Old Nov 21, 2012, 05:48 AM
BlueDevil is offline
Find More Posts by BlueDevil
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
Another question.. with the same rewound 2812.. which plane would be faster.. the Assassin or Widowmaker?
BlueDevil is offline Find More Posts by BlueDevil
Old Nov 21, 2012, 06:52 AM
CaribbeanBlue is offline
Find More Posts by CaribbeanBlue
Joined Jul 2010
WM has a much thinner airfoil >> should have less drag
Speed increases until thrust equals drag in level flight with weight balanced by lift
ie slower in a climb, faster in a dive with gravity helping~~~~H
CaribbeanBlue is offline Find More Posts by CaribbeanBlue
Old Nov 21, 2012, 09:47 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The Assassin is naturally a stronger and stiffer airfoil because it is almost twice as thick as the Widowmaker. If you are going into the hyper speeds with the Widowmaker you may want to stiffen it up a little with and extra spar or more aggressive taping. The Widowmaker won't break but it might flex at super speed. It is potentially the fastest airfoil but we have designed the construction around 80mph top speed and the 2812 motor.
Another note. I was flying a high speed Assassin the other day and the servos were stalling at the high speeds in maneuvers. I hit the ground at about 110+ because the servos weren't big enough to do the job and make sure you have maximized leverage so the servo isn't being stressed by how you install your pushrods. I would have to slow down to make the turns. Make sure that your servos can handle the speed too.
Lee is offline Find More Posts by Lee
Old Nov 21, 2012, 05:10 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Slightly off topic.. My first scythe is done pretty much, built with the suggested gear from the site. Flying a 3s 1800... Does this little bugger need to rip pretty fast for nice cruisin. Is its cruising speed faster or slower than the assassin witg 2200.. Only other battery option ive got is 3s 1000 or i can buy a better fit bat
elliott000 is offline Find More Posts by elliott000
Old Nov 21, 2012, 06:13 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
A 3s 1000mah should work fine on the scythe.
I don't think anybody is recommending an 1800mah for that plane...
jetpackninja is offline Find More Posts by jetpackninja
Old Nov 21, 2012, 06:24 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
I safe to fly my assassin with my Hitec Aurora 9 and a Minima 6E receiver? I am asking it because I had problems
using a Optima 6, 3S lipo 1.3 mah. The Hobiking 30a esc was not powering properly the receiver...
As I bought a GWS esc and it didnīt arrived, I would like to fly my assassin with anothyer setup, while it arrives to me.
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Nov 21, 2012, 11:56 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The lighter the plane the better it flys. To put a big battery on a Scythe makes it hard to launch and it will land fast.
I like the 3S 1000 on my Scythes. I do fly the 1300 3S at times but it takes a harder throw to get it airborn.
Old Nov 22, 2012, 01:18 AM
Joined Feb 2012
How much time do u see lee on the 1000 average power flight. By the way i went from no CTH planes to 5 in a months time lol for anyone wondering about they are sweet to fly and crash
Old Nov 22, 2012, 03:49 PM
Joined Feb 2012
Back to the assassin, i find mine drops the nose but im pretty sure my cog is good. And if i trim it much more or give full ele back i can stall it some, still climbs but not as id expect. Am i nose or tail heavy cuz i remember tuning up my radian pro and if it dove it was tail heavy? Or am i out to lunch lol
Old Nov 22, 2012, 04:24 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
If your cg is correct, you're, by definition, neither tail nor nose heavy. Where does the plane balance, front to back?
elCapitan is offline Find More Posts by elCapitan
Old Nov 22, 2012, 04:26 PM
Joined Feb 2012
Teeters nicely at 6 3/8 of an inch.
Upon further inspection i noticed my motor mount may have been slightly bent forward so instead of it being 90 degrees it was for sake of example 75... Would that thrust direction give me nose down
Old Nov 22, 2012, 06:24 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
that was going to be my next suspicion
Old Nov 23, 2012, 12:39 AM
Joined Feb 2012
Havent had a chance since my last flight to try but im thinkin thats it. When id give more throttle it would dive harder.
Old Nov 24, 2012, 03:11 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Hobbyking are on backorder with the
FC 28-12 Brushless Outrunner 1534kv motor
http://www.hobbyking.com/hobbyking/s...%5F1534kv.html
anyone recommend any other motor from Hobbyking.
how about this one ? http://www.hobbyking.com/hobbyking/s...r%5FMotor.html
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Nov 24, 2012, 09:28 AM
Chico John is offline
Find More Posts by Chico John
Joined Jun 2009
Stick with the 2812
Sean
Check here http://www.planeinsanerc.com/index.php?PageID=12
If this you first build stick with the 2812 for now and buy at least 2. Good luck.
Chico John is offline Find More Posts by Chico John
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 3 Sep 04, 2016 05:47 PM
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 32 Aug 31, 2016 08:21 AM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
