Old Mar 05, 2013, 09:28 PM
tupeloflyer is offline
Find More Posts by tupeloflyer
Dixie Sky Devils
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
Originally Posted by Skeetpf View Post
I am completing an Assassin and am wiring it up. The build went well, but I have a problem. Both elevons are working correctly but when I connect the motor and hit the throttle my port elevon goes up. I'm using a Red Brick ESC. On my other wing which is wired the same, the only difference being the ESC everything works correctly.
What am I doing wrong??
Thanks for the advice on the build, now if I can get past this issue I may be able to get it in the air this weekend
Skeet P
What Rx are you using? it sounds like the BEC might not be working correctly? is there programing instructions with the ESC? never had that issue? your ESC does have a BEC built in right?
tupeloflyer is offline Find More Posts by tupeloflyer
Old Mar 05, 2013, 09:35 PM
foamyflyerr is offline
Find More Posts by foamyflyerr
Joined Jun 2012
That does sound curious
After what Blu and I had to go through to get mine programmed to my DX 6i nothing surprises me any more
At least I got mine worked out now , thanks to him
foamyflyerr is offline Find More Posts by foamyflyerr
Old Mar 05, 2013, 09:39 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Skeet P
Check your programable mixing. You might have them mixed together.
Lee is offline Find More Posts by Lee
Old Mar 05, 2013, 09:40 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Hey! your story has got me brainstorming! Haha! just joking!
I have seen it done off snow.
Old Mar 05, 2013, 09:44 PM
Joined Jun 2012
What about swapping out the esc for test purposes
I had problems with the first ESC I was using.
My motor was like only working at 1/4 speed even at full throttle
I put on a Castle Creations Thunderbird 56 amp esc
Over kill I know, but I had it around so I used it.
Now the Assassin flies great , and fast too
Old Mar 05, 2013, 09:45 PM
Joined Jun 2012
Lee thats a thought too
good thinking
Old Mar 06, 2013, 04:56 AM
Skeetpf is offline
Find More Posts by Skeetpf
United States, NY, Lancaster
Joined Feb 2003
Thanks for the quick advice
1. It's a Hobby King Red Brick 30 amp ESC. with BEC. It came without programing info
2. I was thinking transmitter programing - but on the other wing with a different ESC all works fine
3. I'll check programing of transmitter (Hitec flash 5). If that doesn't work I'll try a different ESC
Thanks again for the help -
Skeet p
Skeetpf is offline Find More Posts by Skeetpf
Old Mar 06, 2013, 07:50 AM
Joined Jun 2012
Skeet p
Every time I have used a Castle Creations esc it has just plugged in and worked with no issues.
They are programmeable but if your not using throttle brake you do not need to program them.
I had one build on a SU - 31 where the motor was doing wierd things.
Went to LHS "B"and he told me that the motor that LHS" A" had sold me was a P.O.S. He tried to sell me another motor. I went back to LHS "A" and he knew what it was immediatly. He hooked up a test esc to the plane and the motor came alive. 150 flights later this P.OS. (according to LHS "B") motor is working no problem and does everything I ask it to do.
Old Mar 06, 2013, 05:27 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
hi friends!
Finally the FULL HD video!
Asa voadora (3 min 18 sec)
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Mar 06, 2013, 05:49 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
wow that is an incredibly tight area, i wouldn't trust myself flying
viper522 is offline Find More Posts by viper522
Old Mar 06, 2013, 08:40 PM
Joined Jun 2012
Originally Posted by Luis_Claudio View Post
hi friends!
http://www.youtube.com/watch?v=3s3e-sX5tMs
Very cool Luis
Nice flying :-)
Old Mar 06, 2013, 11:29 PM
KC Flyer is offline
Find More Posts by KC Flyer
KC Flyer's Avatar
Lee's Summit, MO USA
Joined Jan 2001
I love the "little red motor" it's a great motor for the $! I've been stock piling them since I quit smoking, a couple a 2812's a week is still way cheaper than a couple a pack's a smoke's a day! and the mount coming loose issue is a easy no brainer fix... BTW, just ordered a Widowmaker!! my assassin is lonely want a do some painting on this one, but can't find paint & graphic tips on thread? can someone tell what page they are on?
If you like the stock red motor, you will absolutely love the rewound red motor.
Go to this EMAX FC2812 Rewind Link for more info.
KC Flyer is offline Find More Posts by KC Flyer
Old Mar 07, 2013, 06:27 PM
Dixie Sky Devils
Joined Oct 2012
I know I'm trying my hardest to burn one out. I might just rewind one anyway. never done it before, but my friend works in a motor shop winding big motors and I'm a electrician. surley between the 2 of us we can figure it out.....
Old Mar 07, 2013, 08:05 PM
Skeetpf is offline
Joined Feb 2003
There must be a programing issue with the HK Red Brick ESC I was using (it's brand new). Or it is flawed. Today I went to the LHS and purchased a Castle ESC - installed it, no problem. everything worked fine.
Weather is improving here in WNY, should be able to maiden her Saturday
Skeetp
Old Mar 07, 2013, 09:06 PM
Dixie Sky Devils
Joined Oct 2012
Skeetp
Now that I think about it, I did have a ESC in a P-51 with retracts, and when raising or lowering gear the elev would move a little? got a better ESC and problem went away... I think the BEC was weak and retracts were pulling too many amps and was interfering with the Rx??
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 05:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 12:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
