be used. I made the Assassin airfoil using an airfoil similar to the Clark Y 18%, as the following instructions: 8. Make your one piece jig as described in the foam cutting text using the top of the SD7032 airfoil over the bottom of the SD6060 enlarged to 9". My foam cutter has 39" cutting area, and IŽll follow LeeŽs instructions to cut the cores without variation, As IŽll cut a wing with is 24" long, that means the anchor will be around 48" from the jig. IŽve already tried to cut the cores some time ago, but when I were cutting with my foam cutter, I was lazy in the cutting speed and I damaged the foam. Now I have tu buy a new block and try again.. Below some pictures from my foam cutter and the first wing I did (not the assassin yet ) Also a picture from the jig I did.Thanks again Lee for all of your help. Happy New Year for all!! |
I just bought a couple of these to tape to the Assassin, Titan, and Roswell for some bird's eye video. I have been waiting for a light and simple video camera that is a start and fly to get the effect of hitting streamers and flying limbo that wasn't so expensive that I would feel bad if they got destroyed.
I know our club is ordering several so it should add some fun video to these sites. http://www.chucklohr.com/808/#SystemMode |
Check out this video made with one of these key chain cameras. http://exposureroom.com/members/Flyp...f271ca77e739d/ I hope we can remedy the wavy problem when under power.
| Thread Tools | |
| WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 22 | Sep 23, 2009 06:56 AM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 04:05 PM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 0 | Jan 28, 2004 12:40 AM |
| Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 01:05 PM |
| It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
