Lee's Summit, MO USA
Joined Jan 2001
Yea! We did it the Titan is fixed. In order to cut the left-wing straight by the time I finished cut it would've taken nearly 1 inch out of the end of the wing and I figured the elevon would not matchup right. So I went to Lee's plan B I cut a relief slot in both elevon's, made three sets of tape hinges for each elevon, then bent the elevon to match the wing, taped them. Then I cut a relief slot in the middle of each, covered each hinge with laminate as well as the relief slot. Then taped on top of the relief slot top and bottom and finished all with laminate hinges full length.
It works just great and that damn laminate is tougher than Superman's kneecap. The elevon's move just fine and are as stiff as wood. Thank you Lee and everyone else. We did it! A grateful DJ |
Well I got my Titan straightened out and began to decorated it. I'm done with the bottom and I have a design for the top. I thought I could use a flame design that I downloaded printed on transparent paper, the flames did not work, once the white background is peeled off the transparent film the color just isn't there. So I change the plan for the topside and posted a photo of my intention.
Thanks again y'all for getting me out of that warped airplane warped elevon situation that I woke up to this morning. I want to depart completely from the equipment location instructions in the usual instructions. This is not a criticism! I want to put all the mechanical equipment, battery ESC and servos in the bottom of the plane. The only thing I want to see on top are the tips of the servo arms and the control rods. I know I need to think about how well protected they are on the top. The way I fly all that stuff is in danger anyway. I want to walk back to the flight line casually drop my Titan on the concrete without breaking stride. There will be nothing on top! Please don't be offended by my ignorance as to why this might not be a good idea. On the bottom side I intend to put the battery in wide side down. I will cut a discrete track to hide the balance charge plug. I'm creating this plane as I describe it to you. In the arts we call it chalkboarding. It's a situation where you have no need to hear it it's speakers need to say it. To say it requires all the thoughts be organized into a verbal form so the second stage of creativity can begin. Actualization! I'm trying to figure out a way to keep servo horns from even protruding above the surface. I don't know if there's room for that yet. I know this is all about impression management but as a sculptor that's just what I do. "Half the fun of going is looking good getting there'. DJ tell me how to accomplish this! Or the best we can do toward that end |
If I'm going to set up the elevon servos in the bottom of the wing can I not take those servos and move them out to the middle of the elevon? I have an assassin and I never like the fact that the control device was trying to move the elevon from its edge instead of the center.
DJ, just wondering why |
Remember the purpose of this plane was combat. We found the best way to protect the radio and battery and prevent them from ejecting out the bottom was to mount them in from the top. We had some comical battery ejections during testing and found that ejection was much less likely if the radio was inserted from the top.
We also kept breaking the servo arms off with servos under the wing. If we buried the push rods we would have the wing break along the push rods so we came up with our present building design. I am always interested in what people come up with. Keep us informed. Nothing wrong with a little testing and modification. |
| Thread Tools | |
| WALLY WING...no fins...flies great!!! | gpw | Foamies (Kits) | 22 | Sep 23, 2009 06:56 AM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 6 | Jan 29, 2004 04:05 PM |
| Qjet Flamingo & Butterfly: A plane no one has!! | romans1015 | Parkflyers | 0 | Jan 28, 2004 12:40 AM |
| Noob concept plane | Mikey C. | Foamies (Kits) | 5 | Nov 11, 2003 01:05 PM |
| It's a boat...It's a plane...no! It's flightship! | MrBungle | Electric Plane Talk | 24 | Jun 26, 2001 01:55 AM |
