United States, MD, Kensington
Joined Dec 2008
I've never had a problem with the length, but I think the best advice I ever saw here was if you do shorten the shaft, don't let the metal filings get sucked into the motor. The poster suggested wrapping the motor tightly in a baggy.
Joined Jun 2009
Motor shaft
Positioning the prop mount right up against the motor housing reduces the chance of bending the shaft on a hard impact. Good luck. |
The motor shaft is hardened and easy to bend as you try to cut it. I only tried once and I got such a wobble in my prop I haven't tried again. I scoot my prop saver forward to where the prop is near the end of the shaft and mount the prop with just the end of the shaft poking through.
United States, CA, Carlsbad
Joined Apr 2012
Have an assassin that someone gave me and can bind it on my dx7, use delta configuration, but can't get the right setup. I guess my question is, can anyone walk me through a dx7 setup? I'm wondering if I have to reverse the servos...
Page 46 here covers the servo channels for DELTA (DX7Manual) Left elevon goes in aileron channel and right elevon goes in elevator channel. |
United States, CA, Livermore
Joined Jan 2012
You really can't tell which servo has to plug into which channel. Get the up/down part working right with TX reversing. Both move up with stick down and both move down with stick up. Then go stick right. If its backwards, just reverse the the servo leads at the RX.
United States, FL, Palm Beach
Joined Jan 2011
Here's a MSComposit Swift II chasing my underpowered (I think) Assassin. Tried to put some moves on him but the dude can fly. I'm flying LOS with about 3 batteries of experience, he's obviously flying FPV. Good fun.
If you can't get the different combinations of reversing switches to work, trade the servo plugs in the receiver and try again. |
| Thread Tools | |
| WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 22 | Sep 23, 2009 06:56 AM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 04:05 PM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 0 | Jan 28, 2004 12:40 AM |
| Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 01:05 PM |
| It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
