Old Nov 20, 2012, 06:46 AM
BlueDevil is offline
Find More Posts by BlueDevil
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
Originally Posted by elCapitan View Post
Comparable, but not much more than that. Although, if you take that little red motor and re-wind it with 9 winds of 24g MicroDan wire... zoom!
That said, you mentioned looking for a "bigger sized wing." Have you looked at Crash Test Hobby's Grim Reaper? A little more size, and easily 65-70mph with the standard recommended 3530 1800kv motor (PlaneInsane also sells).
I actually did look at the Grim Reaper.. I just don't know if I want to go that big.. TOO many choices haha
What about using one of the recommended setups for like the Grim Reaper or other larger wings on the Assassin?
BlueDevil is offline Find More Posts by BlueDevil
Old Nov 20, 2012, 06:55 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
It's been done, but obviously ups the weight. Make sure you get your CG right.
That's one of the nice things about re-winding a little red 2812. It's easier than it sounds, it's actually kind of fun to do the re-winding, it doesn't change the weight of your wing, and keeps everything nice and light, but multiplies the power. And the wire only costs about $12.
Not too many posts ago in this very thread, we included links, videos, and diagrams of the most popular re-wind for an assassin. I love my Assassin with the re-wound 2812.
That said, I'd still say take a second look at the Reaper. It's definitely my favorite plane overall, and easy to make fast, especially if you go to 4s on the batt.
elCapitan is offline Find More Posts by elCapitan
Old Nov 20, 2012, 07:17 AM
blunight is offline
Find More Posts by blunight
Chess club geek with wings
blunight's Avatar
United States, FL, Cape Coral
Joined Aug 2008
I agree. With the NTM Propdrive 3536 1800 KV motor, 4S and a 7x6 prop you get a plane that is faster than a Assassin with a rewound 2812 - and as a bonus, it's easier to fly and glides really well. It also pulls 2, 20 ft streamers with ease.
Trent
blunight is offline Find More Posts by blunight
Old Nov 20, 2012, 07:33 AM
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
Trent
what Mah 4's do you run with that setup?
Old Nov 20, 2012, 08:10 AM
blunight is offline
blunight's Avatar
Joined Aug 2008
It's a Turnigy 30c 2.45 mAh 4s; puts out 877 watts with the 7x6 Hobbyking prop.
It's good for 5:30 flight time - combat flying pulling streamers with more than a few full power passes leaves about 3.79 volts per cell at the end of the flight.
Old Nov 20, 2012, 08:46 AM
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
Ok, I'll have to study a little and decide on whether I want to go as big as the 55" reaper.. dunno if I want to go that big so I may just go with the Assassin..
So the rewinding of the 2812 looks simple enough.. if i go that route with the rewound 2812, which prop/esc combo would I need and would it handle a 4S battery?
Should I stay away from the radio shack wire as some has suggested?
Thanks again for all the advice!
Old Nov 20, 2012, 08:56 AM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Just go with the HeadsupRC Powerup 370 Zoom motor. Bolts on, we use it, and it's stupid fast. It's been reliable and it's inexpensive. 6x4e APC prop. Our combat videos here will give you an idea of the speed, page 422 Foamyflyerr vid.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Nov 20, 2012, 09:29 AM
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
Blu
any difference in the EMP 6 X 4e ?
Old Nov 20, 2012, 09:47 AM
Vurtdog is offline
Find More Posts by Vurtdog
United States, TX, Houston
Joined Dec 2011
Originally Posted by Lee View Post
I put the 3mm screws in my motor bases before I ever fly them. They are much more reliable but beware!!! You can over tighten them and either strip the threads or bend the bearing in the motor. I use the lock tight too as you can see in the picture below but don't get it in the bearing.
Thanks for the picture, I didn't realize that there were two screws.
Vurtdog is offline Find More Posts by Vurtdog
Old Nov 20, 2012, 10:47 AM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
@BlueDevil
I don't know anybody that has tried the little red motor on 4s. You're on your own Take notes and report back.
EMP vs APC- Can't speak for the 6x4 range but in a 7x6 The EMP style pulls more amps than the APC versions. Enough so that I smoked a couple of 3530 motors before I figured it out.
Do you have a wattmeter? Get a wattmeter!
If you decide to rewind, go for it. It's easy enough and it's bang for the buck the best upgrade you can do </ninja opinion> Definitely stay away from the Radio Shack wire. I have burned every motor that I have rewound with that stuff, the MicroDan high temp wire is the way to go.
Keep in mind that it's still a six dollar motor, the next weak point is the bearings, keep them lubed.
The Assassin will tolerate a bigger motor (like a 3530) but will most likely need a bigger battery to balance it correctly (a 2200mah in my case). Fun to fly but you do end up with a much heavier plane.
What is your skill level and what kind of flying do you want to do?
jetpackninja is offline Find More Posts by jetpackninja
Old Nov 20, 2012, 11:39 AM
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
Originally Posted by jetpackninja View Post
@BlueDevil
Thanks for the input! As much as I like to fool with things and am pretty hands on guy, I'd about rather stay away from winding IF i could find a sweet setup just for time sake.. I seen a couple of vids with the 370 zoom that was mentioned and it seems to be close to what I'm use to speed wise so now I may go that route..
Yes I definitely need a wattmeter.. I had quite a bit $$ tied up in electric RC several years back and got out of it for several years.. just trying to get bits and pieces back as I can..
As far as skill I can fly pretty much anything.. 3D aerobatics.. I did photography when I was into RC years ago.. I use to have an Edge RC Devastator Wing that was a rocket! Probably 80+ mph. Really miss that plane and the Assassin seems like it may scratch that itch!
I wouldn't say I would win any competition awards haha but I'm pretty sure of myself and myself and my next door neighbor just do combat with the small wings we have now and I REALLY love speed..
Right now all I have is the Dynam SU-26M to satisfy my 3D itch and the Nitro Mini Pop Wing that goes about 65.. just want something a little bigger and a little faster..
Ok, enough rambling :-)
Old Nov 20, 2012, 03:35 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
I understand the way of thinking that buying a different motor is less work, and therefore preferable to re-winding a 2812. And even, at face value, cheaper than a 2812 + the price of a spool of wire.
BUT... a spool of wire can rewind at least 10 motors, if not 20. (I dunno, haven't gotten to the end of my spool yet.) It comes in handy for motors that go bad, or experimenting with different numbers of winds, and so on. Considering 2812's are about $6-$8, you can have a number of good, high-speed motors over time for less $.
Plus, for a hands-on, tinkering, like-to-get-in-and-understand-the-mechanics-of-things kind of person, like I am, the re-winding is just plain enjoyable.
And then there's the fact that you can put a 2812--stock or rewound--on lots of different planes, especially the CTH planes (Scythe, Assassin, Widowmaker, Roswell, Pelican, Albatross... am I missing one?). That means continuity, which means cost-saving. One extra motor or set of screws can be a backup for all of your planes, instead of having to buy different parts for different planes.
Bottom line, though: a rewound 2812 gets you going fast in the air. No doubt about it.
Old Nov 20, 2012, 04:20 PM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Just went on Plane Insane web site to buy the Assassin kit they sell..
Description Item price
34" EPP Assassin $53.45
Servo T-Pro Metal Gear MG90S (2 Servos) $17.00
Propulsion Kit CF28-12
Option(s): Hobbywing 30amp $32.00
Item total:$102.45
Mailing over to Ireland......
Shipping and handling Shipping and handling: (to ) loading...$1,000.00
Estimate shipping and tax
Select ship-to country (optional)
Total:$1,102.45 USD
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Nov 20, 2012, 04:24 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Shipping Rates
Shipping for all items is set at $6.00 to the lower 48 US states. Special shipping arrangements can be made for Alaska and Hawaii (please email me)
All foreign orders will cost $1000.00 for shipping. You think I'm joking? Add something to your cart. No but really, please send an email to ryan.planeinsane@gmail.com for international shipping quotes.
Contact Ryan- He'll fix you up with a quote-
Old Nov 20, 2012, 04:32 PM
Ireland, Cork
Joined Oct 2010
Will do .
Thanks.
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 31 Mar 18, 2015 05:25 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 0 Jan 28, 2004 12:40 AM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
