Old Nov 09, 2012, 11:17 AM
Tom Eutsler is online now
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Sources
Originally Posted by blunight View Post
Try Valuehobby.com as well. Excellent service, fast shipping
Jeff at headsuprc.com offers Very GOOD Service & $2.00 shipping
Tom Eutsler is online now Find More Posts by Tom Eutsler
Old Nov 09, 2012, 11:46 AM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Plane Insane used to have them as well- Haven't checked lately...
jetpackninja is offline Find More Posts by jetpackninja
Old Nov 10, 2012, 12:00 PM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Occasionally we cut wings that have minor defects, usually a wire mark from cutting the wing. It will not affect flight, and in most cases is not visible after the plane has been laminated. These kits are discounted and can be purchased based on availability.
These kits include the same EPP wing cores and elevons, laminate and hardware of the regular kit.
Please contact us though our website if you are interested.
http://crashtesthobby.com/sales
Lee is online now Find More Posts by Lee
Old Nov 10, 2012, 09:29 PM
Thursday is offline
Find More Posts by Thursday
Joined Oct 2012
Hey guys,
I'm currently building my Assassin and I've got a few questions as this is my first ever plane build. I found Ninjas Youtube video of his Assassin with a big battery and motor and he directed me here. I'm going to be following in his footsteps because I have a bunch of 2200 batteries for my 450 heli and I'm thrifty like that.
To show just how green I am I'll start with the most embarrassing question first.
How do I assemble the prop on the motor? I bought the same motor (ExceedRC 3010 1700KV) Ninja has from hobbypartz. It has a bunch of adapters and I'm not sure which ones I need and in which order. Also the mounting bracket doesn't seem like it will fit the assassin mount.
Is painting the laminate okay?
How do I setup a "bomb" drop servo? I've never really seen the mechanics of it all.
With my 2200mah battery should I be mounting as the directions state or will the CG be off?
That's all I can think of at the moment but I'm sure there will be more questions the further I get in the build. I've only laminated it so far, but now all the parts are here and I'm ready to finish it.
Thursday is offline Find More Posts by Thursday
Old Nov 10, 2012, 10:51 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Easiest way is with a "prop saver." (Don't know if you have one of those, but ya should get a few!) It's just a collar that goes on the motor shaft with two screws on each side. Slip that on, tighten it down, then put the prop on (with the right sizing ring stuck in the center of the prop). Then use an o-ring from screw-to-screw, over the prop, to hold it on.
Make sure you only mount the prop when you're ready to fly--for safety reasons. And Also make sure the prop is mounted the right direction. The thick side of the blade should be cutting the air.
Generally doesn't work out too well. If you really want paint, someone can chime in with the right type, but you have to paint the foam, then laminate over it, and get the timing just right.
Much easier and IMO more highly recommended to laminate, then use stick-on color sheets or colored packing tape to make designs. Way easier, bolder colors.
I'm going to defer to someone else on this. The only one I ever did was very unconventional. It didn't drop a bomb; it dropped an Assassin from a Storm Chaser. Wicked awesome, but not what you're looking for.
Oh, darn, that's right. CTH changed the instructions. This is exactly why I wish they hadn't.
Instead of a single measurement in the instructions where the electronics are "supposed" to go, the instruction used to include this other method (which you should follow, because yes, with a 2200 battery, your CG would be WAY off, if you stuck to their measurement which was designed for a 1300 batt):
1) finish the build up to where the wing is laminated and the elevons are hinged on.
2) measure where the proper CG should be, on the bottom of the wing (x" back form the nose... I forget)
3) extend a line perpendicular from that mark, out on either side of the wing, and stick a thumb tack in each side.
4) lay out all your electronics on top of the wing, how you think they'll go, then try to lift the wing up and balance it on the pins.
5) shift the electronics around as needed, until the wing balances (or gets as close as possible)
6) mark where all the electronics are sitting now, and then you can remove them and use those marks as guides to cut slots.
7) if you didn't have enough space on the surface to get things to completely balance, add weight (coins, washers, lead... whatever) to get it to balance.
elCapitan is offline Find More Posts by elCapitan
Old Nov 11, 2012, 06:06 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Just maidened my second assassin and contrary to the greatness of my first she nose dives and barely maintains level flight when i apply full elevator till it rolls n crashtesthobby lol, its truly identical but im assuming my elevons just arent where they were on my peecious one. What was the suggested starting setup for em?
elliott000 is offline Find More Posts by elliott000
Old Nov 11, 2012, 06:13 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Did you make sure your prop isn't on backwards? Done that before!
Recommended setup is slightly higher than the angle of the top of the wing just in front of the elevons, with movement being 3/8" up and 3/8" down
Old Nov 11, 2012, 06:36 PM
Lee is online now
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
A Reaper video with the Keychain Cameras #16 and #16D
RC Bowling with Reaper #16D HD (re-edit) (3 min 11 sec)
Old Nov 12, 2012, 01:46 AM
foamyflyerr is offline
Find More Posts by foamyflyerr
Joined Jun 2012
East Bay Boys Dave and Jim combating with Assassin Wings
Assassin Wings combat 11 11 2012 (4 min 25 sec)
foamyflyerr is offline Find More Posts by foamyflyerr
Old Nov 12, 2012, 06:25 AM
Lee is online now
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
http://www.youtube.com/watch?v=Qd6cRejQY_k
Great flying field. Watch out!!! Combat is addicting!!!
Old Nov 12, 2012, 01:53 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Mount the motor directly to the steel mount.
There is more than one way to get this all done but what I did was the reverse the shaft mod on this motor.
This motor doesn't have a second groove to move the e clip so I added a 5/32 wheel collar onto the end of the shaft to retain the shaft onto the motor.
Then a 4mm prop adapter on the other end.
How to reverse the shaft:
http://crashtesthobby.com/instructio...t-modification
4mm prop saver
http://www.hobbyking.com/hobbyking/s...FWrZQgodRSwAvA
Old Nov 12, 2012, 04:40 PM
Thursday is offline
Joined Oct 2012
4mm prop saver
Thanks ninja. I was finishing mine up about the time you posted this. I did it a little different using one of the adapters that came with the motor.
I finally finished it and of course antsy me took it out in all this snow we have here in Farmington. Now I think I shorted my ESC. You guys make getting in the air look easy or I have something seriously messed up with my assassin. I'll post some pictures of my build a little later.
Old Nov 12, 2012, 04:56 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Some things to check.
CG- 6.25 to 6.5 in back from the nose
Reflex- make sure that the elevons have some "up" with the servos centered. If they are trimmed neutral, you're headed for the ground
Elevons are set up correctly- it's easy to get a servo reversed
Prop on backwards?- make sure the letters are facing the front.
What esc are you using? This particular motor seems to like to be set on "high" timing for some reason...
Old Nov 12, 2012, 05:16 PM
Thursday is offline
Joined Oct 2012
Good news I sat my assassin in front of the fire place to get all the snow off and its working again. I think my left and right controls might be wrong unless the directions are wrong. Left stick = Left elevon up??
Here's how my motor turned out.
Old Nov 12, 2012, 05:26 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
move the right stick all the way to the left- left elevon goes up
move the right stick all the way to the right- right elevon goes up
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 3 Sep 04, 2016 05:47 PM
WALLY WING...no fins...flies great!!! gpw Foamies (Kits) 32 Aug 31, 2016 08:21 AM
Qjet Flamingo & Butterfly: A plane no one has!! romans1015 Parkflyers 6 Jan 29, 2004 04:05 PM
Noob concept plane Mikey C. Foamies (Kits) 5 Nov 11, 2003 01:05 PM
It's a boat...It's a plane...no! It's flightship! MrBungle Electric Plane Talk 24 Jun 26, 2001 01:55 AM
